Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
42 registered members (carlprop, bbhero, Ag76, ArrestMeRedZ, Agnosto, 4 invisible), 912 guests, and 58 spiders.
Topics286,170
Posts4,903,517
Members67,572
Most Online2,967
Mar 10th, 2019
best filter ? #4467199
07/22/17 02:17 PM
07/22/17 02:17 PM
Missouri
hardheaded Offline OP
Missouri
getting ready to change fluid and filter in my "new to me " 2000 pontiac bonneville ssei. dex 6 is the fluid i'm going to use, but what and who carries the best filters ? i have a advanced auto parts store two blocks away and was looking over their filters and don't really know where to buy. auotzone and napa not to far away either. any suggestions ?
Re: best filter ? [Re: hardheaded] #4467206
07/22/17 02:27 PM
07/22/17 02:27 PM
Twin Cities MN USA
Inspecktor Offline
Inspecktor  Offline
Twin Cities MN USA
http://shop.tripleedgeperformance.com/4T60E-65E-Filter-84710E.htm Allomatic filters made in the USA. I installed this one in my Buick, good tight fit. I think Napa carries them, at least in the past.
2001 Ranger 3.0 168,000 mi
2006 Dakota 4.7 156,000 mi
1986 GL1200A 73,500 mi
2001 Buick LeSabre Limited 292,000 mi
Re: best filter ? [Re: hardheaded] #4467210
07/22/17 02:34 PM
07/22/17 02:34 PM
Michigan
BobsArmory Offline
BobsArmory  Offline
Michigan
I have only had good luck with NAPA and OEM filters ACDelco for you.
Keeping the forces of evil at bay
2016 Chevy Malibu LT 1.5 Liter Turbo
2017 Chevy Equinox LT 2.4 Liter
Re: best filter ? [Re: hardheaded] #4467232
07/22/17 03:13 PM
07/22/17 03:13 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I had a transmission filter from Napa that was "made in Israel" but looked like it was well made.
Re: best filter ? [Re: hardheaded] #4467246
07/22/17 03:58 PM
07/22/17 03:58 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Not to throw a wet blanket on the whole deal but I wouldn't worry to much about the filter, get the one from NAPA and call it done, the 4th gear input shaft or forward band will probably fail long before anything else does if its the original unit.
The 4T65E was iffy especially the earlier ones like this one. The good news is once its rebuilt with a few goodies its a very good unit and not that expensive to do.
Re: best filter ? [Re: hardheaded] #4467274
07/22/17 04:52 PM
07/22/17 04:52 PM
Canada
i_hate_autofraud Offline
Canada
When it comes to tranny filters including 4T65Es, no filter can get rid of the wear metals that wind up
in the PCS solenoids or the shift solenoids which causes tons of shift issues.
Tranny filters at best may filter out clutch plate material - period. But you'll always need one since
they easily load up and restrict suction at the oil pump inlet and create shift issues too.
Wear metals are supper fine (.1 to 10 microns) and can only be caught with magnets, & GM uses the crummiest they can get.
Search "4T65E Magnets" there's a TSB where GM half-admits they did it wrong!
I loaded my 4T65E oil pan inside with lots of magnets to reduce the effect of metals in the ATF
and solenoid problems, works well. Be sure to test fit the pan to see that magnets don't hit anywhere since clearance
is near zero.
The filter has a metal plate intake that's recessed from the bottom of the pan, good place for 4 to 6 magnets!
Re: best filter ? [Re: hardheaded] #4468214
07/23/17 05:30 PM
07/23/17 05:30 PM
Missouri
Missouri
where are you buying these magnets at ?
Re: best filter ? [Re: hardheaded] #4468311
07/23/17 07:20 PM
07/23/17 07:20 PM
Trav Offline
Trav  Offline
I just use the 2 GM magnets mentioned in the TSB P/N 29535617, they work okay. No need getting goofy stuffing magnets all over the place, sometimes too much of a good thing is not the best idea.
https://www.amazon.com/ACDelco-29535617-...6Q2CT07TAEJ4FX1
TSB
Re: best filter ? [Re: hardheaded] #4468897
07/24/17 12:20 PM
07/24/17 12:20 PM
Missouri
Missouri
i got the AC Delco filter and two new magnets coming my way today. i must thank everyone for all the info here. i would have never known about the magnet without coming here first. THANKS !
Re: best filter ? [Re: hardheaded] #4471567
07/27/17 04:30 AM
07/27/17 04:30 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Recently got the two GM magnets at Rock Auto for 6.90 ea. Also check out the diff. tube clamp made by Sonnax, part # 84532-01K. A cheap,worthwhile addition while the pan is off.
The "thinking" man's friend.
Re: best filter ? [Re: Lubener] #4471568
07/27/17 04:32 AM
07/27/17 04:32 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Sorry too late but others might want to check out.
