Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
115 registered members (ArrestMeRedZ, 2012AccentSE, Arminius, albenjoseph, 55Test, addyguy, 14 invisible), 2,024 guests, and 63 spiders.
Topics286,147
Posts4,903,006
Members67,565
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
04 Lexus ES330 PYB SAE 30 5,515 miles w/TBN/TAN/PC #4464853
07/20/17 12:07 PM
07/20/17 12:07 PM
Jacksonville, FL
FlyNavyP3 Offline OP
Jacksonville, FL
As promised here's the UOA on my 2004 Lexus ES330 running Pennzoil Yellow Bottle SAE 30 for 5,515 miles for about 3 months. Filter used was one of the Rock Auto Ultra Power Toyota copy filter that's been cut and discussed here in virgin and used form. I was a bit surprised by the particle count data for this run compared to the previously run Fram Ultra.
I've included the previous UOA for the comments and PC data as well.
Luke
Re: 04 Lexus ES330 PYB SAE 30 5,515 miles w/TBN/TAN/PC [Re: FlyNavyP3] #4464899
07/20/17 12:38 PM
07/20/17 12:38 PM
Louisiana
camryrolla Offline
camryrolla  Offline
Louisiana
Why bother dealing with PYB oil and do more oil changes every three months.
Make your life simple by going with PUP for 12,500 miles OCI.
Change the PUP oil, Fram Ultra, and the air filter, all at once.
'11 Camry 2.5L 160K mi
'07 Corolla 1.8L 220K mi
Always Fram XG filter.
Re: 04 Lexus ES330 PYB SAE 30 5,515 miles w/TBN/TAN/PC [Re: FlyNavyP3] #4464901
07/20/17 12:39 PM
07/20/17 12:39 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
No surprises here at all!!!!
Re: 04 Lexus ES330 PYB SAE 30 5,515 miles w/TBN/TAN/PC [Re: camryrolla] #4464903
07/20/17 12:40 PM
07/20/17 12:40 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: camryrolla
Why bother dealing with PYB oil and do more oil changes every three months. Make your life simple ...
Camryrolla = You probably haven't been following this "saga" (which it really isn't, LOL)
This was an experiment - one I'd say turned out perfectly fine.
Re: 04 Lexus ES330 PYB SAE 30 5,515 miles w/TBN/TAN/PC [Re: FlyNavyP3] #4464906
07/20/17 12:41 PM
07/20/17 12:41 PM
il usa
merconvvv Offline
merconvvv  Offline
il usa
Wow pyb 30 rocks
1988 Mazda RX7 na PP 10w30 Noack 4.7
1994 Chrysler Concorde 3.3
1999 Ford Expedition 4.6 QSUD 10W30 NOACK 5.0
Re: 04 Lexus ES330 PYB SAE 30 5,515 miles w/TBN/TAN/PC [Re: FlyNavyP3] #4464911
07/20/17 12:43 PM
07/20/17 12:43 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
What's HILARIOUS to me is "aluminum went up" he says.... from 2 ppm to 3 ppm, LOL!!!!!
I think it's safe to say that's within a possible range of error in the test.
Essentially,
with 2-3 ppm alum,
and w/ 2-3 ppm iron (averaged) -
you are "essentially" experiencing ZERO wear.
Re: 04 Lexus ES330 PYB SAE 30 5,515 miles w/TBN/TAN/PC [Re: camryrolla] #4464914
07/20/17 12:44 PM
07/20/17 12:44 PM
Jacksonville, FL
Jacksonville, FL
I have over 200 quarts of oil that I got DIRT cheap, the PYB I got for 25 cents per quart. These filters I got for $1.41 ea. The oil performed well for the intended usage and interval. Furthermore, why would I change the air filter every 12.5k? The current air filter has been in place since 130,000 miles and is working well. PUP is not only hard to find, but expensive. I rolled back to a 5k OCI while I'm using up random oils from the clearance stash I have going. I'll run the higher end oils in my stash out to 10k, but for now 5k on random oils is working for me. I also enjoy getting under the car every 5k and it lines up with my tire rotations and brake inspections.
Luke
Re: 04 Lexus ES330 PYB SAE 30 5,515 miles w/TBN/TAN/PC [Re: Linctex] #4464920
07/20/17 12:48 PM
07/20/17 12:48 PM
Jacksonville, FL
Jacksonville, FL
Essentially,
with 2-3 ppm alum,
I'm pleased with the performance of this engine in terms of low wear metal production. The PYB 30 I don't think I'd want to run out to 10K, there is reserve TBN but considering the TAN number at 5k compared to the PUP at 10k I'm not sure if the PYB would've made it. Perhaps I'll try next summer, but probably not considering the size of my stash.
Luke
Re: 04 Lexus ES330 PYB SAE 30 5,515 miles w/TBN/TAN/PC [Re: merconvvv] #4464944
07/20/17 01:06 PM
07/20/17 01:06 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Originally Posted By: merconvvv
Wow pyb 30 rocks
Yep, it seems to work just as well as any other oil in that engine.
Which pretty much goes to show that within reason (proper grade, required certifications) the choice of oil is irrelevant in terms of generating a consistent Blackstone UOA.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: 04 Lexus ES330 PYB SAE 30 5,515 miles w/TBN/TAN/PC [Re: FlyNavyP3] #4464992
07/20/17 01:51 PM
07/20/17 01:51 PM
N.C.
gman2304 Offline
gman2304  Offline
N.C.
Oil and filter change, for less than 3 bucks! I'm nominating you for the 'FRUGALBITOGER' OTY award! cool
Re: 04 Lexus ES330 PYB SAE 30 5,515 miles w/TBN/TAN/PC [Re: FlyNavyP3] #4465023
07/20/17 02:31 PM
07/20/17 02:31 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Where did you find the PYB SAE 30 for 25 cents/qt.? That's the (FAR-free) steal of the century!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: 04 Lexus ES330 PYB SAE 30 5,515 miles w/TBN/TAN/PC [Re: bullwinkle] #4465142
07/20/17 04:16 PM
07/20/17 04:16 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I think he said he got it on a clearance sale
Re: 04 Lexus ES330 PYB SAE 30 5,515 miles w/TBN/TAN/PC [Re: Linctex] #4465179
07/20/17 04:38 PM
07/20/17 04:38 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Think he told me in a PM he got that at K Mart and other stores
Re: 04 Lexus ES330 PYB SAE 30 5,515 miles w/TBN/TAN/PC [Re: FlyNavyP3] #4465224
07/20/17 05:31 PM
07/20/17 05:31 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
Looks good.
You were correct in postulating that an SAE 30 would work just fine in constant warm weather conditions.
Particle counts actually look better with the [censored] oil filter and the PYB than they did with PUP and an Ultra.
Go figure?
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: 04 Lexus ES330 PYB SAE 30 5,515 miles w/TBN/TAN/PC [Re: fdcg27] #4465339
07/20/17 07:01 PM
07/20/17 07:01 PM
Jacksonville, FL
Jacksonville, FL
Originally Posted By: fdcg27
Looks good.
Go figure?
I was really really surprised with the PC data. To sure what to make of that. Otherwise the SAE 30 performed very well in a reasonable oil change interval. I still have 5 quarts in use in my 4Runner, VWB also purchased on clearance in that one.
Lexus currently has Valvoline SynPower 20w50 in it with another of the same filter used here, VSP was also end of year clearance oil at a staggering $2/qt, will run through the peak summer heat for another 5k and dump for something thinner as the weather cools off.
Luke
Page 1 of 3 1 2 3
