Toys - My work is my play
Originally Posted By: NGRhodes
The blue and white one sure looks nice !
There are 2 diff Blue and white schemes, here, but the first one has the electric/ removable hard top is probably the coolest one to my mind simply because of that feature.
It also had heated seats.
Every one of the pleasure versions built to date is currently in Germany clustered in the North used on the Baltic sea so they need weather protection.
The yellow boat in the vid currently has a 1300 in it and will exceed 125 Mph which in a 28ft V hull is extremely impressive.
Either raw water, or a through a heat exchanger.
Usually salt water boats run a closed loop where a fresh water boat often won't bother with an auto style recirculation pump
There is a specialized pump on marine engines that pulls the water up through the drive into the engine called a sea pump.
There are often 2-3 stages for plumbing through the blower, oil cooler, and or ps cooling
oil coolers are water based.
limit depends on the engine design but generally 260.
UD
