Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
22 registered members (billt460, Donald1953, barryh, 53' Stude, Char Baby, bbhero, 2 invisible), 823 guests, and 41 spiders.
Topics295,007
Posts4,925,899
Members66,664
Most Online2,553
Oct 27th, 2018
Will my motorcycle blow up overnight?? #4463495
07/19/17 02:04 AM
07/19/17 02:04 AM
Washington
Jon130 Offline OP
Jon130  Offline OP
Washington
So.... I've read that people use Valvoline VR1 in their bikes. Valvoline says to use their motorcycle oil. I just put on a fresh K&N oil filter and poured in 4 quarts of Valvoline VR1 10W-30 into my 1989 GSX-R750. Let's see if the clutch slips. Let's see how it compares to the Mobile 1 4T oil that it replaced.
Re: Will my motorcycle blow up overnight?? [Re: Jon130] #4463497
07/19/17 02:11 AM
07/19/17 02:11 AM
Washington
Jon130 Offline OP
Jon130  Offline OP
Washington
I will note that the used Mobile 1 4T, despite being in the bike for over a year, having over 6k miles, having the bike backed into in Seattle twice, and being flooded so bad that I had to drain the water out of 2 of the 4 carb float bowls, looked perfectly clean and there was zero (0, Nada, none) metal on the magnetic drain plug. Will cut the oil filter tomorrow and share results. Planning to update semi-regularly with how this non-synthetic dino f&#k juice stands up to expensive synthetic bike oil.
I ride my bike like I'm racing on the daily. Mobile 1 made it look like I'm a grandma. How will the 10w-30 not-for-motorcycles compare?
Re: Will my motorcycle blow up overnight?? [Re: Jon130] #4463501
07/19/17 02:20 AM
07/19/17 02:20 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
No.
This is, by the way, the Standard Automatic Always 100% Correct answer to any headline or forum topic post poised as an Answer written in the form of a question.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Will my motorcycle blow up overnight?? [Re: Jon130] #4463536
07/19/17 04:23 AM
07/19/17 04:23 AM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
Why did you use 10W30?
Re: Will my motorcycle blow up overnight?? [Re: Jon130] #4463552
07/19/17 04:50 AM
07/19/17 04:50 AM
Vienna, Austria
alex_at Offline
alex_at  Offline
Vienna, Austria
Originally Posted By: Jon130
.....looked perfectly clean and there was zero (0, Nada, none) metal on the magnetic drain plug. Will cut the oil filter tomorrow and share results. Planning to update semi-regularly with how this non-synthetic dino f&#k juice stands up to expensive synthetic bike oil.
Looking forward to the updates.
You had not even metal dust on the magnetic drain plug? How was it with other oils?
I don't get the last sentence, you ride your bike hard daily, but Mobil 1 did what?
Re: Will my motorcycle blow up overnight?? [Re: alex_at] #4463674
07/19/17 07:23 AM
07/19/17 07:23 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
I think he means that the apparent lack of engine damage makes it look like he's not riding close enough to the screaming edge.
Most bikers have crashes to establish such credentials, we don need no steenkeeng metal dust stylee
Re: Will my motorcycle blow up overnight?? [Re: Jon130] #4463675
07/19/17 07:23 AM
07/19/17 07:23 AM
n.c.
gman2304 Offline
gman2304  Offline
n.c.
I've used conventional 20w50 Vr1 in my Harley's for several years. 3,000 mile OCI's. Three separate holes for engine, trans, and primary. My magnetic oil drain plug has no visible metal particles at all, not even a grey film on it. YMMV as Harley's don't have a shared sump. Let us know how it affects your clutch action.
Re: Will my motorcycle blow up overnight?? [Re: Jon130] #4463714
07/19/17 07:54 AM
07/19/17 07:54 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
You're not really any different than most other sport bike riders.
You won't blow up your bike. ZX-6R's and other 14,000 RPM bikes have been around since the late 80's and didn't blow up with the lousy oils we had back then, either.
Re: Will my motorcycle blow up overnight?? [Re: Jon130] #4463812
07/19/17 09:25 AM
07/19/17 09:25 AM
New York
jeff78 Offline
jeff78  Offline
New York
I'm running VR1 SAE 40 in a Yamaha - no clutch slip. I'm at 2500 miles on the oil and the transmission still shifts brilliantly. Many other (multigrade) oils would have gone notchy by this point. Very impressed with monograde VR1 - as it has no VII's to shear I expect shifting quality to be more or less unchanged throughout the entire OCI (I'll probably change at 4K miles).
