Honda ATF DW1 bottle stamp decoding
by parshisa
06/25/18 12:03 PM
How to lower throttle sensitivity?
by NICAT
06/25/18 11:41 AM
That's some service! (New Central AC...)
by xBa380
06/25/18 11:13 AM
Valvoline 2 Cycle TC-W3 Marine Oil - 6qt - $20
by Jimzz
06/25/18 10:45 AM
Plumbing/Bldg Experts: Cause of Wet Slab?
by LoneRanger
06/25/18 10:13 AM
How to CONFIRM the Country of Manufacture
by Ed_Flecko
06/25/18 09:58 AM
Replacing trans oil seal
by redhat
06/25/18 09:50 AM
VW diesels sitting in huge lots waiting......
by ZZman
06/25/18 09:09 AM
DTD/DT Independence Day Promos
by Sayjac
06/25/18 08:39 AM
It's AMSOILŪ, not Amsoil
by Rat407
06/25/18 06:39 AM
VW Passat 2007
by madRiver
06/25/18 06:18 AM
Review: CVJ Remanufactured CV Axles
by The Critic
06/25/18 03:40 AM
Towing without 85w140?
by OilFilters
06/25/18 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
06/24/18 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
06/24/18 11:13 PM
Darn dogs
by AZjeff
06/24/18 10:21 PM
New GC?
by Bullwinkle007
06/24/18 10:04 PM
The guy with the plexiglass head on you tube
by andyd
06/24/18 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
06/24/18 09:10 PM
SAE 90 v 85/140
by Knuckle078
06/24/18 09:10 PM
dhy808, ROD_Z, lozpxs, danthemanx07, FunktasticLucky
65319 Registered Users
84 registered (4WD, 69Torino, 77GrandPrix, 853okg, Aero540T, 6 invisible), 1622 Guests and 43 Spiders online.
65319 Members
67 Forums
285968 Topics
#4464222 - 07/19/17 05:17 PM Stick Welder for Extracting Broken Bolts
George7941 Offline
Loc: Toronto, Canada
My first time and it did not work out. As you can see, the broken bolt, which had originally broken flush with the end of the nut is on the left and the new nut/bolt combo I installed are on the right. What you see on the end of the broken bolt is the sheared weld where I had welded on a 3/4-10 nut on to the end of the broken bolt. The bolt is 3/4-10 and had been in place undisturbed for 11 years and I am in the rust belt with a lot of salt used in the winter.
I first tried 7018 and wasn't getting good penetration, so I switched to 6010 and the broken weld you see in the pictures was done with 6010. As you can see I was able to achieve a good weld on to the end of the broken bolt but it still wasn't enough to spin the bolt. The seized bolt was subjected to being welded on four times, so it was heated up pretty well four times and it still did not break loose.
Any thing I could have done better? I started off soaking the rusted bolt with acetone/atf over a few days and it did not help. I tried heating the nut/bolt with a propane rosebud tip running off a bar-b-q tank and that did not help. I did not have my oxy-acetylene set up with me, the bolt might have come off had I heated the nut/bolt white hot.
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
#4464261 - 07/19/17 06:40 PM Re: Stick Welder for Extracting Broken Bolts [Re: George7941]
Ducked Offline
Loc: Taiwan
I have not tried this yet, but candle wax is said to be a superior penetrating libricant when heated in situations like this. I've been told there is a specially made wax for the job but have never seen it.
#4464291 - 07/19/17 07:14 PM Re: Stick Welder for Extracting Broken Bolts [Re: George7941]
bioburner Offline
Loc: Minnesota
I would have tried laying on a bead on the nut itself to get it screaming red hot after welding the nut onto your stuck bolt and then giving the works oil to hopefully shock the bolt into submission. Maybe even drilling in from the top to get oil into the center. A few good beats with a heavy hammer while hot. Nothing like working on farm equipment for many years to get a few tricks.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
#4464337 - 07/19/17 08:29 PM Re: Stick Welder for Extracting Broken Bolts [Re: George7941]
SquirrelMan Offline
Loc: In
If you have access to a mill you can remove your weld with an End Mill and then you will be able to drill into the bolt either for easy out or drill and tap for next size up. I have actually taken a drill bit that is one or two tenths of a millimeter smaller than the diameter of the bolt and drilled it. All that is left is thin shell of threads and I clean them out with a tap. But you have to be perfectly centered(center bit) and have a good solid drill press or mill.
