Of 0w-20 oils, which have highest VI
by Bill_W - 06/04/20 03:44 PM
Gasket vs RTV?
by supton - 06/04/20 02:29 PM
List Impossible Sparkplug Replacement
by borgward - 06/04/20 01:31 PM
BMW Diesels
by Trix - 06/04/20 12:21 PM
Shell Rotella Gas Truck 0W-20 UOA Honda Civic
by Davejam - 06/04/20 11:50 AM
replacement tires for 2013 vw passat 2.5
by jstert - 06/04/20 11:04 AM
Communication with Castrol
by BTLew81 - 06/04/20 10:47 AM
How Often Do You Check Your Oil?
by Gebo - 06/04/20 10:04 AM
Slightly OT....shelf life of "boxed" oil containers
by nascarnation - 06/04/20 10:00 AM
choose tire
by John_Conrad - 06/04/20 09:57 AM
J35Y
by tbm5690 - 06/04/20 09:26 AM
Need help with CV Joint grease, very limited choices
by leoblack9 - 06/04/20 08:41 AM
Amsoil 0W20, 2016 Honda Accord V6
by Eddddd - 06/04/20 07:59 AM
New to me Ford Escape
by krz - 06/04/20 06:57 AM
Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
106 registered members (ArrestMeRedZ, 2015_PSD, Anduril, another Todd, 4WD, aquariuscsm, 10 invisible), 2,126 guests, and 70 spiders.
Topics306,138
Posts5,288,212
Members71,604
Page 1 of 5 1 2 5
ATF that meets many spec's: How can it? #4468073 07/23/17 02:41 PM
T
tig1 Offline OP
T
I am at the point where I don't really trust an ATF that meets many differenty spec's, for several different makes.
2007 Ford Fusion 258,000 miles
M1 5-20HM
2017 Ford Fusion 91K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: ATF that meets many spec's: How can it? [Re: tig1] #4468085 07/23/17 02:53 PM
J
Jimzz Offline
J
Because many makers fluid are not that much different. Most of the issues were the viscosity and how it holds up to heat. You notice all the ATFs that meet a lot of specs is a synthetic base like Valvoline Maxlife for example. So since the fluid can hold its viscosity much better now it can work on more vehicles.
yup
Re: ATF that meets many spec's: How can it? [Re: tig1] #4468087 07/23/17 02:54 PM
G
Gebo Offline
G
I feel exactly the same as you.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: ATF that meets many spec's: How can it? [Re: tig1] #4468095 07/23/17 03:04 PM
MolaKule Offline
Global Moderator
Global Moderator
Quote:
The secret of Multi-Vehicle ATF's such as MaxLife or D4 or D6 or Amsoil ATF's is the mix of specialized friction modifier chemistry's which cover a spectrum of dynamic friction coefficients.
Broad Spectrum ATF
I have wondered if this spec thing is more of a scam than anything else. I have used M1 ATF for years in the Fusion and M1 ATF doesn't have the FNR-5 spec. that my Fusion calls for.
What do you think M1 ATF is?
It is mostly a higher viscosity version of Redline D6, MaxLife ATF, and Amsoil ATL.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4418097/1
"As engineers [and scientists] we are wired to solve problems and to create new things, to challenge the status quo and push the limits..." Ken Hurt, Embry-Riddle University, Class of '97.
Re: ATF that meets many spec's: How can it? [Re: tig1] #4468104 07/23/17 03:11 PM
W
Wolf359 Offline
W
I think if you're in a jam and that's the only fluid available use it. But if you have the option, I'd use the one that meets the spec. Valvoline is actually the worse, they claim that their fluid is suitable for applications that call for a specific spec, but they're not actually certified for that spec. I think they have to pay some license fee to do it and they don't pay it. Their Mercon V and other fluids are like that. There are actually alternatives that meet spec and are cheaper than Valvoline (like supertech) so why bother with a fluid that isn't approved by the manufacturer?
Re: ATF that meets many spec's: How can it? [Re: Wolf359] #4468122 07/23/17 03:35 PM
MolaKule Offline
Global Moderator
Global Moderator
Originally Posted By: Wolf359
But if you have the option, I'd use the one that meets the spec. Valvoline is actually the worse, they claim that their fluid is suitable for applications that call for a specific spec, but they're not actually certified for that spec...
Don't know what you mean by actually worse.
Projected coverage and Labeling have been discussed many times before here on BITOG.
No where does Valvoline or any of the other Multi-Vehicle ATF manufacturers claim licensing numbers by the OEM's.
Most ATF manufacturers such as Valvoline also carry Certified fluids that carry OEM licensing numbers, but at a higher per quart price, because licensing adds to the cost.
