Welcome to Dusseldorf... err... Edinburgh.
by Quattro Pete. 03/25/19 01:07 PM
1NZ-FE Under Valve Cover - 280,000 Miles
by kschachn. 03/25/19 12:44 PM
Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
135 registered members (4WD, AndyB, 64bawagon, 2009Edge, 240_Ed, 2015_PSD, 11 invisible), 2,178 guests, and 68 spiders.
Topics286,399
Posts4,907,622
Members67,614
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Fully Synthetic with high levels of zinc? #4466150
07/21/17 12:58 PM
07/21/17 12:58 PM
Florida
lawnguy Online content OP
lawnguy  Online Content OP
Florida
I know this post should prob be in the lawn mower section,but I'm wonder if the people in this section have more knowledge regarding this.
I know royal purple offers the hps oil that's high in zinc,but are there any others that are available,and cost less than the $10 royal puple qt bottles?
Re: Fully Synthetic with high levels of zinc? [Re: lawnguy] #4466161
07/21/17 01:08 PM
07/21/17 01:08 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
You mention lawn mowers, so I assume you're thinking about OPE use. I would suggest looking at some Heavy Duty Diesel Oils like Shell Rotella T6 5W40 (great choice for OPE). Here's a virgin oil analysis:
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2566898
Also possibly worth noting, I believe T6 recently removed the Gasoline spec SN from the labeling, which technically disqualifies it from use according to most OPE engine manuals, but they have said that the formulations have not changed. I personally will keep using T6 in my OPE and motorcycles.
https://bobistheoilguy.com/forums/ubbthr...e_r#Post4465518
Re: Fully Synthetic with high levels of zinc? [Re: lawnguy] #4466167
07/21/17 01:12 PM
07/21/17 01:12 PM
Florida
Florida
forgive me but what does ope mean?
Re: Fully Synthetic with high levels of zinc? [Re: lawnguy] #4466173
07/21/17 01:15 PM
07/21/17 01:15 PM
Great Lakes
Quattro Pete Offline
Great Lakes
Outdoor Power Equipment
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Fully Synthetic with high levels of zinc? [Re: lawnguy] #4466174
07/21/17 01:17 PM
07/21/17 01:17 PM
Florida
Florida
I run a commercial mower in severe heat in florida everyday for many many hrs per day
Re: Fully Synthetic with high levels of zinc? [Re: lawnguy] #4466177
07/21/17 01:20 PM
07/21/17 01:20 PM
Herndon, VA
btanchors Offline
btanchors  Offline
Herndon, VA
I would look at Amsoil Z-Rod 10W-30. It's fully synthetic and high in zinc. As an added bonus, it has a high amount of rust inhibitor, so that when your equipment is in storage over the winter, it's not as likely to rust internally. But it's probably not much cheaper than the Royal Purple unless you buy it in bulk.
Re: Fully Synthetic with high levels of zinc? [Re: lawnguy] #4466183
07/21/17 01:24 PM
07/21/17 01:24 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
In that climate and use, I may consider not bothering with a synthetic. I'd use whatever is the cheapest 15W40 HDEO (Rotella, Delo, Delvac). If you want to run a full synthetic, any of the above brands will still work, although, I don't know what you would gain (maybe longer oil change intervals? lighter wallet?).
Re: Fully Synthetic with high levels of zinc? [Re: lawnguy] #4466194
07/21/17 01:34 PM
07/21/17 01:34 PM
Florida
Florida
Re: Fully Synthetic with high levels of zinc? [Re: lawnguy] #4466196
07/21/17 01:38 PM
07/21/17 01:38 PM
Upper Midwest
kschachn Online content
kschachn  Online Content
Upper Midwest
Using OPE in Florida for long duration, aren't you more worried about HTHS than zinc? Does the amount of zinc even matter to that engine?
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Fully Synthetic with high levels of zinc? [Re: lawnguy] #4466207
07/21/17 01:44 PM
07/21/17 01:44 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
Not synthetic but I think this has the most zinc of any oil on the market.
http://www.buyracingparts.com/lubricants/brad-penn-30w-break-in-oil---case-of-12.html
Another option might be Mobil1 VTWin 20w50 which I recall having high zddp levels.
Re: Fully Synthetic with high levels of zinc? [Re: lawnguy] #4466226
07/21/17 02:07 PM
07/21/17 02:07 PM
MD
AirgunSavant Offline
MD
I put about 15 hrs this week in high 90's F with extreme humidity and no breeze.
I got the oil covered and I use gasoline additives per the makers advice.
I started to wonder if I should up the octane in the gas to premium.
On the oil- I don't like 10w30 here. I'm using 15w50 FS but I have seen T6 hold up to the worst of the worst.
if I didn't have a stash of other oil I'd go with that.
Re: Fully Synthetic with high levels of zinc? [Re: lawnguy] #4466235
07/21/17 02:13 PM
07/21/17 02:13 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
Nice choice, I haven't seen a VOA of the 15W40 since they renamed it to T4, but the old triple protection does:
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1056852
And here's a VOA for a 10W30 T4 that also has a decent dose of zinc:
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4304492/Rotella_t4_10w30
Re: Fully Synthetic with high levels of zinc? [Re: lawnguy] #4466268
07/21/17 02:53 PM
07/21/17 02:53 PM
Florida
Florida
I think I might have found something really good at the best price possible? Your thoughts ?????
https://www.walmart.com/ip/Shell-Rotella-T6-5W-40-Heavy-Duty-Engine-Oil-1-qt/763797918#about-item
Re: Fully Synthetic with high levels of zinc? [Re: lawnguy] #4466279
07/21/17 03:01 PM
07/21/17 03:01 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
Another good choice. But, buy it in the gallon size! https://www.walmart.com/ip/Shell-Rotella-T6-5W-40-Diesel-Motor-Oil-1-gal/102646780
Other options:
https://www.walmart.com/ip/Chevron-Delo-400-Low-Emission-Synthetic-5W40-Motor-Oil-1-gal/20896087
https://www.walmart.com/ip/Mobil-Delvac-1-ESP-5W40-Gal/167510327
All of those oils above and all of them listed above will work and work well.
Re: Fully Synthetic with high levels of zinc? [Re: lawnguy] #4466289
07/21/17 03:14 PM
07/21/17 03:14 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I use Mobil 1 or Castrol edge 0w40 in all 4 stroke OPE engines, both have over 1100 ppm zinc. Snowblowers start first pull in zero degree weather (I dont even bother with the electric starter) and lawnmowers do well with the 0w40 in summer heat.
For oils with low zinc in the 700-800 ppm range use 1 oz of this per qt of oil to bring it up to about 1100-1200 ppm.
https://rislone.com/product/3x-concentrated-engine-oil-supplement-with-zinc-treatment/
Page 1 of 3 1 2 3
