When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
111 registered members (Anduril, 2015_PSD, 2009Edge, 2whlgeezer, andyd, 13 invisible), 2,072 guests, and 60 spiders.
Topics286,160
Posts4,903,325
Members67,569
Most Online2,967
Mar 10th, 2019
Rotella no longer gas engine rated? #4465518
07/20/17 09:26 PM
07/20/17 09:26 PM
Naperville, IL
wwillson Offline OP
Administrator
wwillson  Offline OP
Administrator
Naperville, IL
This is post made by the Rotella Team (BITOG user ChrisGuerrero) in the "Motorcycles, Boating, Small Engine, Aviation, Power Sports" forum as an answer to the question in the subject. I've also posted the answer here so that more of us can see Chris's response.
Quote:
Previously, heavy duty engine oil marketers could claim an API gasoline performance standard on their products if they met CJ-4 and the required performance tests for gasoline standards. Additionally, a waiver was granted for claims of API gasoline performance in cases where products did not meet the chemical restrictions for gasoline specifications (specifically phosphorous limits required for SN).
The recommended viscosity grades for modern gasoline engines are XW-20s and XW-30s. As such, this waiver process is being phased out. Heavy duty engine oils which are XW-30s (and which claim API CK-4 approval) cannot also claim API gasoline standards unless they meet the current phosphorous requirements/limits. The new fully synthetic Shell ROTELLA® T6 Multi-Vehicle 5W-30 is one such product that meets the performance requirements of API CK-4 as well as API SN and is formulated with 800 parts per million of phosphorous, which meets the API SN requirements.
While the industry waiver is still currently in existence for heavy duty engine oils that are XW-40’s, this remains in discussion to be addressed by the API in the near future. However, the Shell ROTELLA® brand has made the decision to remove API SN claims, regardless of viscosity, from our other products which do not meet the preferred low-phosphorous chemistry for gasoline engines. It is important to note that there is no change in formulation associated with this change. It simply means that Shell ROTELLA® products will no longer claim formal API SN approval for products other than our fully synthetic Shell ROTELLA® T6 Multi-Vehicle 5W-30 on labels, technical data sheets, rotella.com and marketing materials moving forward.
- The Shell Rotella Team
Re: Rotella no longer gas engine rated? [Re: wwillson] #4465523
07/20/17 09:29 PM
07/20/17 09:29 PM
out there
spasm3 Offline
spasm3  Offline
out there
Originally Posted By: wwillson
This is post made by the Rotella Team (BITOG user ChrisGuerrero) It is important to note that there is no change in formulation associated with this change. It simply means that Shell ROTELLA® products will no longer claim formal API SN approval for products other than our fully synthetic Shell ROTELLA® T6 Multi-Vehicle 5W-30 on labels, technical data sheets, rotella.com and marketing materials moving forward.
Thanks for posting that explanation Wayne!
Re: Rotella no longer gas engine rated? [Re: wwillson] #4465564
07/20/17 10:10 PM
07/20/17 10:10 PM
Where the wind comes sweepin'
Reddy45 Online shocked
Reddy45  Online Shocked
This is good news to me!
Thank you SOPUS for making a great diesel oil that us motorcycle owners can find readily at any store and has proven to be stout!
Re: Rotella no longer gas engine rated? [Re: wwillson] #4465583
07/20/17 10:24 PM
07/20/17 10:24 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
JASO MA is fit for use in gassers, having a pre requisite of api/acea/ilsac, so since they claimed that MA was ok, I never believed the claim that it was diesel only. But is reformulated, and is friendlier to catcons than the previous gas certified version. That's why I wouldn't want it over CJ/CI.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 106K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 40k Idemitsu 0w20, 57047
Re: Rotella no longer gas engine rated? [Re: wwillson] #4465617
07/20/17 11:03 PM
07/20/17 11:03 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
I've been saying it all along - MA means gas engines (99.9% of the time). So who needs API laugh
Re: Rotella no longer gas engine rated? [Re: wwillson] #4465632
07/20/17 11:16 PM
07/20/17 11:16 PM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
So when are we going to see diesel only shell rotella? Doesn't the CK-4 formula still have reduced ZDDP compared to CJ-4 or is that only because they made it SN certified?
