Matrix totaled
by circuitsmith
Today at 08:32 AM
Door rust problems
by Dave Sherman
Today at 07:51 AM
2016 Honda Civic problems
by dbias
Today at 07:39 AM
Royal purple 75-140 in a subaru rear
by 91camarosRS
Today at 07:32 AM
OCI. With short trips. Nissan 4 liter
by Gawardawg
Today at 06:52 AM
Approach Watching on the Beach @ St Maarten ...
by LoneRanger
Today at 06:41 AM
Honda Accord Needs Shocks; Front, Back, or Both?
by tc1446
Today at 05:50 AM
How much oil does your oil filter hold?
by Snagglefoot
Today at 05:44 AM
better day
by mx5miata
Today at 05:26 AM
BRAVO to Officer Wheeles......
by Sayjac
Today at 05:17 AM
People Watching ....Airport style.
by ZZman
Today at 04:24 AM
Subaru's at play...
by OneEyeJack
Today at 03:50 AM
Treating a 2003 Jetta
by llmercll
Today at 01:41 AM
Brakes not working - brake pedal sinks
by tookien
Today at 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
Today at 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
Today at 12:16 AM
One Dollar Per Gallon?
by Y_K
Yesterday at 11:53 PM
Walmart Tightening up Returns
by John_K
Yesterday at 10:21 PM
flare nut wrench set
by spasm3
Yesterday at 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
Yesterday at 09:45 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
82 registered (beanoil, andyd, BAJA_05, AndyB, 2009Edge, 2004tdigls, 7 invisible), 1492 Guests and 34 Spiders online.
65265 Members
67 Forums
285586 Topics
#4465343 - 07/20/17 07:05 PM TPS sensor 2014 CRV
matrass Online   content
Loc: Pa
Looking for some suggestions on my 2014 Honda CRV's TPS sensor light.
Had my original tires changed and soon after I picked it up the TPS light came on.
The tire dealer also changed the oem metal valve stem caps with cheap platic ones that did not even match.
Told the tire dealer I was unhappy and was going to the dealer to get my new caps and fix the TPS problem
on their dime .
Pressure in all tires were very close , so I checked again the next morning when they were cold.
No loss of pressure and all read 34psi.
Took the car on a trip and the light kept coming on ( pulled over a few times to check pressure and all were good )
Left the light on and contacted my Honda dealer and told them I checked tire pressure for a few days and
all tires were within .5 pounds of 34 psi and that I reset the TPS a bunch of times .
Told them everything and dropped it off with them .
Also mentioned that in the 3 years I have had the car the TPS light never came on.
Honda tech checked tire pressure and reset sensor ( just what I told them I did also )
Picked up the car today and after 20 minutes on the road the light went off again .
Called the dealer back and they said bring it back next week .
Any suggestions what this could be ?
Hate to take the car back for a second time only to not get it fixed again .
Honda dealer did not have the oem valve stem caps either.
Not sure why they did not order them as they has a week to get them in.
My understanding is the TPS runs off of wheel speed sensor, could that have been damaged ?
thanks for any help you all can provide.
Edited by matrass (07/20/17 07:06 PM)
#4465354 - 07/20/17 07:12 PM Re: TPS sensor 2014 CRV [Re: matrass]
eljefino Offline
Loc: ME
More than likely the tire shop damaged the sensor. They will probably deny this and keep at you with the "drive it another day" routine.
Get the honda dealer to actually "sniff out" the sensors and come up with a diagnosis and a price to fix it. Present this paperwork to the tire dealer and don't leave without money or a new sensor.
#4465366 - 07/20/17 07:21 PM Re: TPS sensor 2014 CRV [Re: eljefino]
jsfalls Offline
Loc: USA
These have indirect TPMS (no sensors in the wheels, just a rubber stem). It uses the wheel speed sensors, so it may need a VSA/ABS software update.
2012 Mazda 5 - Havoline 0W20, Idemitsu ATF
2002 Buick Century (beater) - Whatever is cheapest
2003 Honda Civic EX - Honda Genuine oil & ATF
#4465368 - 07/20/17 07:24 PM Re: TPS sensor 2014 CRV [Re: jsfalls]
Dave Sherman Offline
Loc: Ohio
Incorrect. The passive systems that use rotation don't meet the requirements, they are active sensors now. I had a 2008 CR-V, they've been using actual pressure sensors since 2007.
2015 Honda Pilot EX AWD
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
#4465373 - 07/20/17 07:28 PM Re: TPS sensor 2014 CRV [Re: matrass]
skyactiv Offline
Loc: The Midwest
Your vehicle either has a sensor in each wheel assembly or it uses the ABS sensors for the TPMS. Each wheel has an ABS sensor which detects wheel speed. A tire too low on air will spin at a different RPM than one at the nominal tire pressure. You rest the button each time you rotate the tires, add air, get new tires, check the air pressure.
