Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
104 registered members (53' Stude, addyguy, 240_Ed, 38Chevy454, 77GrandPrix, Aero540T, 16 invisible), 2,098 guests, and 69 spiders.
Topics286,203
Posts4,904,136
Members67,576
Most Online2,967
Mar 10th, 2019
Mobil Super 5K 5W-20, 2015 Pentastar, 6598 miles #4465987
07/21/17 10:08 AM
07/21/17 10:08 AM
Virginia
bigt61 Offline OP
bigt61  Offline OP
Virginia
2015 Chrysler 200S with the Pentastar V6, 6598 miles over a 7 month period starting early December. The car sees mostly heavy stop and go driving on the DC/N VA/MD beltway where the 15 mile trip to work can routinely take 1-2 hours. This run had one round trip to Charlotte. (maybe 1000 miles) OLM was at 26% at time of change. Sump holds 6 quarts and a 5 qt jug of MS5K 5W-20 was used along with one quart of MS5K 5W-30. Chrysler allows for either 5W-20 or 30 in this application. No make up oil added. This was the 2nd run on the Wix oil filter, which looked fine and had a total of 15,252 miles on it. The same oil type & a new Wix filter was installed at change. We changed the oil early because the car was leaving for it's new permanent home in Texas. The commute time there will now be drastically shorter.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
Re: Mobil Super 5K 5W-20, 2015 Pentastar, 6598 miles [Re: bigt61] #4466022
07/21/17 10:48 AM
07/21/17 10:48 AM
New York
pbm Offline
pbm  Offline
New York
Was that a Wix Gold, Platinum or Silver?
15K on a plain Wix with those results are impressive?
'Journalism is Dead'
Re: Mobil Super 5K 5W-20, 2015 Pentastar, 6598 miles [Re: pbm] #4466031
07/21/17 10:56 AM
07/21/17 10:56 AM
Virginia
bigt61 Offline OP
bigt61  Offline OP
Virginia
It was the least expensive Wix that fit the car on RockAuto. Part # WL10010
70 Camaro 5.7L 59k
Re: Mobil Super 5K 5W-20, 2015 Pentastar, 6598 miles [Re: bigt61] #4466050
07/21/17 11:21 AM
07/21/17 11:21 AM
MN
oil_film_movies Offline
MN
Mobil conventional has a unique formula. Its the only combination of Titanium (like Castrol Edge) and Sodium (like Valvoline, Shaeffers) I've seen.
I like how the NAPA people call sodium a "contaminant"....
Wondering why Mobil and most other companies don't just use the OLOA 55516 Oronite detergent-inhibitor (DI) package blending methods: Use the same DI package for every oil you sell, conventional, blend, synthetic, and then just blend with different grades of oil to get the specs you need.
For example, Oronite says OLOA 55516, when mixed with GroupII oil becomes an SN/GF-5 oil (Ford, Chrysler, Kia, Toyota, etc.).
Blend with GroupII/GroupIII, and its a dexos1 oil.
Blend with GroupIII, and you have a marketable "full-synthetic" that is dexos1, A5/B5, etc. motor oil.
Maybe tweak with some extra anti-oxidants and you have a "15,000 Mile Oil".
Tweak with a bit more seal conditioners and you have a "High Mileage Oil".
Could be its timing, since dexos1 Gen2 is just coming out while SN has been around for a while.
When GF-6 finally comes out (1 or 2 years), that would be a good time for oil companies to hit the reset button and have more common DI packages to cover all requirements of the marketplace, just blending in different grades of base oils to cheapen or enhance the final product.
Re: Mobil Super 5K 5W-20, 2015 Pentastar, 6598 miles [Re: bigt61] #4466058
07/21/17 11:30 AM
07/21/17 11:30 AM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
Good oil, good filter, good motor, good results, great thread, and THANKS for sharing.
too many cars and oil combinations to list in 150 characters or less
Re: Mobil Super 5K 5W-20, 2015 Pentastar, 6598 miles [Re: bigt61] #4466059
07/21/17 11:30 AM
07/21/17 11:30 AM
MN
MN
Your 200S V6 is a hot-rod. They put a 295 hp engine in a 3,500 lb car. 5.7 seconds 0-60, only a half second off the 2017 Camaro V6 faster time, but thats a sports car. Hot sleeper there.
Re: Mobil Super 5K 5W-20, 2015 Pentastar, 6598 miles [Re: L_Sludger] #4466311
07/21/17 03:29 PM
07/21/17 03:29 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
YEP!!
Was that the $1.40 WIX?
I get those from Rockauto labeled as all kinds of things,
But as long as it says "Affinia... Gastonia, NC" I know it's a WIX! thumbsup
Re: Mobil Super 5K 5W-20, 2015 Pentastar, 6598 miles [Re: bigt61] #4466886
07/22/17 06:58 AM
07/22/17 06:58 AM
Virginia
bigt61 Offline OP
bigt61  Offline OP
Virginia
It came in a Wix box - RockAuto currently sells it for $4.34.
70 Camaro 5.7L 59k
Re: Mobil Super 5K 5W-20, 2015 Pentastar, 6598 miles [Re: bigt61] #4467003
07/22/17 10:05 AM
07/22/17 10:05 AM
US
TheOilWizard Offline
US
I'm surprised how well the oil held up. Those engines must be easy on oil.
Re: Mobil Super 5K 5W-20, 2015 Pentastar, 6598 miles [Re: TheOilWizard] #4467010
07/22/17 10:10 AM
07/22/17 10:10 AM
Texas
4WD Offline
4WD  Offline
Texas
Maybe so - but it is a good conventional - BIL ran it 400k in 1500 GM V8 before the trans acted up - no engine problems ...
Re: Mobil Super 5K 5W-20, 2015 Pentastar, 6598 miles [Re: bigt61] #4467170
07/22/17 01:29 PM
07/22/17 01:29 PM
Michigan, USA
Bighorn2500 Offline
Bighorn2500  Offline
Michigan, USA
Good filter for the price, I get the same Wix WL10010 for $3.85 @ Discount Fleet Supply for the wife's Jeep Cherokee V-6. Can't beat it IMO.
2012 Ram 2500 SLT 6.7L Cummins 4x4
2015 Jeep Cherokee 3.2L Latitude 4x4
Re: Mobil Super 5K 5W-20, 2015 Pentastar, 6598 miles [Re: bigt61] #4469282
07/24/17 07:46 PM
07/24/17 07:46 PM
Tennessee
C4Dave Offline
C4Dave  Offline
Tennessee
Copper and iron look high.
