Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
A cool litttle Fall foliage site
by Papa Bear. 09/23/18 06:02 PM
Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Is Tiger back?
by gman2304. 09/23/18 03:51 PM
Castrol Edge Pro OE LLIV FE 0W20 for VW508
by BrandonT. 09/23/18 03:33 PM
Value of 90's stereo equipment
by wrcsixeight. 09/23/18 03:28 PM
Wisdom of BITOG'ers wanted- 19 Avalon Hybrid oil
by scion_xb. 09/23/18 02:36 PM
w116 300sd Mercedes Diesel HPR fuel
by Gito. 09/23/18 02:14 PM
Power Stop Wheel Bearing/Hubs?
by oilpsi2high. 09/23/18 01:37 PM
Dump the 30k ATF in the 17 Kia?
by 3Aone. 09/23/18 01:31 PM
Miata Aisin 6 speed question
by 10ecfarmer. 09/23/18 12:36 PM
Shortest time you owned a car?
by Corollaman. 09/23/18 12:21 PM
Winter tires pinned for studs, but without studs
by Corollaman. 09/23/18 12:12 PM
03 Accord V6 "needs" iridium plugs?
by columnshift. 09/23/18 11:40 AM
The_Money_Light, DALTRON0659, skippermatt, HondaTech250, SandCruzer
66047 Registered Users
115 registered members (Astro14, bbhero, Ablebody, 2010Civic, anndel, 12 invisible), 1,702 guests, and 42 spiders.
Topics290,904
Posts4,852,218
Members66,047
Most Online3,590
Jan 24th, 2017
Page 1 of 4 1 2 3 4
New S&W M&P 9mm Shield after 300 rounds #4464184
07/19/17 04:36 PM
07/19/17 04:36 PM
n.c.
gman2304 Offline OP
gman2304  Offline OP
n.c.
The first 200 rounds were the Winchester white box FMJ 115 grain. I'm ready to ship this defective [removed] back to S&W! Failing to eject, failing to fire, stovepipes, you name it! I tried 3 different magazines with the same results. This pistol is field stripped and cleaned after each range visit. My friend who owns the range and 2 of his employees said to send it back. It acted the same way when they fired it, and everybody critiqued the ones shooting..and no 'limp wristing' was going on, so I decided yesterday to send it back. But before I left the range, I decided to buy a box of Freedom munitions 9mm 115 grain reload bullets. It fired 50 rounds perfectly! I tried 50 rounds of Blazerbrass today with not a single hiccup. I guess this pistol just doesn't like the Winchester WB ammo. Has Winchester had some QC issues lately, because I had a problem with at least 1 bullet in almost every magazine I used.
Re: New S&W M&P 9mm Shield after 300 rounds [Re: gman2304] #4464193
07/19/17 04:44 PM
07/19/17 04:44 PM
Iowa
The_Eric Offline
The_Eric  Offline
Iowa
I could see that. WWB will run a little funky in my 1911 and Federal aluminum will run like garbage in my wife's M&P 9C, but perfectly fine in my Shield. Also, I'm pretty sure that WWB will run fine in my Shield- but it's been a while and I could be mixing up the 1911 and the Shield, but I am positive it centered around the WWB.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: New S&W M&P 9mm Shield after 300 rounds [Re: gman2304] #4464196
07/19/17 04:46 PM
07/19/17 04:46 PM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
Is this from the batch that was being sold super, super cheap very recently?
I learned my S&W lesson after buying a Smegma 9mm. Switched to German-made Sig Sauers and have cursed S&W's new plastic semi autos since.
too many cars and oil combinations to list in 150 characters or less
Re: New S&W M&P 9mm Shield after 300 rounds [Re: gman2304] #4464207
07/19/17 04:59 PM
07/19/17 04:59 PM
Utah, USA
28oz Offline
28oz  Offline
Utah, USA
My experience has been that WWB ammo is garbage (mostly accuracy issues and fouling). I much prefer Federal...........or just about anyone else. However, I would expect my weapon to cycle regardless. I'd send it back.
1990 Nissan 300zx - Castrol Edge Euro 0W-40
2004 Nissan Quest - Pennzoil Platinum Euro 0W-40
2003 Ford Excursion 7.3 PSD - Mobil 1 TDT 5w-40
Re: New S&W M&P 9mm Shield after 300 rounds [Re: L_Sludger] #4464216
07/19/17 05:06 PM
07/19/17 05:06 PM
n.c.
gman2304 Offline OP
gman2304  Offline OP
n.c.
Yes, with the S&W $75 rebate I ended up paying roughly $215 for the 9mm Shield. After shooting the last 100 rounds perfectly, with 2 different brands of ammo, actually cheap ammo, I'm thinking it's the WWB rather than the pistol. I have 250 rounds coming from Freedom munitions, so time will tell.
Re: New S&W M&P 9mm Shield after 300 rounds [Re: gman2304] #4464236
07/19/17 05:40 PM
07/19/17 05:40 PM
Hollister, CA
Sunnyinhollister Offline
Hollister, CA
Sounds like the M&P 9mm Shield a friend of mine got. Same symptoms. He has already sent it back once and it's still doing the same thing. He has to send it back again. He's tried different magazines, different ammo, and still gets the same results.
2017 Ram 1500 Regular Cab 4x2 5.7L 8spd
2017 Chevy Bolt
2013 Honda CR-V AWD EX-L W/Nav
Re: New S&W M&P 9mm Shield after 300 rounds [Re: gman2304] #4464243
07/19/17 05:50 PM
07/19/17 05:50 PM
MA.
Camprunner Offline
Camprunner  Offline
MA.
