1994 Civic LX, 1.5L hard to start
by Gito. 12/19/18 08:01 AM
Observation of Mechanics and their tools...
by ToadU. 12/19/18 07:56 AM
Toshiba Laptop HDD Replacement
by Ifixyawata. 12/19/18 07:49 AM
Aisin Warner TF-71SC
by Bailes1992. 12/19/18 06:37 AM
on the Fence about giving up Facebook
by Donald. 12/19/18 06:20 AM
Motorcraft Mercon LV, 15k, 15' Ford Fusion 6F35
by ssamaroo01. 12/19/18 06:14 AM
RockAuto AC compressors
by chrismo. 12/19/18 05:38 AM
Fullers Vintage Ale anyone?
by Lolvoguy. 12/18/18 11:23 PM
Got an alignment
by michaelluscher. 12/18/18 11:18 PM
Castrol Edge 0W-40; 9,762 mi; 2016 Ford Fiesta ST
by asiancivicmaniac. 12/18/18 10:50 PM
Windows Defender Error Code
by ZeeOSix. 12/18/18 10:20 PM
UOA Motul 300V, 5w40, 2013 BMW S1000RR
by Sportbiker. 12/18/18 09:53 PM
Under valve cover pics
by barkingspider. 12/18/18 09:47 PM
Kubota Super UDT2? Anything better?
by Jmoney7269. 12/18/18 09:23 PM
Car Door Fabric Glue
by cb450sc. 12/18/18 08:57 PM
Canadian Uber
by StevieC. 12/18/18 08:13 PM
71141 / Lifeguard 5
by chefwong. 12/18/18 07:52 PM
blkvzgo, AdamJames, Firefighter3244, Sportbiker, trollhattan
66721 Registered Users
90 registered members (andyd, 2012AccentSE, A310, 53' Stude, 1foxracing, 2004tdigls, 12 invisible), 1,463 guests, and 37 spiders.
Topics295,256
Posts4,930,989
Members66,721
Most Online2,553
Oct 27th, 2018
Worth reremong UP TO DATE smog on 454 motorhome ? #4467942
07/23/17 10:33 AM
07/23/17 10:33 AM
AZ
leroyd92 Offline OP
leroyd92  Offline OP
AZ
Would it be worth removing the current ( up to date) smog on a crate 454 motorhome?
Would i gain slight fuel economy ? Or power?
We have plans to pull a 6klb boat/ trailer once in a while.
Supertech Junky
Re: Worth reremong UP TO DATE smog on 454 motorhome ? [Re: leroyd92] #4467948
07/23/17 10:42 AM
07/23/17 10:42 AM
Indiana
nascarnation Offline
Indiana
What generation of "smog" controls do you have?
Re: Worth reremong UP TO DATE smog on 454 motorhome ? [Re: leroyd92] #4467961
07/23/17 11:04 AM
07/23/17 11:04 AM
AZ
leroyd92 Offline OP
leroyd92  Offline OP
AZ
Whoops.... Most important part of question.
1982.
So i have the air pump,egr charcoal canister. And whatever else i can't remember @ the moment.
Supertech Junky
Re: Worth reremong UP TO DATE smog on 454 motorhome ? [Re: leroyd92] #4467971
07/23/17 11:19 AM
07/23/17 11:19 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
1982.
So i have the air pump, egr, charcoal canister. And whatever else i can't remember @ the moment.
None of these really hurt your power. EGR actually helps with part throttle fuel economy.
Re: Worth reremong UP TO DATE smog on 454 motorhome ? [Re: leroyd92] #4468031
07/23/17 12:39 PM
07/23/17 12:39 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
If the air pump is not working properly then the oxygen sensor in the exhaust will see the wrong information and the engine will not run properly. Do not remove the air pump. If you do you will mess up the way the engine runs.
My 1985 Olds 88 has an air pump. The pipe to one of the exhaust sides rusted out and was leaking the pumped air out before it got to the exhaust. The oxygen sensor was seeing the wrong information and the engine would not idle properly. Fixed the pipe between the air pump and the exhaust and the engine now runs and idles properly.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Worth reremong UP TO DATE smog on 454 motorhome ? [Re: leroyd92] #4468186
07/23/17 03:53 PM
07/23/17 03:53 PM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
I would not do it personally. Messing with smog equipment is a federal beef, and big vehicles like that get more scrutiny than passenger cars.
