Looking to replace 2005 Sienna with SUV
by i6pwr
06/23/18 07:26 PM
Trying to fix chainsaw
by turtlevette
06/23/18 06:48 PM
tire rotation
by marine65
06/23/18 06:48 PM
Reese hitch $30 Walmart YMMV
by pda1122
06/23/18 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
06/23/18 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
06/23/18 06:00 PM
New belt squeal cause damage to belt?
by pda1122
06/23/18 05:33 PM
Food Safety - If You Have Children
by Zee09
06/23/18 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
06/23/18 05:02 PM
Chain cleaning and lube
by dadinfo
06/23/18 04:57 PM
Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
06/23/18 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
06/23/18 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
06/23/18 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
06/23/18 04:30 PM
mobil 1 rebate check
by Fitter30
06/23/18 03:52 PM
Cab mount failure
by ram_man
06/23/18 03:31 PM
02 Saab aero oil?
by Newuser
06/23/18 03:00 PM
Extend wifi range
by clarkflower
06/23/18 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
06/23/18 01:57 PM
Lease Buyout by Dealer
by Throt
06/23/18 01:52 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
92 registered (69Torino, 14Accent, 2015_PSD, 93cruiser, 2004tdigls, 12 invisible), 1503 Guests and 62 Spiders online.
65303 Members
67 Forums
285875 Topics
#4464351 - 07/19/17 08:50 PM Good Blind Hole bearing puller set for the money?
SquirrelMan Offline
Loc: In
I noticed all the usa-made puller sets are around a hundred fifty bucks for starters. I like the cheaper 9 Piece sets that I see but I noticed the guys at work have cheaper sets and the steel doesn't seem to hold up well. Will be using it to pull bushings and punch hole buttons from die lowers. I would appreciate any good recommendations.
#4464420 - 07/19/17 10:06 PM Re: Good Blind Hole bearing puller set for the money? [Re: SquirrelMan]
L_Sludger Offline
Loc: Ohio
Harbor Freight has a cheap set that I think you can get replaced every time the puller teeth round off. At my old job working in quality engineering, I had to design a blind hole puller to remove bushings from steering racks that failed inspection and were to be reworked or torn down. It cost a small fortune to get a batch of them made at a machine shop. But we had to do it that way because Corporate's purchasing system had to use invoices from existing suppliers, and would not just give me a credit card to get the darn part from Harbor Freight for 1/20 of the price to start with. /rant off
Here's the set I was talking about: https://www.harborfreight.com/slide-hammer-and-bearing-puller-set-5-pc-62601.html
too many cars and oil combinations to list in 150 characters or less
#4464427 - 07/19/17 10:14 PM Re: Good Blind Hole bearing puller set for the money? [Re: SquirrelMan]
JMJNet Offline
Loc: TX, USA
I borrowed the one from the part store loan-a-tool program if you only need it once in a blue moon.
Edited by JMJNet (07/19/17 10:15 PM)
  • 2017 Toyota Sienna
#4464681 - 07/20/17 08:52 AM Re: Good Blind Hole bearing puller set for the money? [Re: JMJNet]
Ducked Offline
Loc: Taiwan
you people are spoilt.
#4464779 - 07/20/17 10:54 AM Re: Good Blind Hole bearing puller set for the money? [Re: SquirrelMan]
NYEngineer Offline
Loc: NY, NY
#4465258 - 07/20/17 05:58 PM Re: Good Blind Hole bearing puller set for the money? [Re: SquirrelMan]
SquirrelMan Offline
Loc: In
Thanks for the replies, I think the harbor freight set is a good set, but I am drawn more to a 9 Piece set like NYEngineer posted. I have been looking at that same set online. I think I will benefit from having 8 different sizes.
