ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
104 registered members (2whlgeezer, 2015_PSD, 53' Stude, 2012AccentSE, 15 invisible), 2,182 guests, and 62 spiders.
Topics286,159
Posts4,903,310
Members67,569
Most Online2,967
Mar 10th, 2019
Wood finishing advice #4464274
07/19/17 06:57 PM
07/19/17 06:57 PM
Greenville, SC via Chicago, IL
dja4260 Offline OP
dja4260  Offline OP
I'm making a "reclaimed" wood headboard for our bed, for my wife. The wood is weathered in various sizes.
I plan on lightly sanding the pieces and would like to do something so I don't get splinters or destroy the sheets, while retaining the woods natural wear/color.
Polyurethane, Varnish, Shellac?
The end result should be similar to below.
Before anyone asks. This is what my wife wants. Happy wife, happy life.
Thanks in advance!
2013 Hyundai Elantra Gt Hatch 6 spd
2005 Toyota Highlander V6
1997 HD Sportster
Re: Wood finishing advice [Re: dja4260] #4464287
07/19/17 07:09 PM
07/19/17 07:09 PM
out there
spasm3 Offline
spasm3  Offline
out there
Poly can yellow, since there is no heat, or real wear, I vote shellac. You could just coat it once, then sand down the raised spinters and coat it 2 more times.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: Wood finishing advice [Re: dja4260] #4464288
07/19/17 07:10 PM
07/19/17 07:10 PM
texas
danez_yoda Offline
danez_yoda  Offline
texas
Dewaxed shellac followed by a water based polyurethane.
The shellac will prevent the water based from raising the grain. Unless you want a rough finish the skip the shellac.
The difference between a water based poly and a oil based is that the oil based will turn yellow immediately and get yellower with time. Water based wont do that.
I recommend poly since it is tough. Shellac is nice since it is easy to repair but it is not as tough for applications that get rubbed on or brushed against frequently.
As with any finish, try it on some test pieces before you commit to make sure you like the result and to adjust the application technique.
With a round finish I would HIGHLY recommend spraying it.
Re: Wood finishing advice [Re: dja4260] #4464335
07/19/17 08:26 PM
07/19/17 08:26 PM
AZ
Killer223 Offline
Killer223  Offline
AZ
to keep the weathered look, splinters are likely, try and get the ones closest to the pillow area, then as stated before, water based EXTERIOR poly, as it's a harder finish. then several coats, you can do the first two, sand with 150/220, then do 2 more coats.
i've done a few of these and this method works great.
as for sanding get sanding sponges. wear those gloves that look like they were dipped in blue gripper stuff. helps protect fingers from wayward wood shards.
spraying would be ok, but brushed with a 3" SOFT brush, (purdy) brushed with the grain.
08 6.7 cummins G56
04 5.9 cummins
95 12V NV4500.
11 ranger 4.0
18 crf450RX
Re: Wood finishing advice [Re: dja4260] #4464340
07/19/17 08:31 PM
07/19/17 08:31 PM
Central Texas
sleddriver Offline
sleddriver  Offline
Central Texas
1. What species is it?
2. How "weathered"?
3. How dry is it?
Give it a good sanding with 220g, only with the grain due to it being 'reclaimed'. Bring indoors, put it under the bed for about 2 weeks with some sort of spacers to lift it off the floor. It needs to 'adapt' to indoor conditions. Could take longer depending on how wet it is, local humidity, indoor house humidity, etc.
Solvent based PU will stink for weeks indoors until fully cured. Water-base will raise the grain but won't stink. Shellac won't stink at all indoors, just be sure to finish ALL SIDES & ENDS with whatever finish you decide.
To knock-the-shine off any finish, you'll have to lightly sand after the final coat.
I'd suggest a coat or two of thinned shellac on all surfaces after an initial sanding and drying indoors. This will seal in any 'funk/mold/mildew' in the wood and provide a good base for the top coats.
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: Wood finishing advice [Re: sleddriver] #4464635
07/20/17 08:01 AM
07/20/17 08:01 AM
wv
krismoriah72 Offline
wv
Most of the furniture and most of my house is old barnwood..here is what we did.
https://fiveoeight.com/diy-barn-wood-headboard-part-two-sealing/
Re: Wood finishing advice [Re: dja4260] #4464675
07/20/17 08:47 AM
07/20/17 08:47 AM
wi
dave123 Offline
dave123  Offline
wi
Two coats 0to5 degree conversation varnish or 2k poly with a 25to 50% reduction.
Re: Wood finishing advice [Re: dave123] #4464768
07/20/17 10:41 AM
07/20/17 10:41 AM
MI
doitmyself Offline
doitmyself  Offline
MI
LOL, had to investigate that conversation varnish. Guess what? It exists!
http://www.paintanddesignstore.com/varnish-plus-satin-gallon/
Quote:
VarnishPlus is a water-based pre-catalyzed conversation varnish that meets or exceeds all USA standards for durability and chemical resistance as set forth by the Furniture, Kitchen Cabinet and Millwork Association. A beautiful, professional grade topcoat, VarnishPlus is the superior choice for finishing projects where top quality is important