IOW, the juice isn't worth the squeeze.
too many cars and oil combinations to list in 150 characters or less
Re: Worth reremong UP TO DATE smog on 454 motorhome ? [Re: leroyd92] #4468206
07/23/17 04:17 PM
07/23/17 04:17 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
I would leave it alone unless it's malfunctioning. You'd have to reprogram the ecu to get any benefits. Go with low restriction mufflers instead.
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Worth reremong UP TO DATE smog on 454 motorhome ? [Re: leroyd92] #4468224
07/23/17 04:37 PM
07/23/17 04:37 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I don't think the heavy duty 454's in 1982 had any electronics... the small blocks had "ESC" (elec spark control) but I don't recall seeing any '82 big blocks with it.
Re: Worth reremong UP TO DATE smog on 454 motorhome ? [Re: leroyd92] #4468240
07/23/17 04:53 PM
07/23/17 04:53 PM
AZ
leroyd92 Offline OP
leroyd92  Offline OP
AZ
There's no sensors nor computers...
I personally don't wanna mess with it. But if there's mountains to gain id be open to the idea
Supertech Junky
Re: Worth reremong UP TO DATE smog on 454 motorhome ? [Re: leroyd92] #4468256
07/23/17 05:04 PM
07/23/17 05:04 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
Many of those engines were down on power, not because of the bolted on emission controls, but because of the internal design. Cam timing, valve lift, and duration were all extremely conservative. The compression ratio was also very low. In addition, the valve sizes and port sizes conspire to limit output.
However, if you have one of the old style catalytic converters on it, and small, single exhaust/muffler, they are quite restrictive.
For a while, owners of these were installing free flowing exhausts and the aftermarket throttle body fuel injection systems. That did help the power and MPG, plus eliminated the hot start issues some of them had.
EDIT: Those in the know, replaced those engines with the marine versions that produced 400HP stock.
Re: Worth reremong UP TO DATE smog on 454 motorhome ? [Re: leroyd92] #4468274
07/23/17 05:26 PM
07/23/17 05:26 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Replace all the vacuum hoses. Those cause the most trouble on engines of that era. Headers and duel exhaust will help too.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Worth reremong UP TO DATE smog on 454 motorhome ? [Re: JimPghPA] #4468279
07/23/17 05:29 PM
07/23/17 05:29 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
A.I.R only pumps air into the exhaust during "Open Loop" operation, With an old system like yours with a non-heated O2 sensor was any time the engine is cold or idling.....This is also why the system has Diverter Valve/s to divert the air away from the manifold.
2001 Chevy Camaro L92/4L80E
Re: Worth reremong UP TO DATE smog on 454 motorhome ? [Re: leroyd92] #4468301
07/23/17 06:12 PM
07/23/17 06:12 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
You answered your own question!
However if you really wanted to do some tuning.....There is probably alot on the table for that engine even if it's a low compression variant. It's just a ton of work on a carbureted engine.
If it was mine, I would.......
Rip all the A.I.R system off & plug the ports on the manifolds, It creates exhaust heat & that is the last thing you need!
Dual 2 1/2" pipes into Flowmaster Big Block II mufflers, Have a O2 bung welded on each side as close to the manifolds as possible with plugs.
Buy a Wide Band Sensor & monitor (Probably lost you right there because the price)
I would plug the EGR because it will plug itself eventually.....Then you have way to much timing!
Re-Curve your distributor! This is where the most gains come from!
On this engine without EGR.....34-36 degrees total mechanical all in by 2500-2800. Plus 10 degrees vacuum advance hooked to Manifold Vacuum, You will need to limit your existing vacuum advance or buy a adjustable one.
I don't worry much about initial timing as long as the starter don't kick on hot re-starts....I like around 10-12 degrees.
Then use the Wide Band to "Jet" the carburetor (Jets & Metering Rods on a Q-Jet) to achieve as close to 14.7:1 AFR during cruise situations as you can, WOT & High Load will be richer because the accelerator pump & Secondary enrichment circuit.
You will probably need to set/adjust the Secondary Air Valve opening rate which can be tedious....But will eliminate the BOG associated with most Q-Jet carburetors.
Re: Worth reremong UP TO DATE smog on 454 motorhome ? [Re: leroyd92] #4468524
07/23/17 10:29 PM
07/23/17 10:29 PM
CA
user52165 Offline
user52165  Offline
CA
Exactly which crate engine is this?
Wide variety of 454 from mild to wild.
Re: Worth reremong UP TO DATE smog on 454 motorhome ? [Re: leroyd92] #4468623
07/24/17 05:27 AM
07/24/17 05:27 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
I'd have a set of long tubes on that thing by yesterday. That's what's really going to open things up.
