Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
Good or bad? Special ordering a brand new car?
by Ed_Flecko. 03/19/19 11:49 AM
Good Purchase?
by FordBroncoVWJeta. 03/19/19 11:33 AM
not sure what spark plugs to buy now
by MrTruckDriver. 03/19/19 11:33 AM
Tires on a Lease Return
by clarkflower. 03/19/19 11:25 AM
Auto-Rx now available on Amazon
by LarryD. 03/19/19 11:14 AM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
125 registered members (01rangerxl, 2015_PSD, 4WD, 2004tdigls, 15 invisible), 2,059 guests, and 55 spiders.
Topics286,082
Posts4,902,248
Members67,560
Most Online2,967
Mar 10th, 2019
Fram HP1, high volume oil pump, better filter? #4464727
07/20/17 09:29 AM
07/20/17 09:29 AM
New England
555 Offline OP
555  Offline OP
New England
In reference to the 92 GT in signature. Engine builder recommended Fram HP1 back in 2001. The engine has a high flow oil pump. 10W-40 Royal Purple. I change the oil every 3000 miles(I don't get a chance to drive it very often). Would a "better" filter be an option I should explore? My concern is the high volume oil pump with a different filter(possibly more restriction?) I have an M1 filter should I use it or something else or just stick with the HP1? Thanks for any advice.
84 XJ6 M1
92 Mustang 5.0 Redline
99 Tahoe 2 door Castrol Edge
99 MX5 Miata Anniversary Edition M1
04 Subaru STi Motul
Re: Fram HP1, high volume oil pump, better filter? [Re: 555] #4464742
07/20/17 09:46 AM
07/20/17 09:46 AM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
I'm running an hp1 on my cougar, 408 stroker, high volume oil pump. I will use hp1 and ultras.
2019 Cherokee, 2018 Jetta, 2014 Sentra, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Fram HP1, high volume oil pump, better filter? [Re: 555] #4464794
07/20/17 11:07 AM
07/20/17 11:07 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Any reason for the high volume pump? I would think factory is more than adequate if its not shot.
2019 VW Jetta S,6M OCI#0 1136mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Fram HP1, high volume oil pump, better filter? [Re: 555] #4464812
07/20/17 11:35 AM
07/20/17 11:35 AM
New York
jeff78 Offline
jeff78  Offline
New York
The Fram HP series are high flow filters designed for racing applications so your engine builder was right on the money.
Re: Fram HP1, high volume oil pump, better filter? [Re: 555] #4464872
07/20/17 12:23 PM
07/20/17 12:23 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: 555
The engine has a high flow oil pump. 10W-40 Royal Purple. I change the oil every 3000 miles.... with a different filter(possibly more restriction?)
You are WAAAY over-thinking this. Even the short FL-300 will adequately flow what you need it to.
The stock Motorcraft FL-1A is very large, and will never go into bypass unless you are stone cold and go full throttle.
I honestly cannot think of one single reason why you might "need" a HP filter.
Not one.
And I have close to 100 289's, 302's, 347's, 351's and other notched in my belt.
Your biggest worry? Honestly, the roll pin that holds the distributor gear to the distributor shaft SHOULD BE your "biggest worry".....I've changed a dozen already in 25 years, and the HV oil pump was always the cause.
....and the oil pump driveshaft, too. It's a real weak point.
Re: Fram HP1, high volume oil pump, better filter? [Re: ARCOgraphite] #4464883
07/20/17 12:26 PM
07/20/17 12:26 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: ARCOgraphite
Any reason for the high volume pump? I would think factory [oil pump] is more than adequate if its not shot.
It usually is.
Crank/rod bearing clearances usually dictate which to use.
99.99% of "street" engines do *NOT* need a HV oil pump.
I have found MORE OFTEN than not that a HV oil pump only eats HP, distributor gears, oil pump drive shafts, etc.
Anyone with real engine building experience will typically advise against using one.
Re: Fram HP1, high volume oil pump, better filter? [Re: 555] #4464927
07/20/17 12:52 PM
07/20/17 12:52 PM
New England
555 Offline OP
555  Offline OP
New England
Thanks for the responses. At the time, 16 or 17 years ago I was going to have a supercharger put on at a later date. Paxton,Vortech and Procharger(SQ) were competing for customers money and I hadn't made a decision yet. I was overly concerned with overheating and put a 7 quart oil pan on there along with the high volume oil pump(HVOP). The engine also has underdrive pulleys from before, so maybe that helps a little. The engine builder has since passed away, rest in peace Bob Pucel, so I would ask him first if I could.
