Wrong ATF Fluid in my 07 Chevy Impala
by CM613. 12/14/18 08:39 AM
Hyundai motor oil
by pbm. 12/14/18 08:16 AM
Which Exhaust Manifold Should I Buy
by Miller88. 12/14/18 08:10 AM
Rotella T5 10w30 Ford 6.7L anyone?
by sw99. 12/14/18 07:49 AM
Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
captobvious, pgrkcs, 4Doors4Life, 780Ari, kayumb
66677 Registered Users
87 registered members (aquariuscsm, ArrestMeRedZ, aba4430, badduxx, Alfred_B, A310, 3 invisible), 1,283 guests, and 41 spiders.
Topics295,050
Posts4,926,876
Members66,677
Most Online2,553
Oct 27th, 2018
1982 th400 in rv with 10 year old fluid in it. #4465658
07/20/17 10:54 PM
07/20/17 10:54 PM
AZ
leroyd92 Offline OP
leroyd92  Offline OP
AZ
Is it safe to say i need to change this fluid and filter?
The rv has been used maybe 5/6 k in the last few years when it was brought back to life.
My real question is If you guys would add anything to the fresh atf to maybe condition it?
Its in a p30 chassis. 84k miles total
Supertech Junky
Re: 1982 th400 in rv with 10 year old fluid in it. [Re: leroyd92] #4465695
07/21/17 12:41 AM
07/21/17 12:41 AM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
No, if you do a fluid change and filter change just use a good quality fluid, no additives necessary.
It might not even need a fluid change, but it's probably not a bad idea.
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
Re: 1982 th400 in rv with 10 year old fluid in it. [Re: leroyd92] #4465968
07/21/17 08:54 AM
07/21/17 08:54 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
In a TH400, if the oil looks good and doesn't smell burnt, it's fine to leave it.
Re: 1982 th400 in rv with 10 year old fluid in it. [Re: leroyd92] #4466241
07/21/17 01:15 PM
07/21/17 01:15 PM
AZ
leroyd92 Offline OP
leroyd92  Offline OP
AZ
The fluid is clean and red.
I don't wanna do a swap if i don't have to. if i do end up doing it,i was going to collect the fluid and use it as upper cylinder lubricant ( its that clean )
Supertech Junky
Re: 1982 th400 in rv with 10 year old fluid in it. [Re: leroyd92] #4466606
07/21/17 07:04 PM
07/21/17 07:04 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
TH400's NEED the filter changed periodically!!! They are NOT screens.
I have seen my fare share of TH400's pulled into my shop on a hook with a wadded-up/clogged-up filter.
It's also a good time to replace the Suction Tube O-Ring & get all the brass out of the pan.
Use a Filtran Filter & a Farpak/Duroprene Fiber Pan Gasket, Torque the Filter hold down bolt & pan bolts to 96 Inch Pounds. Filter, O-ring, & Gasket
2001 Chevy Camaro L92/4L80E
Re: 1982 th400 in rv with 10 year old fluid in it. [Re: leroyd92] #4466818
07/21/17 11:11 PM
07/21/17 11:11 PM
AZ
leroyd92 Offline OP
leroyd92  Offline OP
AZ
Can you explain what makes the filter kit special? I bought a kit from oriley. Not sure if it has that oring but the filter and gasket look similar
Supertech Junky
Re: 1982 th400 in rv with 10 year old fluid in it. [Re: leroyd92] #4468268
07/23/17 05:16 PM
07/23/17 05:16 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
The filter in the link is (suppose to be) a Filtran filter, That's what GM/Hydramatic/Allison use from the factory.
The gasket is a fiber matrix gasket, It has to be kept flat during shipping/packaging....It cannot be folded up into a box, This is the reason auto part stores don't carry them.
GM started using this style gasket later in the TH400/3L80 production to eliminate leaks.
Re: 1982 th400 in rv with 10 year old fluid in it. [Re: clinebarger] #4469261
07/24/17 06:28 PM
07/24/17 06:28 PM
AZ
leroyd92 Offline OP
leroyd92  Offline OP
AZ
I returned my fk106 filter kit and bought that one.
I vividly remember selling my suburban 1 year after replacing the pan and the rubber seal was leaking/ cracked / split.
Supertech Junky