Re: ATF that meets many spec's: How can it? [Re: Wolf359] #4468124 07/23/17 03:36 PM
Hootbro Offline
So where is the data showing transmissions exploded because they used a consumer manufactured "recommend" ATF vs. actual licensed ATF product? Examples of people doing their first ATF change at 150K miles do not count, I am talking about normal service interval changes.
I think these multi-vehicle ATF makers like Valvoline, Mobil, AMSOIL and a host of others have done their homework. In my opinion, most of these vehicle makers that spec low viscosity fluids Mercon LV, Dexron VI, Toyota WS, Matic S and others, are all basically calling for the same fluid but pride does not allow them to call out an already made fluid used in other makes and they then spec their own fluid and call it something proprietary.
If people are in warranty, I get the need to stay with something licensed, but outside warranty, there is plenty of reliable multi-fluids to fill ones maintenance needs.
2020 Jeep Gladiator Rubicon 3.6L (Dealer Bulk 0W-20)
2018 Chevrolet Colorado Z71 3.6L (Dealer Bulk 5W-30)
2013 Volkswagen Jetta 2.5L (Havoline HM 5W-30)
Re: ATF that meets many spec's: How can it? [Re: tig1] #4468125 07/23/17 03:38 PM
MolaKule Offline
Global Moderator
Global Moderator
thumbsup thumbsup
Re: ATF that meets many spec's: How can it? [Re: MolaKule] #4468149 07/23/17 04:20 PM
W
Wolf359 Offline
W
I feel they're the worse because they're basically mass market fluids which you can find on the shelf at the local Walmart. There are other fluids that do the same thing, but they're more boutique fluids so the owners probably know what they're getting into when buying them. I think they're basically somewhat deceptive because their wording usually says "suitable for applications that call for xxx" but it doesn't actually say that it meets that spec so if you don't read it carefully you'd think it met the spec. And I'm not sure Valvoline actually has a fluid that can be easily found on the shelf that meets Mercon V spec or even MB 236.14 (ATF 134).
My question is why would you pay more to buy a fluid that doesn't meet manufacturer spec when there are cheaper fluids out there that meet spec? Doesn't make any sense. Plus when your transmission blows up, do you blame the transmission or the fluid? You've got a tough case to prove there, why take the risk by using something that doesn't meet spec? Again, the whole thing doesn't make sense. Pointless risk, don't really see the potential gain.
Re: ATF that meets many spec's: How can it? [Re: Wolf359] #4468159 07/23/17 04:26 PM
MolaKule Offline
Global Moderator
Global Moderator
Valvoline MaxLife labeling indicates MerconV coverage except in California which took issue with the viscosity requirement but which PQIA earlier accepted a statement indicating Valvoline's line of reasoning.
Quote:
*Please note that legislation in California prohibits Valvoline from recommending MaxLife™ ATF in certain applications where the viscometrics of MaxLife™ ATF do not match those of the official OEM specification. Valvoline therefore does not recommend the use of MaxLife™ ATF in these applications in California.
Of course we are aware of California's pendent for Overregulation.
Nothing deceptive about it as long as they don't state the respective fluids are licensed by the OEM's.
Don't know why there are two separate threads on the same subject???? ??? I guess people are only interested in their own worlds.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4389454/'Broad_Spectrum'_ATF,_how_does#Post4389454
Re: ATF that meets many spec's: How can it? [Re: tig1] #4468193 07/23/17 05:01 PM
L
L_Sludger Offline
L
I have a hard time trusting the universal stuff too.
That's why I spend the extra time and money to get the manufacturer specific stuff - I don't want to take that chance.
Re: ATF that meets many spec's: How can it? [Re: L_Sludger] #4468197 07/23/17 05:06 PM
MolaKule Offline
Global Moderator
Global Moderator
We have choices here and I have never seen a bottle of Valvoline MaxLife move off the shelves and twist anyone's arm.
Re: ATF that meets many spec's: How can it? [Re: tig1] #4468199 07/23/17 05:07 PM
SilverFusion2010 Offline
I went with motorcraft Mercon LV for my drain and fill. Before that it had the maxlife multi LV fluid and it ran fine, but now the little voice is quiet because I know the ford specified fluid is in there
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: ATF that meets many spec's: How can it? [Re: tig1] #4468216 07/23/17 05:32 PM
U
user52165 Offline
U
Based on what evidence?
Or just "feelings"?
Re: ATF that meets many spec's: How can it? [Re: tig1] #4468245 07/23/17 05:58 PM
M
merconvvv Offline
M
Motorcraft atf is pretty cheap.
Thats what i use in the expedition drain and fill. About 4 or 5 drains and fill.
1988 Mazda RX7 na PP 10w30 Noack 4.7
1994 Chrysler Concorde 3.3
1999 Ford Expedition 4.6 QSUD 10W30 NOACK 5.0
Page 1 of 5 1 2 5