If I do install a super or turbocharger should I still dump the HVOP?
The car has never had an overheating issue, put in new radiator with engine build.
84 XJ6 M1
04 Subaru STi Motul
Re: Fram HP1, high volume oil pump, better filter? [Re: 555] #4465038
07/20/17 02:44 PM
07/20/17 02:44 PM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
Run it as is. Usually Racing type filters biggest benefit is the higher burst strength. What is yourMaximum cold oil pressure?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Fram HP1, high volume oil pump, better filter? [Re: 555] #4465135
07/20/17 04:11 PM
07/20/17 04:11 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Some SC's use engine oil for lube, some don't.
A turbo definitely does. It isn't hurting anything as seldom as you drive it.
Yes to above post by CT8 - higher burst strength is the only benefit. You'll pop your electric oil pressure sending unit before you pop any oil filter, though.
Go for better filtration. Leave the racing filters tot he guys with straight 50 oil.
Donaldson and Amsoil (just a Donaldson with amsoil sticker) make excellent filters.
Re: Fram HP1, high volume oil pump, better filter? [Re: CT8] #4466416
07/21/17 05:01 PM
07/21/17 05:01 PM
New England
555 Offline OP
555  Offline OP
New England
Oil pressure is always high but in the normal range when cold. Then it drops off to the middle of the normal range as it warms up.
Out of town, so I will have some numbers after the weekend. I think the underdrive pulleys saved me from my mistake. The engine builder wasn't too keen on it but I insisted and this might be why he recommended an HP1 filter. Thanks for responding.
84 XJ6 M1
04 Subaru STi Motul
Re: Fram HP1, high volume oil pump, better filter? [Re: Linctex] #4466487
07/21/17 06:05 PM
07/21/17 06:05 PM
New England
555 Offline OP
555  Offline OP
New England
Not one.
Thanks for the advice. I'm not worried about filtration since I change the oil often. Just don't want to bottleneck oil flow with the wrong filter with the high flow oil pump. Going to find the vacuum leak next week and throw it on the dyno.
Thanks for the info and reassurance.
84 XJ6 M1
04 Subaru STi Motul
Re: Fram HP1, high volume oil pump, better filter? [Re: Linctex] #4466497
07/21/17 06:16 PM
07/21/17 06:16 PM
New England
555 Offline OP
555  Offline OP
New England
As far as superchargers using engine oil that's part of the reason I added the 7 quart sump, plus I figured if I went turbo, couldn't hurt either.
Concerned with oil filter selection because I was worried about creating significant oil back pressure with the wrong filter. Thanks for responding and have a good weekend.
84 XJ6 M1
04 Subaru STi Motul
Re: Fram HP1, high volume oil pump, better filter? [Re: ARCOgraphite] #4466508
07/21/17 06:25 PM
07/21/17 06:25 PM
New England
555 Offline OP
555  Offline OP
New England
I was thinking with a supercharger and a 7 quart sump I didn't want any part to starve for oil. Plus I thought of the motor oil as a primitive secondary cooling system. Remember, this was 2000 and had less options and didn't know that much....not that I know much more now!
I appreciate your feedback. Enjoy your weekend.
84 XJ6 M1
04 Subaru STi Motul
Re: Fram HP1, high volume oil pump, better filter? [Re: 555] #4466558
07/21/17 07:12 PM
07/21/17 07:12 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Creating significant oil back pressure with the wrong filter?
It'll never happen. Read this:
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3197094/
have a good weekend, too!
Re: Fram HP1, high volume oil pump, better filter? [Re: 555] #4468870
07/24/17 11:43 AM
07/24/17 11:43 AM
N.H, U.S.A.
N.H, U.S.A.
Just BC you have a HV pump doesn't mean its pumping HV through the FILTER. The engine will flow what it does at any given pressure. You are likely heating oil and wasting HP pumping it out the bypass.
There was a time when chevy guys would put BB pumps on moderately cammed and tuned SBC.
They Don't do anything good only bad - including spark scatter in the distributer.
Rebuilding a stock spec (or new Melling) pump and setting it up correctly is more important.
I recall 45 years ago hand lapping gear faces in diamond paste ... ahh the good ole days smile
