Boiler/baseboard valve corrosion
by wormwood1978. 01/18/19 09:24 AM
Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
79 registered members (Anduril, Astro14, Al, Alfred_B, 240_Ed, badduxx, 8 invisible), 1,968 guests, and 55 spiders.
Topics296,776
Posts4,958,680
Members66,969
Most Online2,577
Jan 14th, 2019
Class D Mini Amps #4465683
07/21/17 12:00 AM
07/21/17 12:00 AM
Under the hood
Carmudgeon Offline OP
Under the hood
Anyone using one of the Class D mini amps like the Alpine KTP-445? They seem to be popular with bike riders who can easily fit them inside fairings.
I'd like something with a little more oomph than my head unit provides, to provide better volume at highway speeds, but have neither the need nor inclination to go though the hassle to mount and install a full-sized amp.
Given the plethora of choices now available in the category, it looks like I'm not alone.
I've narrowed it down to the Alpine, or the Clarion XC-2410, which offer more adjustability than the Pioneer and Sony units.
Re: Class D Mini Amps [Re: Carmudgeon] #4465751
07/21/17 04:04 AM
07/21/17 04:04 AM
The Netherlands
Tommiee Offline
Tommiee  Offline
The Netherlands
I have experience with the Pioneer GM-D1004. I used it in my buddy's VW EOS with an aftermarket android radio that really sucked sound quality wise. the nice part about the pioneer is that you can choose to connect by RCA, that gives a massive bump in SQ. If you would use the speaker output ( most mini amps only offer speaker output as line in ) the already [censored] signal gets amplified, yes it will play louder, but it won't make it sound better.
I don't know if you are using a factory headunit or an aftermarket, that makes a difference because the OEM HU probably doesn't have RCA outputs.
It definately is easy to install, within an hour with the right tools. I do advise to run a extra 12v wire as a power source for the mini amp instead of using the std delivered iso adapter. It will take the power from thesame wire as the headunit then and the factory wire isn't made for these amp draw. for these small amps i suggest to use a fuse tapper like this:
[img:left]http://contentinfo.autozone.com/znetcs/product-info/en/US/bsm/BP-HHH-RP/image/3/[/img]
Seat Leon 2.0T FSI 2007 380HP / 370 lb ft
Petronas Syntium 7000 0W40 + LM Ceratec
Mahle Filter
Suzuki Alto 1.0 2011
Shell Helix Ultra 0W20
Re: Class D Mini Amps [Re: Carmudgeon] #4465802
07/21/17 05:39 AM
07/21/17 05:39 AM
Georgia
AVB Offline
AVB  Offline
Georgia
We installed a 500w mono Punch mini amp in my old bosses semi. I was a little underwhelmed, but for something so small and drawing such few amps it pushed a 10" sub ok. He said that he found the right setting to wake it up, but I don't think I ever heard it after that. I haven't thought to ask him how it has held up.
Re: Class D Mini Amps [Re: Carmudgeon] #4465901
07/21/17 07:51 AM
07/21/17 07:51 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
I though this was for home smile Ive been looking at SMSL Q5 pro stuff so its digital straight through to the speaker OUTS. No Class AB to be found. You guys talking tripath? Of just wave chopper power supplies?
2019 VW Jetta S,6M OCI#0 62mi-Castrol Edge Prof VW508+OE Filter; '17 Subaru Crosstrek CVT OC#5 37K mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Class D Mini Amps [Re: Carmudgeon] #4465972
07/21/17 08:56 AM
07/21/17 08:56 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Are your choices rain/weather resistant?
Re: Class D Mini Amps [Re: Carmudgeon] #4466077
07/21/17 10:43 AM
07/21/17 10:43 AM
Chicago, IL
EdwardC Online content
EdwardC  Online Content
Chicago, IL
I've been using a JL Audio XD400/4 for several years now in the car, amping the fronts and bridged to the small sub in the rear. It was perfect since it was small enough to fit under the passenger's seat. No problems at all since it was purchased in 2012. I'm no audiophile, but it sounds good enough for me.
Is this for a car or motorcycle? I think regardless of what you go with, it should be an upgrade over the HU's internal amp, especially if you're pushing aftermarket speakers. If you have an Alpine HU, the Alpine amp is an easy option.
Re: Class D Mini Amps [Re: Carmudgeon] #4466609
07/21/17 07:09 PM
07/21/17 07:09 PM
Under the hood
Under the hood
It's for a car with an aftermarket head unit, so I can feed it with RCA line level.
