New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Sludge and Facebook's infinite wisdom
by RDY4WAR. 03/24/19 02:05 PM
Gear lube 75W90 Synthetic GM# 88900401
by rcbob. 03/24/19 01:47 PM
Rislone Rebates
by Nickdfresh. 03/24/19 01:42 PM
IndyCar Classic at COTA
by bdcardinal. 03/24/19 12:29 PM
STP 500 at Martinsville
by bdcardinal. 03/24/19 12:27 PM
Source For Microfiber Towels
by Wrenchturner44. 03/24/19 12:26 PM
SUPREME C3-X SYNTHETIC 5W-30
by 21Rouge. 03/24/19 12:17 PM
Jcountry, CMichael, dude59, Petrolhead, stp
67608 Registered Users
107 registered members (ArrestMeRedZ, addyguy, 2004tdigls, arowbat, 2002 Maxima SE, 10 invisible), 2,213 guests, and 64 spiders.
Topics286,351
Posts4,906,907
Members67,608
Most Online2,967
Mar 10th, 2019
Dumb question I've been thinking about a while #4466643
07/21/17 08:33 PM
07/21/17 08:33 PM
Sav ga
NStuart Offline OP
NStuart  Offline OP
Sav ga
Just to start with my bypass filter is about $40 a piece and the oil I'm running is $23.40 a gallon. Ebp120 probably holds a gallon
I'm only half way serious here..... when it's time to change the oil (11 gallons)and i do not want to change the bypass filter , is there any way you can think of The Purge the old oil out of the filter.
I think flushing it with clean oil would be a waste partially because it wouldn't be clean in Old out I would think it would mix,using air psi would damage the filter possibly, unscrewing it and draining it will probably ruin the gasket (could get replacement oring)
This has been on my brain for a few days bc I think I may have to change the oil around 45k...just a guess
Detroit14l 1m75k mi bp schaffer9k 30k oil
96 ram 5.9 gas 80k built tranny 5k m1
85 cj7 4.2 performance build. Schaeffer 9000
08 cbr600rr graffiti. T6
08 husky sm610 t6
Re: Dumb question I've been thinking about a while [Re: NStuart] #4466648
07/21/17 08:36 PM
07/21/17 08:36 PM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
The filter should become better at filtering as it gets loaded up. Either change the filter or don't; please don't play games with it because its protecting expensive mission critical equipment.
too many cars and oil combinations to list in 150 characters or less
Re: Dumb question I've been thinking about a while [Re: NStuart] #4466651
07/21/17 08:39 PM
07/21/17 08:39 PM
Sav ga
NStuart Offline OP
NStuart  Offline OP
Sav ga
The question is more along the lines of getting old oil out of it, for example gravity feeding through the in side. ( its,more,of a tongue in cheek bitog anal question)
08 husky sm610 t6
Re: Dumb question I've been thinking about a while [Re: NStuart] #4466652
07/21/17 08:40 PM
07/21/17 08:40 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
Leave the bypass filter alone.
What's inside is still typically good oil, and besides - -
your engine probably traps almost that much in all the "nooks and crannies".
Re: Dumb question I've been thinking about a while [Re: NStuart] #4466655
07/21/17 08:41 PM
07/21/17 08:41 PM
Sav ga
NStuart Offline OP
NStuart  Offline OP
Sav ga
I was told by someone that it holds two gallons between the cooler and somewhere else
08 husky sm610 t6
Re: Dumb question I've been thinking about a while [Re: NStuart] #4466676
07/21/17 08:59 PM
07/21/17 08:59 PM
Canada
i_hate_autofraud Offline
Canada
I like knowing that at an OCI I can get all the old oil out, I see no harm in screwing off the Bypass filter, draining it and putting it back on.
If you want, you can refill it with new oil to reduce the dry start if the oil pump has to refill a totally empty bypass system including the hoses.
Re: Dumb question I've been thinking about a while [Re: NStuart] #4466693
07/21/17 09:13 PM
07/21/17 09:13 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
just drain the engine oil.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Dumb question I've been thinking about a while [Re: i_hate_autofraud] #4466734
07/21/17 09:55 PM
07/21/17 09:55 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
I do not think reseating the filter is a good idea after draining it. Change the filter or leave it alone.
2015 Ford F250 w/Powerstroke
Re: Dumb question I've been thinking about a while [Re: NStuart] #4466833
07/22/17 01:37 AM
07/22/17 01:37 AM
Midwest, Illinois
beanoil Online content
beanoil  Online Content
Midwest, Illinois
Schaeffer 9k is 23.50 a gallon? Get every mile out of it you can!
I'd leave the bypass alone. With an 11 gallon sump, even 2 gallons isn't going to do any harm.
And for bypass, this is the exact reason I like replaceable cartridges.
I can swap a new cartridge into my Racor LFS for about 12. The only old oil left is in the lines.
I'm doing 5k OCI, the bypass gets changed every 10K.
beanoil: Tough under heat, real dirty afterwards.
Re: Dumb question I've been thinking about a while [Re: beanoil] #4467002
07/22/17 10:04 AM
07/22/17 10:04 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Why are you running a bypass?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Dumb question I've been thinking about a while [Re: beanoil] #4467249
07/22/17 04:09 PM
07/22/17 04:09 PM
Sav ga
NStuart Offline OP
NStuart  Offline OP
Sav ga
Tell me more about this racor unit .I about to put a bypass on on my 5.9 magnum .I don't really care about the cost,I will be keeping this truck until the motor rots off the frame. Right now it has 85 k on a 1996 model. Iv been considered a frantz, at 5k with mobile one the uoa isn't very impressive
08 husky sm610 t6
Re: Dumb question I've been thinking about a while [Re: NStuart] #4468412
07/23/17 09:07 PM
07/23/17 09:07 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
What are you trying to achieve by installing a bypass filter?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Dumb question I've been thinking about a while [Re: NStuart] #4468611
07/24/17 06:08 AM
07/24/17 06:08 AM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
Please don't " ... just a guess ..." your way into extended OCIs! You should be doing UOAs at predetermined intervals.
Sure, you could remove the BP element and drain it. I think you should do it, but not because it's warranted. Rather, I think it's silly but it may well be the only way to convince you. Some folks just have to go down a road to find the dead-end themselves. Run a few UOAs both ways; see if you can find out if it makes a difference. I HIGHLY suspect you'll not be able to tell.
Regarding your truck; it's 21 years old, but only has 85k miles on it? And you're considering a BP on it?
You are correct; it will rot away far sooner than the engine will die.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Dumb question I've been thinking about a while [Re: NStuart] #4485596
08/11/17 10:35 AM
08/11/17 10:35 AM
California
Powerhaze Offline
Powerhaze  Offline
California
In my opinion, it's the clean oil you want to keep, not the contaminated oil filter element. I run a Racor ABS10300 and elements are about the same cost. I sample the oil and when the time comes I replace the BP element, top off the oil and go on my way. One person posted that a filter works better as it gets plugged, true up to a point but moisture will over come, (saturate) the cellulose and eventually pass where solids will stay.
Power Haze - 2011 Ram 6.7 - Racor Bypass Oil Cleaner
