Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Hyundai extended my warranty
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
12-14-18 only! Irwin vise @ Menards. $99.99
by Kruse. 12/14/18 06:01 PM
10" Subwoofer - $6.52 Each
by Greg L. 12/14/18 05:31 PM
Finding 507.00 spec oil
by sloinker. 12/14/18 05:31 PM
New Tires for the Old Chevy!
by dogememe. 12/14/18 05:09 PM
Back to Basics II
by MolaKule. 12/14/18 04:31 PM
"SG(+)" 15w40 or better oil 1987 BBC 454
by F239141. 12/14/18 03:52 PM
NEKGuy, Deltafaatl, wsalopek, jcr1293, maxwellk
66684 Registered Users
24 registered members (Black_Thunder, anndel, BigRich954, berlyn, bowtie4by, 2 invisible), 736 guests, and 37 spiders.
Topics295,091
Posts4,927,659
Members66,684
Most Online2,553
Oct 27th, 2018
need help added old bottle of Schaeffers 132 and #4466251
07/21/17 01:25 PM
07/21/17 01:25 PM
Honolulu, HI
[RT] ProjUltraZ Offline OP
Honolulu, HI
Found an unopened bottle of Schaeffers 132 and wanted to try it. it might be from 2010 tho. it was thicker than honey, kinda like that STP stuff from the 80s. No it was like blue goop. took several min to clear a narrow funnel. Black bottle was stored indoors in a box no sunlight and not deformed. So thick i only added 40% of the bottle. it says add the whole pint to 94 Camaro Z28
First drive, quieter but oil pressure is remaining high for 6 or 7 min, like cold start pressure, not going down. So i came home and shut down after only 7 min. Ambient 85F.
my water temp gauge sensor is not working, have to replace. i'm worried about blocked oil passages. has this happened to anyone?
did it thicken too much or interact with the Valv max life 10w-30 in there? thanks
Re: need help added old bottle of Schaeffers 132 and [Re: [RT] ProjUltraZ] #4466345
07/21/17 02:55 PM
07/21/17 02:55 PM
Honolulu, HI
Honolulu, HI
i found some threads that say its thick, i'll try a short drive now. oil used to reach near operating pressure in 15 min city driving
Re: need help added old bottle of Schaeffers 132 and [Re: [RT] ProjUltraZ] #4466348
07/21/17 02:56 PM
07/21/17 02:56 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
7 mins is not long enough to mix up the goop.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: need help added old bottle of Schaeffers 132 and [Re: [RT] ProjUltraZ] #4466359
07/21/17 03:06 PM
07/21/17 03:06 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Sounds like something you'd just add a Little "bit" (Like a tablespoon or so)
Re: need help added old bottle of Schaeffers 132 and [Re: [RT] ProjUltraZ] #4466434
07/21/17 04:14 PM
07/21/17 04:14 PM
NY
demarpaint Offline
demarpaint  Offline
NY
No worries, the product has a great reputation, especially in older oil burning engines.
God Bless Our Troops
Re: need help added old bottle of Schaeffers 132 and [Re: [RT] ProjUltraZ] #4466559
07/21/17 06:13 PM
07/21/17 06:13 PM
Honolulu, HI
Honolulu, HI
It finally reached oper idle pressure after 20 min or so. Had some valvetrain noise seems quieter. I was paranoid w/o coolant temp working. thanks
Re: need help added old bottle of Schaeffers 132 and [Re: [RT] ProjUltraZ] #4466586
07/21/17 06:46 PM
07/21/17 06:46 PM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Sounds like it was moly additive. Its super slippery. A form of it is still available.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: need help added old bottle of Schaeffers 132 and [Re: [RT] ProjUltraZ] #4467289
07/22/17 04:12 PM
07/22/17 04:12 PM
Michigan
Oil_Flunky Offline
Oil_Flunky  Offline
Michigan
132 is good stuff you're fine with the amount you added. Run it. smile
Oil, you need it. Oil snobbery, you don't need it.
Re: need help added old bottle of Schaeffers 132 and [Re: [RT] ProjUltraZ] #4467292
07/22/17 04:14 PM
07/22/17 04:14 PM
out there
spasm3 Offline
spasm3  Offline
out there
It has antimony , an antiwear additive. I use it mixed with oil for installing piston rings, and lubing the cylinder walls during rebuild.
13 elantra 72k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 7300 miles m1 0w30
Re: need help added old bottle of Schaeffers 132 and [Re: [RT] ProjUltraZ] #4467352
07/22/17 05:26 PM
07/22/17 05:26 PM
Middlesex County CT
simple_gifts Offline
Middlesex County CT
No issues; I use a whole bottle in my 4qt sump in my echo and I'm running 40 weight oil.
2004 Prius; 102K; ASL
2007 Yaris 78K 0w-40 Castrol
2006 B2300;132K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: need help added old bottle of Schaeffers 132 and [Re: [RT] ProjUltraZ] #4516274
09/14/17 03:15 PM
09/14/17 03:15 PM
Honolulu, HI
Honolulu, HI
7 weeks later (but only 400 miles) the engine is running smoother than a long time. Hot idle oil pressure looks about 21 or 22 psi vs 18 or 19 before with 5W-30 or 10W-30 and takes 5 or 10 min longer to reach. I think protection has been increased. 40 to 50% of the 132 pint only, still have the rest. and I fixed my water temp gauge
