2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
99 registered members (64bawagon, 69GTX, 97f150, 97prizm, 65convertible, 9 invisible), 1,649 guests, and 62 spiders.
Topics286,228
Posts4,904,674
Members67,582
Most Online2,967
Mar 10th, 2019
Quickie lube reviews, you can't make this stuff up #4466045
07/21/17 11:13 AM
07/21/17 11:13 AM
Northern Arizona
funflyer Offline OP
funflyer  Offline OP
Northern Arizona
After reading a BITOG post about the horrors of quick lube places, I found myself reading actual reviews from customers. It was like a good book that you just can't put down. Here are some of the actual review quotes that had me cracking up or scratching my head.
"So I went to Valvoline about a month ago for a oil change and employee didn't put on my oil filter so I left, got home. I was home for about a hour. I was leaving my home to pick up my boyfriend from work and my car broke down. It made a loud noise, started smoking and shut off on the Rankin bridge."
"Went here for the first time for an oil change and got my tires rotated on the spot. Not long after, my car made noises like it was falling apart. They had rotated my tires but did not align them. Ended up costing me $500+ to fixed."
"He now has a blown engine which is costing almost $8000.00 due to the fact that the Valvoline location in Kyle, TX has been putting Pennzoil in his truck & it finally clogged the oil pump which caused the engine to seize up. I, myself, had the oil analyzed to find out what kind of oil it was & it came back that the vehicle had Pennzoil in the truck."
"I took my 1996 Jimmy for the flushing and then make damage to the heater core cuz they put too much pressure is the throughno."
"I went to that elaine to oil change and also tires rotated, wanted a passionate take it back because there was noise coming from my phone and then and they thought it was the tire."
"Tranny went in my explorer due to Valvoline changing the transmission fluid. About a month later my transmission went. Been told don't EVER change the transmission fluid in a older car. If it's not broke don't fix it."
"I brought my vehicle into the location in Minneapolis, on Lake St. for what I thought would be a quick oil change. Unfortunately, once the guy was done, as I left, my vehicle shut off in the middle of the street, then proceeded to jerk once I tried to turn it back on. I went back so that they could fix it and he told me there was a hole in my gasket."
"She called me and said that they told her that the motor had to be flushed and as an ex-state certified auto and diesel mechanic, I knew this was a bunch of [censored]. I told her not to do it but she said they already started. The only way to clean a motor is by taking it apart, boring out the heads and putting new pistons and rings and new seals in it. You cannot clean a motor with a cleaner. It loosens the grime and can make it worse and that's gospel"
"Valvoline Oil Change Debacle - I had an oil change and inspection. They stripped a lug nut and when they pulled the parking brake lever up, it stuck."
"Do not allow anyone to install synthetic oil in any car after 40,000 or 50,000 miles. It will cause leaks and expose other warn parts."
"I asked why I did not hear the grease gun go off. I was told by the man taking care of me that the grease guns were new and would not work on my car. I told him I was to get a grease job for what I paid and I better get it ."
"I just found out my lube holder was broken because of EZ Lube. I went to change oil at another company today. People told me that my lube holder will need to be changed because the guy in EZ Lube did not carefully handle it."
"It turned out, they either, did not change the oil, or left a dirty filter on, and did not lube the parts they were paid to lube. This caused a blown engine, and both sides in the front end broke"
"Then he tried to tell me that my battery needed to be replaced. I said no, then called me back out to show me my hood filter needed to be replaced"
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
Re: Quickie lube reviews, you can't make this stuff up [Re: funflyer] #4466061
07/21/17 11:34 AM
07/21/17 11:34 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Some of those reviews are super brilliant.
Re: Quickie lube reviews, you can't make this stuff up [Re: funflyer] #4466071
07/21/17 11:39 AM
07/21/17 11:39 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Remember, half the population is below average intelligence.
(yes I know it is actually "median" intelligence, but I have to simplify it for the simple folk)
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Quickie lube reviews, you can't make this stuff up [Re: funflyer] #4466072
07/21/17 11:39 AM
07/21/17 11:39 AM
Spring,Texas
Bud_One Offline
Bud_One  Offline
Spring,Texas
Hood filter ??
