Found an unopened bottle of Schaeffers 132 and wanted to try it. it might be from 2010 tho. it was thicker than honey, kinda like that STP stuff from the 80s. No it was like blue goop. took several min to clear a narrow funnel. Black bottle was stored indoors in a box no sunlight and not deformed. So thick i only added 40% of the bottle. it says add the whole pint to 94 Camaro Z28
First drive, quieter but oil pressure is remaining high for 6 or 7 min, like cold start pressure, not going down. So i came home and shut down after only 7 min. Ambient 85F.
my water temp gauge sensor is not working, have to replace. i'm worried about blocked oil passages. has this happened to anyone?
did it thicken too much or interact with the Valv max life 10w-30 in there? thanks