I'll switch over to shell rotella from now on then. Maybe they realized how many people would buy it if they got rid of the gas certification.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Rotella no longer gas engine rated? [Re: BrocLuno] #4465709
07/21/17 02:51 AM
07/21/17 02:51 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
I agree, MA covers you for a petrol / gas engine.
Why don't they start claiming something like a Euro A3/B3 spec with less restrictions on Phos and avoid the API Sx thing altogether ?
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Rotella no longer gas engine rated? [Re: motor_oil_madman] #4465857
07/21/17 08:09 AM
07/21/17 08:09 AM
CK-4 does not limit ZDDP. I know for certain that the T4 15W40 CK4 is just as stout as the old CJ-4 stuff.
Re: Rotella no longer gas engine rated? [Re: wwillson] #4465885
07/21/17 08:38 AM
07/21/17 08:38 AM
Cincinnati, OH, USA
bullwinkle Online confused
bullwinkle  Online Confused
Cincinnati, OH, USA
My reading of it is that the CK-4/SN 30 weight Rotella might not be the greatest oil to use in a diesel either, 800 PPM phosphorus is weak! 40 weight is probably still 1000-1200 PPM, it's likely OK.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Rotella no longer gas engine rated? [Re: wwillson] #4465921
07/21/17 09:15 AM
07/21/17 09:15 AM
Michigan
Building3 Offline
Building3  Offline
Michigan
Chris: some of us here use the Shell Rotella (for instance I use T4) in our classic and muscle cars which need higher levels of zinc and phosphorous. So, does this mean that Rotella T5 and T4 still have more than 1000 PPM of zinc and phosphorous, and that only the T6 is below that level? Thanks for the clarification.
Re: Rotella no longer gas engine rated? [Re: BrocLuno] #4465994
07/21/17 10:16 AM
07/21/17 10:16 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Ed Hackett and I said much the same thing. If it's E7, E9 now and was E7, E9 before, and we weren't worried about using it in a gasser then, we really shouldn't now, unless we're hung up on a specific new car warranty requirement, and there aren't a lot of vehicles calling for 5w-40 in SM or SM, with nothing beyond that.
Of course, API gasoline certification or even simply claims to be "suitable for" can be helpful. Someone wouldn't want to put a locomotive oil or certain marine lubes in a gasser, but those won't be E7, E9 or anything like that.
This is one time I wish the oil companies would adopt the "suitable for use" wording, but I don't think they'll be jumping on that, given that the big three all have a 5w-40 in SN already, with varying degrees of availability and convenience.
Plain, simple Garak.
Re: Rotella no longer gas engine rated? [Re: Building3] #4466062
07/21/17 11:34 AM
07/21/17 11:34 AM
New York
jeff78 Offline
jeff78  Offline
New York
He's saying only the Rotellas certified for SN have the lower level of phosphorous - and as of now that's only the 5W-30 T6 Multi-Vehicle. The 5W-40 T6 has the higher level.
Re: Rotella no longer gas engine rated? [Re: jeff78] #4466454
07/21/17 05:34 PM
07/21/17 05:34 PM
Los Angeles, California
Gokhan Online content
Gokhan  Online Content
CK-4 and CJ-4 have the same limits on P, S, and SA. CK-4 is just CJ-4 with stricter limits and more modern tests on engine protection.
xW-40 and thicker is exempt from P limits for SM and SN.
So, that's not the reason.
They probably figured out that it was not worth spending money on all the additional SN tests for gasoline engines on an oil made and intended for HD diesel engines, as few people use such thick oils in their cars these days anyways.
1985 Toyota Corolla LE, 4A-LC engine, ~ 273,000 M
Mobil 1 Extended Performance 0W-20 SN PLUS (PAO-based)
Fram Ultra XG3600 filter (full synthetic), 90430-12031 drain gasket (rubber on aluminum)
Re: Rotella no longer gas engine rated? [Re: Gokhan] #4466980
07/22/17 09:35 AM
07/22/17 09:35 AM
OH
fdcg27 Online content
fdcg27  Online Content
OH
Or maybe they figured out that the faithful old BMW, Mercedes and turbo Subie users have enough savvy to look beyond the absence of an API S license in judging the suitability of this oil to their engines?
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: Rotella no longer gas engine rated? [Re: wwillson] #4467234
07/22/17 03:19 PM
07/22/17 03:19 PM
BrocLuno Offline
BrocLuno  Offline
And SBC, BBC, and SBF engine guys laugh