LOL LOL
16 Civic-QSUD 0W-20, XG7317
14 Civic-Idemitsu Zepro 0W-20, XG7317
05 Chevy 2500HD-QSUD 10W-30, XG3675
97 Accord Wagon-Havoline ProDS 10W-30, TG7317
Re: Quickie lube reviews, you can't make this stuff up [Re: mightymousetech] #4466074
07/21/17 11:40 AM
07/21/17 11:40 AM
Illinois
javacontour Offline
javacontour  Offline
Illinois
I have shared this before and you may or may not be shocked by the number of people who are offended by this statement.
However, it's my belief that if you understand it, you are probably not in the bottom half...
network down, IP packets delivered via UPS -BOFH
Re: Quickie lube reviews, you can't make this stuff up [Re: mightymousetech] #4466076
07/21/17 11:43 AM
07/21/17 11:43 AM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Amen. And they breed rapidly.
Thick vs Thin test: 15k / 43k miles complete
Re: Quickie lube reviews, you can't make this stuff up [Re: funflyer] #4466078
07/21/17 11:43 AM
07/21/17 11:43 AM
Columbus Nebraska
old1 Offline
old1  Offline
Columbus Nebraska
Boy, reviews like those sure prove the old saying that no mater what part of a vehicle you work on, the next thing that goes wrong will be your fault.
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 15/40 Delo
1929 ford model A No filters, and 15/40 oil
Re: Quickie lube reviews, you can't make this stuff up [Re: funflyer] #4466081
07/21/17 11:47 AM
07/21/17 11:47 AM
Utah
CKN Offline
CKN  Offline
Utah
Another thread knocking quick lubes....must be hard to find something new to post today.......
Re: Quickie lube reviews, you can't make this stuff up [Re: funflyer] #4466086
07/21/17 11:53 AM
07/21/17 11:53 AM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
Yup, you gotta handle your lube holder carefully. Everyone knows that. Jeez.
Re: Quickie lube reviews, you can't make this stuff up [Re: funflyer] #4466149
07/21/17 12:58 PM
07/21/17 12:58 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Those people vote.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Quickie lube reviews, you can't make this stuff up [Re: CKN] #4466158
07/21/17 01:04 PM
07/21/17 01:04 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
It's really not knocking quick lubes. It's knocking people who go to quick lubes and blame them publicly for things that have nothing to do with what the quick lube did or didn't do.
Plain, simple Garak.
Re: Quickie lube reviews, you can't make this stuff up [Re: funflyer] #4466166
07/21/17 01:11 PM
07/21/17 01:11 PM
Ontario, Canada
Ontario, Canada
I have a friend that manages a group of quick lubes. I wish I could post some of his stories here. Surprising how many of these stories end up in court. Quite often gives the judge a good laugh.
Mighty Mouse Tech
Re: Quickie lube reviews, you can't make this stuff up [Re: javacontour] #4466172
07/21/17 01:15 PM
07/21/17 01:15 PM
Guilford, CT
exranger06 Offline
exranger06  Offline
Guilford, CT
I understand it, but I realize it's not true. That's not how averages work.
2006 Ford Ranger Sport
1992 Honda Accord EX
2013 Toyota Sienna XLE AWD
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: Quickie lube reviews, you can't make this stuff up [Re: exranger06] #4466176
07/21/17 01:20 PM
07/21/17 01:20 PM
Ontario, Canada
Ontario, Canada
If you had read the full quote.
Mighty Mouse Tech
Re: Quickie lube reviews, you can't make this stuff up [Re: CKN] #4466178
07/21/17 01:21 PM
07/21/17 01:21 PM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
The ONE time I told someone to use a quick lube because I couldn't lube her car myself at that time, they BONED it and almost killed her car, and endangered her personally. (more details in my thread in general topics)
So yeah, I had a legitimate beef. And I never aired that beef before today, so to speak.
too many cars and oil combinations to list in 150 characters or less
