Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
transmission fluid and filter exchange
by Dennisistheman. 09/22/18 04:53 PM
Why people should change oil+filter!
by 53' Stude. 09/22/18 04:50 PM
Household lubricants (general purpose) differences
by 92saturnsl2. 09/22/18 04:35 PM
debris in my engine oil--what to do?
by Jasper8146. 09/22/18 03:50 PM
Is this seal bad?
by parshisa. 09/22/18 03:44 PM
Leather Masters Protection Cream review....
by gregk24. 09/22/18 03:13 PM
Aisin WS
by RodneyM. 09/22/18 03:11 PM
Husqvarna trimmer questions
by BrianF. 09/22/18 02:51 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
84 registered members (92saturnsl2, aquariuscsm, Ben Boyle, 53' Stude, A310, bdcardinal, 12 invisible), 1,534 guests, and 40 spiders.
Topics290,852
Posts4,851,452
Members66,044
Most Online3,590
Jan 24th, 2017
Idler and Pittman arm replacement question. #4464527
07/20/17 03:32 AM
07/20/17 03:32 AM
Colorado
Chris B. Offline OP
Chris B.  Offline OP
Colorado
A friend who is a ASE mechanic(and has a stellar reputation)helped me change out my old idler and pittman arms on my 97 GMC Sierra. He did not torque any of the bolts with a torque wrench and I'm just wondering if this should have been done? He said he has changed tons of them over the years and just zips everything together with the impact wrench or snugs them up with the ratchet and never has any problems. What are your thoughts on this. Are these parts sensitive to how tight you get the nuts and bolts tightened up? Thanks!
Re: Idler and Pittman arm replacement question. [Re: Chris B.] #4464530
07/20/17 03:40 AM
07/20/17 03:40 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
You don't need a torque wrench for chassis parts no. Just get them tight.
Torque wrenches are primarily for dealing with gaskets so that you get even compression.
Re: Idler and Pittman arm replacement question. [Re: Merkava_4] #4464576
07/20/17 06:13 AM
07/20/17 06:13 AM
New York
pbm Offline
pbm  Offline
New York
I agree...
'Journalism is Dead'
Re: Idler and Pittman arm replacement question. [Re: Chris B.] #4464696
07/20/17 09:02 AM
07/20/17 09:02 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I do torque the pitman arm nut on the steering box as its very tight and has a specific measurement (184 ft.lb) the rest no, some nuts are castellated nuts that use cotter pins on tapered shafts that you couldn't possibly use a torque wrench on anyway.
Re: Idler and Pittman arm replacement question. [Re: Chris B.] #4465045
07/20/17 02:47 PM
07/20/17 02:47 PM
Colorado
Chris B. Offline OP
Chris B.  Offline OP
Colorado
Appreciate it guys! So it there a way using an impact gun to get close to a certain torque setting? Say you wanted 80 ft-lbs on a 19mm lug nut. Can you use or set the gun to come some what close to that ft-lb range?
Re: Idler and Pittman arm replacement question. [Re: Chris B.] #4465148
07/20/17 04:18 PM
07/20/17 04:18 PM
Trav Offline
Trav  Offline
In fantasy land if you used the same gun, the same PSI every time, had clean fasteners every time and ran the impact say on its lowest setting for x amount of seconds then took a torque reading as a benchmark then maybe, realistically no way in Hades.
