Solar lights that last all night
by Snagglefoot. 12/16/18 09:20 AM
Things Santa might say......
by ZZman. 12/16/18 08:24 AM
ULTRA-POWER 57082
by ET16. 12/16/18 06:56 AM
No collision totaled vehicle
by madRiver. 12/16/18 06:32 AM
Brightest backup light for my daughters car?
by BobsArmory. 12/16/18 06:26 AM
M1 0W20 EP Good To At Least 10K Miles ?
by ChrisD46. 12/16/18 03:29 AM
Gift for young Army Cadet
by Snagglefoot. 12/16/18 12:33 AM
Instacart Grocery Delivery
by dogememe. 12/16/18 12:26 AM
My brother bought this...
by miden851. 12/15/18 09:12 PM
Watch out for scammers
by Chris142. 12/15/18 08:45 PM
15K OCI R53 2006 Mini Cooper S 144k
by dx92beater. 12/15/18 08:32 PM
Beneficial clean fuel.injectors in Ultrasonic Cleaner
by JLawrence08648. 12/15/18 06:54 PM
Back to Basics III
by MolaKule. 12/15/18 05:30 PM
MikeMTL, AJ11, bandito, Spkrdctr, torchredone12
66691 Registered Users
111 registered members (03s, amblerman, ammolab, 53' Stude, 97K15004WD, Ag76, 6 invisible), 2,154 guests, and 36 spiders.
Topics295,143
Posts4,928,540
Members66,691
Most Online2,553
Oct 27th, 2018
Can't find alternator pulley for my car.... #4464843
07/20/17 10:58 AM
07/20/17 10:58 AM
Virginia
Hemispheres Offline OP
Virginia
I've got a rattle coming from the alternator pulley on my vehicle. 2009 Lacrosse with the Series III 3800.
If possible I'd rather replace the pulley instead of the whole alternator, I don't see any need to drop $125 on a whole new alternator when it still operates just fine.
Here's the only info I can find on the pulley. http://www.rockauto.com/en/moreinfo.php?pk=3572820&cc=1442771&jsn=248
I'll accept a junkyard part, just don't see how I'd be able to remove the pulley without an electric or air powered impact.
2009 Buick LaCrosse (3800 Series III) - 137,000 miles.
PZ Plat HM/Mobil 1 HM
Bosch/Purolator/Mobil filters
Re: Can't find alternator pulley for my car.... [Re: Hemispheres] #4464848
07/20/17 11:03 AM
07/20/17 11:03 AM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
Without a more mechanically complicated decoupler pulley (that your car's alternator apparently does NOT have), how/why would a regular solid belt pulley make a rattling noise beyond coming loose? It's not a wear item or something prone to going bad.
Re: Can't find alternator pulley for my car.... [Re: Bottom_Feeder] #4464851
07/20/17 11:05 AM
07/20/17 11:05 AM
Virginia
Virginia
Most likely because I've been beating the [censored] out of it recently.....
I replaced the battery in March when the rattle first started occurring, I had both battery and alternator tested and the alt checked out.
Re: Can't find alternator pulley for my car.... [Re: Hemispheres] #4464854
07/20/17 11:10 AM
07/20/17 11:10 AM
Occupied Virginia
Occupied Virginia
The car with your right foot, or the alternator with a hammer?
Re: Can't find alternator pulley for my car.... [Re: Hemispheres] #4464860
07/20/17 11:15 AM
07/20/17 11:15 AM
Virginia
Virginia
Car with the right foot. Driving like an idiot. I edited my last post for more detail. Rattle has been present for 4.5 months and the alternator checks out. Also probably doesn't help that I've been driving around on a busted motor mount.
Re: Can't find alternator pulley for my car.... [Re: Hemispheres] #4464861
07/20/17 11:16 AM
07/20/17 11:16 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
There are a couple of alternator/starter part website that sells alternator pulley.
If all else fail, check ebay.
You need to know the diameter of the pulley plus no. of groove.
You CANNOT search by the alternator for your model car since you are looking for parts of the alternator.
I am not sure if the pulley alone will cost you more than the alternator itself or not much more if you buy a complete alternator.
Another way is to buy a used good one from JY.
  • 2017 Toyota Sienna
Re: Can't find alternator pulley for my car.... [Re: Hemispheres] #4464866
07/20/17 11:20 AM
07/20/17 11:20 AM
Virginia
Virginia
Pulley OD = 62 mm
Serpentine belt = 90.5" long by .82" wide with six ribs
Re: Can't find alternator pulley for my car.... [Re: Hemispheres] #4464891
07/20/17 11:31 AM
07/20/17 11:31 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Any alternator rebuild shop can help.
I have had good luck with eBay alternator pullies.
Yes, an impact is needed to change it.
Re: Can't find alternator pulley for my car.... [Re: Hemispheres] #4464896
07/20/17 11:36 AM
07/20/17 11:36 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I cant think of how a solid pulley would rattle unless its loose on the shaft. I would suspect a bearing going bad more than the pulley.
Re: Can't find alternator pulley for my car.... [Re: Hemispheres] #4464905
07/20/17 11:40 AM
07/20/17 11:40 AM
Virginia
Virginia
I've got no squealing or screeching noises. It's specifically a metallic rattle coming from the top of the engine/alternator pulley.
Re: Can't find alternator pulley for my car.... [Re: Trav] #4464909
07/20/17 11:43 AM
07/20/17 11:43 AM
Occupied Virginia
Occupied Virginia
This. ^
Or a belt idler pulley being the real culprit. Or the belt tensioner. Or the water pump. Etc.
Have you actually removed the belt and poked around to determine for sure it's the alternator? I just can't see how a sold pulley goes bad or how a rattling/loose pulley would be the pulley's fault.
Re: Can't find alternator pulley for my car.... [Re: Hemispheres] #4464924
07/20/17 11:51 AM
07/20/17 11:51 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Take the belt off and start the car to let it run for a few seconds, see if the noise is still there.
And you can turn the pulley by hand to feel for a bad bearing or movement. Solid, one piece pulleys don't go bad.
I thought my PS pump was going bad, turned out to be the AC clutch bearing. But until I removed the PS pump belt I could not tell.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Can't find alternator pulley for my car.... [Re: Hemispheres] #4464935
07/20/17 11:57 AM
07/20/17 11:57 AM
Virginia
Virginia
Just fired her up, no rattle but I did hear a squeaking from the a.c. compressor that went away after about a minute. Tensioner has slight movement but is in sync with the back and forth movement of the engine due to the bad motor mount.
Ill have to replace the mount and go from there.
Re: Can't find alternator pulley for my car.... [Re: Hemispheres] #4465044
07/20/17 01:46 PM
07/20/17 01:46 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
If it is a solid pulley, it is not the pulley making the noise.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Can't find alternator pulley for my car.... [Re: Trav] #4465138
07/20/17 03:12 PM
07/20/17 03:12 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I'm responding to this thread believing he has an "overrunning clutch" alternator pulley.
