Re-using building materials esp nails
by andyd
06/18/18 08:57 AM
Central A/C [censored] out
by TOMJ
06/18/18 08:43 AM
08 Scion tC under valve cover pics
by Highboy
06/18/18 08:39 AM
Storing extension ladded in garage?
by maverickfhs
06/18/18 08:27 AM
Do you let your tool batteries go dead in storage
by Snagglefoot
06/18/18 07:20 AM
Any news on what happened to this plane?
by Exhaustgases
06/18/18 02:36 AM
E4OD fluid ?
by Exhaustgases
06/18/18 02:23 AM
Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
WtsTacoma01, Orion62, Revd, blinky1041, mostdecent
65262 Registered Users
84 registered (4WD, AITG, 2012AccentSE, Astro14, Artem, AndyB, 7 invisible), 1506 Guests and 34 Spiders online.
65262 Members
67 Forums
285515 Topics
Page 1 of 3 1 2 3 >
#4464531 - 07/20/17 03:41 AM 1st brake job on my 2012 Honda Accord
Chris B. Offline
Loc: Colorado
My 2012 Accord has 70,000 miles on it and the rotors are wraped badly. The pads have lots of meat left but I cant stand the car shaking when I hit the breaks so I'm going to replace everything. A good friend of mine can get me parts at NAPA at a pretty good discount so I'd like to take him up on that offer. What would you say is the best parts for this job that I can get at NAPA? The factory rotors started warping between 40,000 and 50,000 miles and slowly got worse till now at 70.000 miles. I'd like to get a rotor that would resist warping and pads that last and bite well too. Are Ultra Premium rotors and adaptive One pads a good combo? Thanks for any recommendation!!!
Edited by Chris B. (07/20/17 03:51 AM)
Edit Reason: spelling
#4464533 - 07/20/17 03:49 AM Re: 1st break job on my 2012 Honda Accord [Re: Chris B.]
Merkava_4 Offline
Loc: Clovis, CA
That's two times in a row tonight that you misspelled "brake" in a thread title. grin2
#4464534 - 07/20/17 03:50 AM Re: 1st break job on my 2012 Honda Accord [Re: Merkava_4]
Chris B. Offline
Loc: Colorado
Oh dang! It is 3am and I'm dead tired but that is no excuse haha!
#4464535 - 07/20/17 03:55 AM Re: 1st break job on my 2012 Honda Accord [Re: Chris B.]
Merkava_4 Offline
Loc: Clovis, CA
We'll let you slide this time - pun intended. grin2
#4464536 - 07/20/17 03:58 AM Re: 1st break job on my 2012 Honda Accord [Re: Chris B.]
The Critic Offline
Loc: CA
The scenario you described sounds very normal for most imports that use ceramic pads from the factory.
You can either have the rotors machined using an on-car-lathe (not bench lathe) or you can remove the old rotors, clean off the rust on the hub very well and install new premium rotors (Napa Ultra prem should be ok). Make sure you measure the runout and confirm that it is under 0.002." Sand the old pads lightly and re-use them.
Be sure to check your rear brakes. At your mileage, the rear pads should be due soon.
2011 Toyota Prius - 168k - ServicePro Dexos 0W-20
2007 Honda Accord 2.4 - 128K - Idemitsu 5W-20
#4464569 - 07/20/17 06:05 AM Re: 1st break job on my 2012 Honda Accord [Re: The Critic]
Kira Offline
Loc: Champlain/Hudson Valley
My neighbor's 2010 Accord had near bone dry, STICKY pins in the rear brakes.
One pad cocked so it wore crookedly, hit the warning tang and I got a phone call.
ERGO address cleaning and lubing the pins.
#4464570 - 07/20/17 06:06 AM Re: 1st brake job on my 2012 Honda Accord [Re: Chris B.]
Tman220 Offline
Loc: MN
I tried the adaptive one pads on a 2009 Malibu, as you probably know the theory behind them are different friction material between the inside and outside pad. I found in my scenario they quickly lead to a pulsating pedal and had less bite than the factory pads. I switched to Akebono Pro Act pads and was much happier. It looks like NAPA has an Akebono pad for your Accord that may be worth a try.