I'd just need to construct a short harness so I put it in the free space behind the center stack on top of the tunnel, and run a positive cable through the firewall to the positive jumper terminal, which is just on the other side. I think the factory radio harness could handle the lower draw models but it's tight, and not that much additional work to be assured of a proper power supply.
The Clarion is marine-rated, so it has no issues with weather. The Alpine isn't, but I don't think it's an issue, as lots of people put them in their cruisers.
Alpine was the first to market these, first as a PnP for their head units, then with a universal version. Pioneer, Sony, Clarion, and others have jumped in.
Feature comparison
What seems to be telling is that the Clarion has a 40 amp fuse, while the rest are 15 amp.
Re: Class D Mini Amps [Re: Carmudgeon] #4466630
07/21/17 07:23 PM
07/21/17 07:23 PM
Georgia
AVB Offline
AVB  Offline
Georgia
Yeah the Clarion would be my choice based on the specs. I don't think it will be working as hard as the others to make rated power.
Re: Class D Mini Amps [Re: ARCOgraphite] #4466646
07/21/17 07:35 PM
07/21/17 07:35 PM
Georgia
AVB Offline
AVB  Offline
Georgia
I don't know how these things work. I know the punch amp we used ran jacked up rail voltages.
Re: Class D Mini Amps [Re: Carmudgeon] #4468567
07/24/17 01:04 AM
07/24/17 01:04 AM
The Netherlands
Tommiee Offline
Tommiee  Offline
The Netherlands
How much power can the drivers (speakers) handle? The Clarion seems a wise choice, the only disadvantage is that it has the lowest S/N ratio, but i'll doubt you'll hear the difference in a non high end setup in a car.
I do have a higher end setup in my car ( ESX Vision Elite 6.2C MKII front components, Hertz Mille Pro 690.3 Rear ovals, powered by a Hertz EP4 amp ) and i do hear some slight noise when i listen to music with the engine off, and that annoys me..
For the clarion i would also run the wire directly from the battery, the 15 amps from the other systems would be fine from the fusebox. Make sure to use an inline fuse within a few inches of the battery
Mahle Filter
Re: Class D Mini Amps [Re: AVB] #4469940
07/25/17 10:27 AM
07/25/17 10:27 AM
N.H, U.S.A.
N.H, U.S.A.
Anything with big power in a car/boat, MC needs to jack up VOLTAGE, you cant make much RMS wattage with a 4ohm speaker with 14VDC.
Re: Class D Mini Amps [Re: Carmudgeon] #4469952
07/25/17 10:48 AM
07/25/17 10:48 AM
down in the park
Jetronic Offline
Jetronic  Offline
down in the park
Exactly. I suppose that's one reason Bose uses 2 ohm speakers in car systems
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus Prime 2 215/50R17 (front)
Pirelli P7 Cinturato 225/45R17 (rear)
Re: Class D Mini Amps [Re: Carmudgeon] #4470395
07/25/17 07:35 PM
07/25/17 07:35 PM
Georgia
AVB Offline
AVB  Offline
Georgia
Yes, but I was comparing voltage of traditional class AB & D amps with these newer mini amps that run even higher rail voltages to get comparable power in a smaller chassis. Rockford Fosgate calls it Boosted Rail Technology or BRT.
Re: Class D Mini Amps [Re: Carmudgeon] #4470547
07/25/17 11:36 PM
07/25/17 11:36 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
They must be using these modules with and an internal switching power supply:
https://www.infineon.com/dgdl/audio-modules.pdf?fileId=5546d462533600a40153568cd0312a7c
Scars remind us of where we have been, but do not have to dictate where we are going.
Re: Class D Mini Amps [Re: Carmudgeon] #4473061
07/28/17 12:26 PM
07/28/17 12:26 PM
Los Angeles, CA
razel Offline
razel  Offline
Los Angeles, CA
I don't have experience with those smaller ones, but I was interested in those Alpine power packs for the longest time. My issue was the additional hiss if you use the speaker level version. I am very familiar with class D amps in a car and recommend them highly. I settled on the Alpine PDX and JL Audio HDs. They're nearly a decade old design and I expect them to update it in the next few years... meaning you can pick them up cheap when that happens.
If you just want more volume, you'll need more than the 45watts max that those power packs provide. The best way to 'add' more volume is sound deadening via thin neoprene sheets in your doors and thicker open cell foam carpet padding over your wheel wells in the trunk. If there is room and it's safe, even under your dash near the firewall. Doubling your wattage is an increase of 3db. So a 3db reduction in your noise floor is 'equivalent' assuming you keep the volume knob in the same spot. That's not to mention the overall enjoyment you'll get from a quieter ride.
