Car Door Fabric Glue
by cb450sc. 12/18/18 08:57 PM
Canadian Uber
by StevieC. 12/18/18 08:13 PM
71141 / Lifeguard 5
by chefwong. 12/18/18 07:52 PM
Tested Positive for Flu
by john_pifer. 12/18/18 07:37 PM
Cooper RTX?
by 01rangerxl. 12/18/18 07:25 PM
IPhone SE or flip phone?
by 53' Stude. 12/18/18 05:49 PM
1993 K1500 hard cold start
by BrianF. 12/18/18 05:43 PM
Put my wife's dog down yesterday
by Stelth. 12/18/18 05:04 PM
ATF Filter oem vs aftermarket any differences?
by 97prizm. 12/18/18 03:50 PM
Depth-Fiberglass Filter Media.
by Al. 12/18/18 03:43 PM
O2 sensor B1S1 no voltage??
by David1. 12/18/18 03:43 PM
Brilliant payback for package thieves
by SirTanon. 12/18/18 01:22 PM
Calling all Ford Owners
by dogememe. 12/18/18 01:01 PM
2003 Ford CVPI, 86kmi, 6kmi on Edge HM Ti 5W30
by Colt45ws. 12/18/18 12:35 PM
2017 Kia Sportage recall notice
by SlavaB. 12/18/18 12:26 PM
My VW Service Experience
by Delta. 12/18/18 11:36 AM
Nissan high idle, P0507
by LeakySeals. 12/18/18 11:23 AM
Sportbiker, trollhattan, MuhThugga, wxo, dbierman
66718 Registered Users
108 registered members (14Accent, andyd, -SyN-, 330indy, A310, aquariuscsm, 10 invisible), 1,896 guests, and 39 spiders.
Topics295,237
Posts4,930,732
Members66,718
Most Online2,553
Oct 27th, 2018
Comparing oil filters #4467583
07/22/17 10:02 PM
07/22/17 10:02 PM
US
TheOilWizard Offline OP
US
When comparing the ACDELCO PF1237 and FRAM TG6600, does either filter offer a clear advtange in quality or performance, or is it completely subjective? My research indicates that both filters share many of the same features. One obvious difference is the TG has twice as many holes on the top plate (where it mates with the engine), but not sure if that means much of anything.
Thoughts? I should also add that the TG retails for about twice as much as the ACDELCO. The ACDELCO is not an ecore version.
Re: Comparing oil filters [Re: TheOilWizard] #4467587
07/22/17 10:06 PM
07/22/17 10:06 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
The unknown secret that 99.999% of the people do not know is the best oil filter is a good air cleaner and the intake plumbing not leaking.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Comparing oil filters [Re: TheOilWizard] #4467593
07/22/17 10:11 PM
07/22/17 10:11 PM
US
US
That's great advice. Thank you.
Re: Comparing oil filters [Re: TheOilWizard] #4467594
07/22/17 10:11 PM
07/22/17 10:11 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
Originally Posted By: TheOilWizard
does either filter offer a clear advantage in quality or performance,
You would have to compare efficiency numbers.....
but even at that, there will be no impact on the longevity of your engine,
unless you run your filters 20,000+ miles
Re: Comparing oil filters [Re: TheOilWizard] #4467598
07/22/17 10:15 PM
07/22/17 10:15 PM
Dallas,Tx USA
aquariuscsm Online content
aquariuscsm  Online Content
Dallas,Tx USA
One of my mandatory requirements for an oil filter is a thick heavy can. I can crush a yellow Purolator with my bare hands.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum 5W20
Re: Comparing oil filters [Re: TheOilWizard] #4467599
07/22/17 10:18 PM
07/22/17 10:18 PM
US
US
Are you concerned the housing will burst or something?
Re: Comparing oil filters [Re: aquariuscsm] #4467600
07/22/17 10:18 PM
07/22/17 10:18 PM
Cali
Malo83 Offline
Malo83  Offline
Cali
Wix/NAPA filters are all I use, no need to lose sleep over an oil filter cheers
Re: Comparing oil filters [Re: aquariuscsm] #4467605
07/22/17 10:26 PM
07/22/17 10:26 PM
Waco, TX
Waco, TX
This proves nothing - - the pressure is from the "inside out"
I've never seen an oil filter burst under normal operation.
Re: Comparing oil filters [Re: Linctex] #4467610
07/22/17 10:40 PM
07/22/17 10:40 PM
Dallas,Tx USA
Dallas,Tx USA
I guess my concern with a thin can is how well it can withstand damage from road debris.
Re: Comparing oil filters [Re: aquariuscsm] #4467745
07/23/17 06:54 AM
07/23/17 06:54 AM
Waco, TX
Waco, TX
Is it in a highly susceptible location?
I never see so much as a chip in the paint of the filters I pull off, MUCH less a dent or puncture.
Re: Comparing oil filters [Re: aquariuscsm] #4467812
07/23/17 08:07 AM
07/23/17 08:07 AM
PA
copcarguy Offline
copcarguy  Offline
PA
I've had a ding in the filter on my '07 Caravan 3.3 a time or two. It's right out front directly behind the radiator support, wide open. Not a good location at all.
Re: Comparing oil filters [Re: TheOilWizard] #4467834
07/23/17 08:34 AM
07/23/17 08:34 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
If you drive a truck with all-terrain or mud terrain tires, on gravel roads, it is VERY possible to have dents or even holes in an oil filter that hangs down by the oil pan. The (now hard to find) Bosch Distance Plus is probably the most rock resistant one-I'm actually going to use a Baldwin HPG on the XJ as an external transmission filter, mounted behind/under the radiator core support.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Comparing oil filters [Re: TheOilWizard] #4467877
07/23/17 09:31 AM
07/23/17 09:31 AM
Waco, TX
Waco, TX
Then I think a rubber (or even metal) sleeve that slides over the can would be an order of magnitude better protection, & hopefully could/would be reusable.
Re: Comparing oil filters [Re: Linctex] #4467881
07/23/17 09:35 AM
07/23/17 09:35 AM
Waco, TX
Waco, TX
Re: Comparing oil filters [Re: Linctex] #4468096
07/23/17 02:07 PM
07/23/17 02:07 PM
Dallas,Tx USA
Dallas,Tx USA
Well,both of mine are on the very bottom,but located at a higher elevation than the oil pan. I've heard of that happening,maybe it's just an internet urban legend. People will find a tiny gash hole in the oil filter can where oil has seeped out.