Most any tire shop or dealer will toss your valve stem caps when getting new tires. You will wanna remove them from now on when buying new tires or having a flat fixed. OEM valve stem caps are usually the best quality. The factory ones for my wifes Audi have tiny O rings in them to give an air tight seal.
Me: 13' VW GTI 3 door 6 speed manual
#4465375 - 07/20/17 07:30 PM Re: TPS sensor 2014 CRV [Re: Dave Sherman]
JTK Offline
Loc: Buffalo, NY
Indeed some very late model Hondas did not use sensors in the wheels for TPM, they used the wheel speed sensors, but I don't believe the CRV ever went this route.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
#4465378 - 07/20/17 07:31 PM Re: TPS sensor 2014 CRV [Re: Dave Sherman]
skyactiv Offline
Loc: The Midwest
Cars don't have to use in wheel sensors for TPMS, regardless of the model year.
Edited by skyactiv (07/20/17 07:32 PM)
#4465394 - 07/20/17 07:40 PM Re: TPS sensor 2014 CRV [Re: matrass]
Loc: Ohio
My mistake, I had thought the fed needed active instead of indirect TPMS. My 2008 had active sensors.
#4465395 - 07/20/17 07:41 PM Re: TPS sensor 2014 CRV [Re: Dave Sherman]
LotI Offline
Loc: America's Dairyland
You are incorrect on your "incorrect" statement. 2014 CR-V and Accord went back to indirect TPMS.
OP, Press the button under your left knee to reset or use the MID to reset in vehicle settings. The metal valve stems are just a pretty cover anyway.
If you have a problem it could be the ABS speed sensor, and you should have an ABS MIL also
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
#4465403 - 07/20/17 07:47 PM Re: TPS sensor 2014 CRV [Re: skyactiv]
JTK Offline
Loc: Buffalo, NY
They don't have to, but almost all do. I can't name a single every day make/model other than Honda that went sensorless (in-wheel) in recent years for some of their models.
#4465463 - 07/20/17 08:37 PM Re: TPS sensor 2014 CRV [Re: matrass]
NormanBuntz Offline
Loc: Outer Banks, NC
If the TPMS light came on within 5-10 miles of leaving the tire dealer, either the tire dealer damaged one of the sensors or the new valve stems may not be compatible with your TPMS system.
My Ridgeline is almost 11 years old and I never had a TPMS light come on. I favor leaving on the original steel valve stems instead of using a new but cheap Chinese rubber valve stem.
2017 Honda Odyssey SE, 14K
2013 Honda Accord LX, 58K
2007 Honda Ridgeline RTS, 86K
2007 Infiniti M35, 104K
#4465466 - 07/20/17 08:39 PM Re: TPS sensor 2014 CRV [Re: Dave Sherman]
jsfalls Offline
Loc: USA
I am a Honda tech. Did they/you try a "hard" reset? You can press the reset button 3 times in a row (with about 5 seconds in between) to make the system "forget" the previously learned data. If that doesn't work it is probably either a wheel speed sensor or software issue. The dealer you went to probably just gave it to one of the express lube guys to check the tire pressure and reset it.
#4467870 - 07/23/17 10:27 AM Re: TPS sensor 2014 CRV [Re: matrass]
Loc: Pa
thanks for all of the advice so far.
The Honda dealer did not say what reset they used but I was thinking they just pushed the button once and checked the tire pressure.
What got me is I told them the pressure in the tires was monitored for a week and I reset the button but it did not work.
I ended up trying the hard reset on it yesterday, will see if the light comes back on.
Should the light come on I will call the Honda dealer back and ask to speak to the service manager and explain the whole situation before
taking it back to them.
Edited by matrass (07/23/17 10:35 AM)
#4480569 - 08/06/17 09:00 AM Re: TPS sensor 2014 CRV [Re: matrass]
Loc: Pa
update on the TPS light. I did the hard reset and it came back on . have to get it back to the dealer again.
#4483019 - 08/08/17 07:21 PM Re: TPS sensor 2014 CRV [Re: matrass]
14Accent Offline
Loc: MN
Might be a dumb question, but what is the actual tread depth of the tires? Being as Honda switched to a high-resolution ABS sensor based system, there could be enough of a discrepancy in the circumference to cause an issue.
These systems are actually quite smart. I MUCH prefer WSS based systems to active, tire sensor systems. No need for extra equipment, less touchy with weather changes, easily (usually) diagnosed.
As a side note: Those metal caps on hard stem TPM sensors are a pain. They LOVE to seize to the stem and snap off. Steel cap on aluminum... no thanks.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
