Looking for some suggestions on my 2014 Honda CRV's TPS sensor light.
Had my original tires changed and soon after I picked it up the TPS light came on.
The tire dealer also changed the oem metal valve stem caps with cheap platic ones that did not even match.
Told the tire dealer I was unhappy and was going to the dealer to get my new caps and fix the TPS problem
on their dime .
Pressure in all tires were very close , so I checked again the next morning when they were cold.
No loss of pressure and all read 34psi.
Took the car on a trip and the light kept coming on ( pulled over a few times to check pressure and all were good )
Left the light on and contacted my Honda dealer and told them I checked tire pressure for a few days and
all tires were within .5 pounds of 34 psi and that I reset the TPS a bunch of times .
Told them everything and dropped it off with them .
Also mentioned that in the 3 years I have had the car the TPS light never came on.
Honda tech checked tire pressure and reset sensor ( just what I told them I did also )
Picked up the car today and after 20 minutes on the road the light went off again .
Called the dealer back and they said bring it back next week .
Any suggestions what this could be ?
Hate to take the car back for a second time only to not get it fixed again .
Honda dealer did not have the oem valve stem caps either.
Not sure why they did not order them as they has a week to get them in.
My understanding is the TPS runs off of wheel speed sensor, could that have been damaged ?
thanks for any help you all can provide.
on their dime .
