2003 Ford CVPI, 86kmi, 6kmi on Edge HM Ti 5W30
by Colt45ws. 12/18/18 12:35 PM
2017 Kia Sportage recall notice
by SlavaB. 12/18/18 12:26 PM
My VW Service Experience
by Delta. 12/18/18 11:36 AM
Nissan high idle, P0507
by LeakySeals. 12/18/18 11:23 AM
Should i go for even thinner fluid ?
by NICAT. 12/18/18 11:06 AM
Viscosity question
by dbierman. 12/18/18 10:50 AM
48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
102 registered members (87sammy, 28oz, 14Accent, AdditiveOCD, 15 invisible), 1,939 guests, and 38 spiders.
Topics295,220
Posts4,930,279
Members66,716
Most Online2,553
Oct 27th, 2018
My transmission makes greenish milky oil #4465144
07/20/17 03:17 PM
07/20/17 03:17 PM
Louisiana
SuzukiGoat Offline OP
Louisiana
Stand alone transmissions. Wet clutch
Five speed manual.
Zero material in filter screens.
Two units. One running yamalube 15w50 synthetic. One running rotella 15w40.
When draining either trans, oil comes out the wrong color. Greenish chocolate milk.
Water intrusion is impossible on one unit. Possible on the other.
One unit only sees long drives. One only sees short. One unit is driven by someone who clutches every gear while rev matching. The other is by Simone who only rev matches.
Oil comes out of both units the same odd color.
Performance of transmission changes when oil starts to sheer. Tougher to slot gears in.
Before I pay to semd these off... What in God's name could it be.
2003 Nissan Xterra 4x4 M1 HM 10w40
2001 Toyota 4runner 4x4 M1 0w40
2016 Yamaha YXZ1000R VR1 20w50
Re: My transmission makes greenish milky oil [Re: SuzukiGoat] #4465164
07/20/17 03:31 PM
07/20/17 03:31 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
What does the oil look like if you increase the frequency of the oil changes?
Re: My transmission makes greenish milky oil [Re: Linctex] #4465173
07/20/17 03:35 PM
07/20/17 03:35 PM
Louisiana
Louisiana
Oil was wired color at first change. First change at 50ish miles. Second at 200. Third around 600.
Wired every single time. Longer seems to make milkier oil.
I am in a 95% or greater environment
Re: My transmission makes greenish milky oil [Re: SuzukiGoat] #4465345
07/20/17 06:06 PM
07/20/17 06:06 PM
Florida /Texas
Mackelroy Offline
Mackelroy  Offline
Florida /Texas
The water pump normally has two seals, one separates water, the other oil , Id say that's where your issue is.
Happening on two different units of the same type(would be rare), so there must be a common defect.
Re: My transmission makes greenish milky oil [Re: SuzukiGoat] #4465591
07/20/17 09:33 PM
07/20/17 09:33 PM
New York
jeff78 Offline
jeff78  Offline
New York
It has to be some sort of fluid contamination. You said these are separate transmissions - do these have coolant/oil heat exchangers?
Re: My transmission makes greenish milky oil [Re: jeff78] #4465599
07/20/17 09:47 PM
07/20/17 09:47 PM
Louisiana
Louisiana
Transmssions are isolated self co tained units with zero cooling. One shaft going in. Two shafts coming out.
Thing of it more as a divorced transfer case with a clutch.
Unless coolant were to leak into the engine. Which it isn't. Run down a four foot drive shaft. Penetrate a seal. Then a second seal. And then somehow mixed with the oil, fluid intrusion is impossible.
That's what makes it weird.
Re: My transmission makes greenish milky oil [Re: SuzukiGoat] #4465622
07/20/17 10:05 PM
07/20/17 10:05 PM
Atlanta
DuckRyder Offline
DuckRyder  Offline
Atlanta
Are those lubes what are specified...?
Wondering if the greenish is from yellow metals?
Are they both YXZ1000R Side by Sides?
Robert
  • 2007 Toyota Prius Touring
  • 2005 Honda Civic Sedan
  • 1972 Ford F100
Re: My transmission makes greenish milky oil [Re: SuzukiGoat] #4466054
07/21/17 10:25 AM
07/21/17 10:25 AM
New York
jeff78 Offline
jeff78  Offline
New York
Beats me then. You could have an oil analysis done on the green milkshake to see what's in it.
Does the stuff smell like engine oil, or something else?
What's the history behind these? Purchased new (known history), or secondhand?
Re: My transmission makes greenish milky oil [Re: DuckRyder] #4466265
07/21/17 01:48 PM
07/21/17 01:48 PM
Louisiana
Louisiana
Both new yxz1000r units.
Fluids both meat specs. One is the manufacturer's fluid of choice.
Oil smells... Like old oil. Not burned. But like a greasy mechanic shop.
Both units are working perfectly. Just an oddity.
Will send the yamalube off in 1000 miles or so.
Re: My transmission makes greenish milky oil [Re: SuzukiGoat] #4467695
07/23/17 05:24 AM
07/23/17 05:24 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
These getting driven through the wet by any chance? Sounds like classic water contamination from being driven through wet terrain.
Re: My transmission makes greenish milky oil [Re: SuzukiGoat] #4468552
07/23/17 11:33 PM
07/23/17 11:33 PM
MN
tmorris1 Offline
tmorris1  Offline
MN
Clutch material probably