You could always try welding it again it looks like your existing weld did not weld to the sides any. I see clearance all the way around. We always use MIG welder at about 22V in our die repair shop. Place a nut over it, that's a little smaller than the bolt hole, that way you are protected from welding your sides up. Try to get 100% coverage inside the bottom of the nut and Fill it up with as hot of a weld as you can get away with without melting your nut away. We always let the weld cool for at least 30 seconds but it may help if you can heat the body(unit bolt is broke off in) up with a torch. You just don't wanna crank on that nut while the weld is still super hot. Then I just put a 12 or 15 inch adjustable wrench directly on the nut.
Edited by SquirrelMan (07/19/17 08:37 PM)
#4464356 - 07/19/17 08:58 PM Re: Stick Welder for Extracting Broken Bolts [Re: George7941]
tig1 Offline
Loc: Illinois
I have removed hundreds of broken bolts by welding, and IMO I would have just cut the long hex nut off from the beginning, and as you did weld a new nut on.
2007 Ford Fusion 227,000 miles
M1 0-20 EP
2017 Ford Fusion 49K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
#4464357 - 07/19/17 09:00 PM Re: Stick Welder for Extracting Broken Bolts [Re: George7941]
SquirrelMan Offline
Loc: In
There's a stick rod called TS-12 that loves to burn hot and penetrates well and is strong and an excellent choice for welding broken things back together. But it would also work well in this situation. TS-12 Tig filler Rods are even better.
A number 5 easy out can withstand more torque than most welded nuts. Welding nuts can work and does sometimes but I will always elect to drill for easy out first.
Edited by SquirrelMan (07/19/17 09:06 PM)
#4464359 - 07/19/17 09:01 PM Re: Stick Welder for Extracting Broken Bolts [Re: George7941]
AVB Offline
Loc: Georgia
IF it is seized bad enough drilling will be the only option. Welding removes the temper from the bolt and it will just ring off.
#4464385 - 07/19/17 09:28 PM Re: Stick Welder for Extracting Broken Bolts [Re: George7941]
justintendo Offline
Loc: northwest pa
as mentioned before, much easier to just remove and weld on new.
ive seen just a wax ring from a toilet bowl be used around the shop for penetration...surprising but seemed to work well
Edited by justintendo (07/19/17 09:37 PM)
2013 escape 2.0 awd
2008 fusion 2.3 mtx
1996 f150 4.9 2wd mtx
1999 kaw zrx 1100
many husqvarnas
#4464389 - 07/19/17 09:32 PM Re: Stick Welder for Extracting Broken Bolts [Re: George7941]
AVB Offline
Loc: Georgia
I know that crayons do not work, I don't know what kind of so called wax they use.
#4464641 - 07/20/17 08:10 AM Re: Stick Welder for Extracting Broken Bolts [Re: George7941]
pcoxe Offline
Loc: South Carolina
The nut just acts as a fence to prevent you from welding the broken bolt to the surrounding metal and becomes sort of a handle. During the actual welding, the bolt needs to become red hot. In doing so it tries to expand, and being confined by the surrounding metal, it deforms instead. When it cools down, it becomes smaller than the hole it's in and that's what makes it easy to remove. I think the reason it didn't work for you is that you didn't have much metal surrounding the broken bolt, and it expanded along with the bolt preventing the needed deformation. If it was in a larger piece of metal you probably would have been ok.
Edited by pcoxe (07/20/17 08:11 AM)
#4464663 - 07/20/17 08:36 AM Re: Stick Welder for Extracting Broken Bolts [Re: George7941]
motor_oil_madman Offline
Loc: Houston, Texas
Why not just grind that old one off and replace it like you already did? If you can weld a new one on, why not just do that instead of welding nuts on?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#4464828 - 07/20/17 11:50 AM Re: Stick Welder for Extracting Broken Bolts [Re: pcoxe]
George7941 Offline
That makes sense. As I mentioned in my post, the bolt got pretty hot four times, so I was expecting it to come off.
As to why I did not just replace the nut, two reasons
1) I wanted to gain some experience extracting broken bolts.
2) New nut entailed a trip to my fastener supplier. I had on hand a bolt I could have used had I been able to remove the broken bolt.
1987 BMW R80 - sold
2015 Honda CBR300R
