sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Rough Idle after short trip
by Datarock. 12/15/18 09:07 AM
Homelite 360
by mobilaltima. 12/15/18 09:04 AM
Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Hyundai extended my warranty
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
NEKGuy, Deltafaatl, wsalopek, jcr1293, maxwellk
66684 Registered Users
85 registered members (aba4430, 53' Stude, amblerman, A310, 69GTX, 7 invisible), 1,887 guests, and 36 spiders.
Topics295,101
Posts4,927,813
Members66,684
Most Online2,553
Oct 27th, 2018
Transfer Pump - ATF change - PS #4467118
07/22/17 11:21 AM
07/22/17 11:21 AM
Texas
WyrTwister Offline OP
Texas
https://www.harborfreight.com/multi-use-transfer-pump-63144.html
Bought this at harbor freight a few days ago . Cheap enough at $ 5.95 .
This morning I used it on our new-to-us 2006 Buick Lacrosse CX 3.8l . I had driven the Buick this morning on some errands , so the transmission was warm and the fluid " stired up " .
I found an empty 1 gallon plastic jug that had contained windshield wiper fluid .
The pump came with 2 orange plastic flexible tubes , 1 in & 1 out . I pulled the transmission dipstick and shoved the " in " tube down the tip stick tube until it would not go any further . The pump started sucking air just as the 1 gallon jug was filled .
I had ordered 6 - 1 quart bottles of Valvoline Synthetic Dexron VI ( blue bottle ) from Walmart online . In a few minutes , I am going to dump 4 of them into the transmission .
The fluid that came out was darker than it looked , on the dip stick . I am really glad I did this , although I know roughly 1/2 of the old fluid remains in the transmission / torque converter .
I am thinking about doing our 1991 Chevy Caprice 5.0l next . Then , maybe the 2015 Chevy Sonic .
I know this does not get the filter changed , but it has to be better than nothing . And the Sonic does not have a DIY serviceable filter , anyway .
PS Only got about 1-1/2 - 2 quarts out of the Caprice , before it started sucking air .
Wyr
God bless
Re: Transfer Pump - ATF change - PS [Re: WyrTwister] #4467138
07/22/17 11:54 AM
07/22/17 11:54 AM
Connecticut
69GTX Online content
69GTX  Online Content
Connecticut
I tried doing the same thing on my 2002 and the hose stops at the base of the tube. I'm lucky to get 4-6 oz of fluid out before the pump is pushing air. From what I recall, there's a protective clip on the bottom of that tube that is visible from the pan side. I guess the OEM wanted to ensure that foreign material didn't make it all the way down the tube....in this case....a pump hose.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Transfer Pump - ATF change - PS [Re: WyrTwister] #4467140
07/22/17 12:03 PM
07/22/17 12:03 PM
Canada
i_hate_autofraud Offline
Canada
As far as the 2006 Buick Lacrosse CX 3.8l is concerned, you have a 4T65E tranny, Be sure to drive it a few miles stop and go
and then check the new ATF level again, typically it will seem to drop on the dipstick.
That is, a warm engine by idling won't give you a hot tranny with the true ATF level. Top up as needed.
4T65Es don't like low ATF levels even if just on Min on the dipstick, including HD models.
Re: Transfer Pump - ATF change - PS [Re: WyrTwister] #4467142
07/22/17 12:05 PM
07/22/17 12:05 PM
MN
TmanP Offline
TmanP  Offline
MN
I did the exact same thing (on my exact same car) with the same pump. Using the small black hose, I was able to get out exactly 6 quarts of ATF. I did this twice. Then I used it to change the power steering fluid. Here's a writeup I did on that: https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4190408/I_changed_my_p.s._fluid,_it's_
I found that it works pretty well!
2012 Toyota Camry 2.5 30,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 30,000 mi
2010 Toyota Sienna 3.5 V6 150,000 mi
Re: Transfer Pump - ATF change - PS [Re: WyrTwister] #4467182
07/22/17 12:48 PM
07/22/17 12:48 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Get a smaller diameter tubing, like some polyethylene - - like Ice maker water tube, but a little bigger. (at the hardware store)
Re: Transfer Pump - ATF change - PS [Re: WyrTwister] #4467220
07/22/17 01:49 PM
07/22/17 01:49 PM
Onondaga County
Miller88 Offline
Miller88  Offline
Onondaga County
I've had a few of those ... they are so cheap I never keep track of where I leave them. Work well for lighter fluids - ATF and engine oil and such. they do get a bit frustrating when it comes to filling differentials. ..
18 Forester 2.5I 6M
00 Jeep Cherokee
01 Ford F-350 XL 4x4 5M
Re: Transfer Pump - ATF change - PS [Re: WyrTwister] #4467281
07/22/17 03:59 PM
07/22/17 03:59 PM
Canada
Canada
I used to hate pulling the tranny pan, but now it's easy:
- I use a long, wide, 5" tall lid of cheap 100L tupperware-type storage bin to catch all the ATF in one shot!
- I use a cordless driver to remove bolts fast.
- I got scoops sized to tranfer ATF from the catch bin to jugs
- I get to see what's all over the 8 magnets and clean them off!
- I get to replace the tranny filter early!
- gives me a new opportunity to find places to cram more magnets! wink
As a result I skip using transfer pump
Re: Transfer Pump - ATF change - PS [Re: TmanP] #4467284
07/22/17 04:06 PM
07/22/17 04:06 PM
Texas
Texas
Did not try the black hose . 4 quarts with the orange hose . May need to try the black hose ob the Caprice .
Thanks , :-)
Wyr
God bless
Re: Transfer Pump - ATF change - PS [Re: WyrTwister] #4467288
07/22/17 04:10 PM
07/22/17 04:10 PM
Texas
Texas
Had not thought of using it on differentials .
They are cheap enough that you could buy one for each of the different types of fluids . If you have several vehicles .
I bought 2 turkey basters , one for PS fluid and one for brake fluid .
Thanks , :-)
Wyr
God bless
Re: Transfer Pump - ATF change - PS [Re: i_hate_autofraud] #4467297
07/22/17 04:20 PM
07/22/17 04:20 PM
Texas
Texas
You left out jacking up the car & putting it on jack stand . And getting down on the ground or concrete . Then getting up and down a few times .
Getting up and down is getting more difficult as time goes by , with bad kneed and bad hips . :-(
How many inch-pounds do you torque the pan bolts to ?
Thanks , :-)
Wyr
God bless
Re: Transfer Pump - ATF change - PS [Re: WyrTwister] #4467880
07/23/17 09:33 AM
07/23/17 09:33 AM
Canada
Canada
Thanks , :-)
LOL! Good point on hips and knees gettin' up and down! Right now for me that's still a little exercise!
On 4T65E pan bolts torque is 100 inch/Lb - w/o big power tools or you'll go over and may strip
out threads. I cheat a little with a small D cell nicad power screw driver as a nut runner up
to last 1-2 turns, final torque with vintage dial indicating mini torque wrench.
I run the car up on ramps then use jacks to lift the body higher for more elbow room under the car!