On an air/oil cooled GSXR I would not go lower than a xW-40, especially not in summer. These bikes run their oil very hot. It's not unusual to hear owners changing to 20W-50 for summer.
Re: Will my motorcycle blow up overnight?? [Re: Jon130] #4463923
07/19/17 11:11 AM
07/19/17 11:11 AM
The Canyons
02SE Offline
02SE  Offline
The Canyons
Yep, those old oil-boilers run hot. In my old FJ1200, (another hot running bike) I ran 20w-50 for the best summertime results.
Re: Will my motorcycle blow up overnight?? [Re: Jon130] #4464157
07/19/17 03:16 PM
07/19/17 03:16 PM
Washington
Jon130 Offline OP
Jon130  Offline OP
Washington
I chose the 10w30 based on a choice between 10W-30 and 20W-50. Truly, my only concern is the 30 weight vs. the recommended 40. I'm likely going to change the oil at the end of the summer and possibly have an analysis done.
I'm not sure what had been in the bike when I got it, but it came out chunky and there was a lot if fine metal in the drain plug. Not ideal.
The Mobile 1 10W40 4T came out looking dark but nowhere near as dark as anything I've drained from a car. Otherwise, it appeared and felt the same as it went in. I was surprised by the absolute lack of metal on the drain plug. I cleaned it on a white towel and looked at it in bright light just to be sure. Nothing. I'm going to cut into my filter today, but the Mobile 1 seems to work very well. Still, I'm not a huge fan of the $40 oil change.
So, with that in mind, I'm going to see how the VR1 does. It's close to the upper end of the temperature range for using the 10W-30 here. I believe the Suzuki manual says that 96 degrees F is the upper limit for using 10w-30. Given that my bike lives at 8k to 11k rpm, this should be a proper stress test.
Re: Will my motorcycle blow up overnight?? [Re: Jon130] #4464190
07/19/17 03:42 PM
07/19/17 03:42 PM
Washington
Jon130 Offline OP
Jon130  Offline OP
Washington
20-50 in summer? I would have thought that would be too heavy for a gixxer. Small oil passages, tight clearances, yada yada.
Re: Will my motorcycle blow up overnight?? [Re: Jon130] #4464226
07/19/17 04:23 PM
07/19/17 04:23 PM
The Canyons
02SE Offline
02SE  Offline
The Canyons
Do you have your owners manual? If so, it will show the acceptable viscosity oils for various ambient temperature ranges. In short, 20w50 is fine for use from IIRC, 14F on up.
Re: Will my motorcycle blow up overnight?? [Re: Jon130] #4464268
07/19/17 05:48 PM
07/19/17 05:48 PM
New York
jeff78 Offline
jeff78  Offline
New York
There's always the monograde SAE 40 VR1. Not having a W rating doesn't matter in the summer, and you'd get the benefit of no shearing.
Yeah, sounds like a bit of neglect by the previous owner, but it also sounds like the Mobil 1 did a good job cleaning it up.
Valve clearance checks on these are every 3000 miles IIRC, so it won't be too long before you'll need to open up the valve covers and take a look inside anyway.
Re: Will my motorcycle blow up overnight?? [Re: jeff78] #4468019
07/23/17 12:13 PM
07/23/17 12:13 PM
Washington
Jon130 Offline OP
Jon130  Offline OP
Washington
Good call on the valve clearances. I should probably get on that sooner than later, maintenance unknown and all.
The bike was completely restored and painted at some point. I actually work with a guy who claims to have contributed to that effort. Since that time, it has seen some neglect.
I took the body and fuel system apart over the weekend to replace the fuel lines and vacuum line. I noticed the float bowl breathers had no lines and were just open in an upright position at the carbs. Crankcase breather? Yeah, just a gaping hole. The rear subframe was held on with 3 of 6 bolts, two of which with damaged threads. The truly special treat was a previous owners electrical projects that left all unused connections fully exposed, rear led turn signal resistors melted into the rear upper fender, and an oil pressure idiot light connector just dangling free with no bulb. Clearly a master mechanic at work. All corrected now with the exception of OEM bolts and light bulb on order.
The bike seems to run just fine on the VR1. The clutch and shifting are noticeably smoother, though that's normal for an oil change. My girlfriend just got her endorsement and we are practicing and wrenching every spare minute, so it doesn't look like I'll be having any high-rpm fun in the short term.
