Just to start with my bypass filter is about $40 a piece and the oil I'm running is $23.40 a gallon. Ebp120 probably holds a gallon
I'm only half way serious here..... when it's time to change the oil (11 gallons)and i do not want to change the bypass filter , is there any way you can think of The Purge the old oil out of the filter.
I think flushing it with clean oil would be a waste partially because it wouldn't be clean in Old out I would think it would mix,using air psi would damage the filter possibly, unscrewing it and draining it will probably ruin the gasket (could get replacement oring)
This has been on my brain for a few days bc I think I may have to change the oil around 45k...just a guess