At one time WWB was an excellent low cost FMJ practice ammo but times change and I hear it has many issues. As for your M&P Shield the pistol as a whole is extremely reliable I have many friends that have them including myself all of us have between 1,000-3,400 rounds fired and only one has had some issue when new but after aprox 250 rounds it seems to work fine. S&W has real good customer support so if you do have an issue Smith will fix it.
Never trust a new gun for carry shoot at leased 300 rounds threw it before you trust it I don't care who builds it!
Re: New S&W M&P 9mm Shield after 300 rounds [Re: gman2304] #4464252
07/19/17 06:17 PM
07/19/17 06:17 PM
MO
FirstNissan Offline
FirstNissan  Offline
MO
When I first bought my Glock 19, I ran WWB through it with multiple issues. Switched to most any-other brand and have not had a hiccup since! I refuse to buy WWB anymore, I don't trust it one bit.
2017 Toyota Sienna (Hers)
2017 Toyota Sienna (His)
Re: New S&W M&P 9mm Shield after 300 rounds [Re: gman2304] #4464320
07/19/17 07:59 PM
07/19/17 07:59 PM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
Originally Posted By: gman2304
The first 200 rounds were the Winchester white box FMJ 115 grain. I'm ready to ship this defective @#%^& back to S&W! Failing to eject, failing to fire, stovepipes, you name it! I tried 3 different magazines with the same results. This pistol is field stripped and cleaned after each range visit. My friend who owns the range and 2 of his employees said to send it back. It acted the same way when they fired it, and everybody critiqued the ones shooting..and no 'limp wristing' was going on, so I decided yesterday to send it back. But before I left the range, I decided to buy a box of Freedom munitions 9mm 115 grain reload bullets. It fired 50 rounds perfectly! I tried 50 rounds of Blazerbrass today with not a single hiccup. I guess this pistol just doesn't like the Winchester WB ammo. Has Winchester had some QC issues lately, because I had a problem with at least 1 bullet in almost every magazine I used.
Lots of pistols don't like the White Box. Always start-off new handguns with round nose FMJs and better-yet check out S&W Gun Forums to see what the model likes best, prior to your first ammo purchase.
She's the only sister-in-law I have. But she's not my favorite.
Re: New S&W M&P 9mm Shield after 300 rounds [Re: gman2304] #4464332
07/19/17 08:25 PM
07/19/17 08:25 PM
Elizabethtown, Pa
Al Offline
Al  Offline
Elizabethtown, Pa
It should eat every type of ammunition period.If it that picky something is wrong. It may be that it was just a tight fit and it needed to wear in. My G42 chocked on every 3rd round I have gone through almost 2000 rounds without aj hickup, That includes 1000 rounds of TulAmo.
Shields have a great reputation. I had one and my son still does. Neither of them have had an issue. Go back to the other Ammo and if it chokes on that again send it back my 3 Glocks and Ruger LCP eat anything so should the Shield.
The Limp Wrist thing os over-rated IMHO. Has to be really bad to cause it to fail to eject.
Re: New S&W M&P 9mm Shield after 300 rounds [Re: gman2304] #4464422
07/19/17 10:09 PM
07/19/17 10:09 PM
Ohio
jjjxlr8 Offline
jjjxlr8  Offline
Ohio
The only "Winchester White Box" ammo that you want is the NATO spec stuff with all black text. That ammo is consistent. The [censored] with the red text that you find at Walmart is not consistent at all.
1993 Toyota MR2 Turbo
2008 Mazdaspeed3
2014 Toyota Highlander XLE
Re: New S&W M&P 9mm Shield after 300 rounds [Re: gman2304] #4464446
07/19/17 10:42 PM
07/19/17 10:42 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
I have a Ruger P 95 I had to send back twice for proper repair. Finally they replaced the slide and It ran 4,000 rounds with out clean only lubing. I had to clean it because it was oozing crud and ruined 3 Tee shirts. crush It is a gun I love to hate. But it works well. [email protected] will fix it.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: New S&W M&P 9mm Shield after 300 rounds [Re: gman2304] #4464470
07/19/17 11:15 PM
07/19/17 11:15 PM
midland tx
askani79705 Offline
askani79705  Offline
midland tx
I've been feeding mine Stand 1 FMJs and Underwood Ammo's HPs both XTP and Gold Dot with good results.
Best place for 10mm btw.
2017 Ford F150 NAPA syn 5w30 Fram 11955.
2000 Chevy 2500 Silverado PYB 5w30 AC Delco Filter
Re: New S&W M&P 9mm Shield after 300 rounds [Re: gman2304] #4464726
07/20/17 09:27 AM
07/20/17 09:27 AM
OR, USA
bsmithwins Offline
bsmithwins  Offline
OR, USA
As they say, 'There's your problem!'
As far as Winchester's ammunition quality getting worse recently, I don't think that's correct. Winchester has been disappointing me for almost 30 years. After enough times getting burned you quit sticking your hand in the fire.
BSW
Re: New S&W M&P 9mm Shield after 300 rounds [Re: gman2304] #4464728
07/20/17 09:30 AM
07/20/17 09:30 AM
Mahzurrah!
KCJeep Offline
KCJeep  Offline
Mahzurrah!
I too have had some issues with WWB. It is hit and miss because some I have had has been great (the good stuff was mostly .40 caliber for some reason).
For range ammo I really like PMC, Blazer Brass, Fed Eagle or even Freedom Munitions all of which is as cheap or cheaper and does not give me any problems.
If your Smith runs reliably on everything else I think you have your answer.
09 Lincoln MKZ AWD 97k - M1 AFE 0w30
12 KIA Sedona 91k - PP HM 10w30
09 Ford Focus 131k - Supertech FS HM 5w30
00 Chev Lumina 201k - Supertech FS HM 5w30
04 Jeep Grand Cherokee gone but not forgotten.
Page 1 of 4 1 2 3 4