I liked the adaptive one Pads enough at first to recommend them and install a set in my mom's 2007 Camry. In her car, the pulsating pedal isn't an issue but they are noisy while backing up and when cold, and offer significantly less bite than the factory pads to the point she noticed and complains about it.
New rotors were installed on both brake jobs.
Just my experience... different cars, different environment etc.
Edited by Tman220 (07/20/17 06:19 AM)
2012 Regal GS Turbo PP 5w30
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30
#4464590 - 07/20/17 06:40 AM Re: 1st break job on my 2012 Honda Accord [Re: Merkava_4]
aquariuscsm Offline
Loc: Dallas,Tx USA
He was sleepy and just needed to take a brake,um,I mean break haha laugh
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum 0W20
#4464594 - 07/20/17 06:50 AM Re: 1st break job on my 2012 Honda Accord [Re: Chris B.]
rshaw125 Offline
Loc: Raleigh ,NC CSA
Have your NAPA contact have the rotors turned. They'll probably last until the pads are actually worn out. I have a buddy who did my Buick rotors for (free) a few cold ones. The pads still are not worn out.
2012 Porsche Carrera S
2016 Ford Edge 2.0
2002 Taurus Vulcan SOLD
2006 Explorer SOLD
#4464617 - 07/20/17 07:29 AM Re: 1st break job on my 2012 Honda Accord [Re: Chris B.]
mightymousetech Online   happy
Loc: Ontario, Canada
If the rotors are actually warped, it is most likely caused by improper wheel nut torque. Quality of rotor has nothing to do with it.
This is assuming the brakes (NOT breaks GAH!) are properly serviced at least once a year.
Edited by mightymousetech (07/20/17 07:29 AM)
Mighty Mouse Tech
Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
#4464624 - 07/20/17 07:37 AM Re: 1st break job on my 2012 Honda Accord [Re: Merkava_4]
DBMaster Offline
Loc: DFW
That seems to be a rampant error on this site, almost as bad as the misuse of there, they're, and their, or your and you're.
#4464630 - 07/20/17 07:56 AM Re: 1st break job on my 2012 Honda Accord [Re: Chris B.]
LotI Offline
Loc: America's Dairyland
There are several TSB's for Accords having brake shudder. It could be warped rotors or material transfer to the rotor. You could have them turned if there is enough material. If you go new, be diligent about removing any rust from the hub. Make sure your wheel surfaces are cleaned up too.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
#4464648 - 07/20/17 08:21 AM Re: 1st break job on my 2012 Honda Accord [Re: mightymousetech]
Stevie Offline
Loc: Port Aransas, TX
I second this opinion. You will be surprised how over torqued the lug nuts can be when they use those powerful impact drivers. Even my Mercedes dealer had mine way way over specs. Discount tire is one of the few that is careful about this and uses torque sticks.
#4464747 - 07/20/17 09:53 AM Re: 1st brake job on my 2012 Honda Accord [Re: Chris B.]
HangFire Offline
Loc: Central Maryland
I am running Ultra Premiums and Adaptive One's on my Honda Pilot for the last 10K miles and are very happy with them. My AO's are made in Canada and rated GG, both make me happy. They have plenty of bite. My buddy has had AO's on his Volvo's for several years now. No pulsating problems.
The "best parts" may include SilGlyde as well, but other brake-qualified greases will do.
The rotors pulsating or "warping" may happen again unless you check parallelism, rotor runout, and properly bed the brakes (not breaks). These are simple things to do, but many people would rather trust random chance and claim "these things are set at the factory" or other nonsense.
I have the instruments, I've had to correct for runout by re-indexing the rotors. Yet some people would rather be blind and trust to luck. My cheap C-Tek rotors on the Toyota have 58K with zero "warping" feeling when braking. I've lubed the brakes once since I put them on and that's it. But I did check parallelism and corrected for runout when I installed them 3 years ago.
#4464748 - 07/20/17 09:54 AM Re: 1st break job on my 2012 Honda Accord [Re: Stevie]
HangFire Offline
You just contradicted yourself. You said they're careful, and use torque sticks.
Careful would mean using a torque wrench.
Various musings: http://hangfire.net
Page 1 of 3 1 2 3 >
