When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
124 registered members (01rangerxl, 2015_PSD, 2K2AcuraTL, 2009Edge, 15 invisible), 2,039 guests, and 60 spiders.
Topics286,160
Posts4,903,335
Members67,569
Most Online2,967
Mar 10th, 2019
Please school me on changing a tire on a lawn mowr #4463300
07/18/17 08:51 PM
07/18/17 08:51 PM
Marshfield , MA
andyd Offline OP
andyd  Offline OP
Marshfield , MA
I have a new tube in the old tire and cannot get the outside bead back under the edge of the rim. It is a 6" wheel. TIA
Thick oil is better grin2
Re: Please school me on changing a tire on a lawn mowr [Re: andyd] #4463308
07/18/17 08:57 PM
07/18/17 08:57 PM
Indiana
5AcresAndAFool Offline
Indiana
Harbor freight sells a manual tire changing rig fairly cheap, Its perfect for mower tires. It makes the job a lot easier, but you can do it with several screwdrivers, just be careful not to puncture the inner tube.
Generally I use about 3 tire spoons to get the tire on if I am doing without the tire changing rig.
Re: Please school me on changing a tire on a lawn mowr [Re: andyd] #4463314
07/18/17 09:01 PM
07/18/17 09:01 PM
Georgia
AVB Offline
AVB  Offline
Georgia
I just when through that ordeal myself. I have one of the HF tire changers, for a 6" wheel I only use it to break the bead. I punctured two tubes trying to get the tire back on my mower this spring. Finally, I just put the tire on without the tube and just stuffed the tube into the mounted tire.
Re: Please school me on changing a tire on a lawn mowr [Re: andyd] #4463316
07/18/17 09:03 PM
07/18/17 09:03 PM
Pittsburgh, Pa
Fastcompany Offline
Fastcompany  Offline
Pittsburgh, Pa
+1 on the harbor freight small tire changer. Very cheap and works great. And also for tubes so they don't pinch when inflating them I put baby powder all over the tube. Otherwise it can bunch up and tear itself when you add air. If it's an old junky looking wheel you can use several pairs of vise grips to hold the bead down as you work around the wheel.
Re: Please school me on changing a tire on a lawn mowr [Re: andyd] #4463327
07/18/17 09:12 PM
07/18/17 09:12 PM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
Youtube has several clips to choose from. I have a set of motorcycle tire irons that are useful when I tube the old tires on my riding mower.
07 Focus ZXW, 5spd manual, 230km M1 5W30
18 Outback 2.5 CVT 22km 0W20
Re: Please school me on changing a tire on a lawn mowr [Re: andyd] #4463335
07/18/17 09:18 PM
07/18/17 09:18 PM
Marshfield , MA
andyd Offline OP
andyd  Offline OP
Marshfield , MA
Thank you all for prompt response. I'm gonna try vise grips. The nearest HF is 25 miles away. I try to stay out of them because I am always shy a tool. I'm in need of a corded sawzall, and a cordless drill/driver. Arrgg!
Re: Please school me on changing a tire on a lawn mowr [Re: andyd] #4463337
07/18/17 09:20 PM
07/18/17 09:20 PM
Indiana
Indiana
Also, If you use the HF Tire changer, buy a jug of lube from napa. Its made specifically for mounting tires.
Re: Please school me on changing a tire on a lawn mowr [Re: 5AcresAndAFool] #4463342
07/18/17 09:25 PM
07/18/17 09:25 PM
Kansas
Kruse Offline
Kruse  Offline
Kansas
The stuff is call RuGlyde and the gallon jugs are somewhat expensive for just one application. A lot of tire jockeys just use a small amount of dish soap, not saying that it's the proper item to use.
Re: Please school me on changing a tire on a lawn mowr [Re: andyd] #4463352
07/18/17 09:30 PM
07/18/17 09:30 PM
Georgia
AVB Offline
AVB  Offline
Georgia
Ruglide helps, but it really is too thin. At least the jug I have is.
You can also use Murphy's oil soap to mount the tire. Murphy's also makes tire soap. Last time I went to HF I bought another one of their 18" tire irons and left the dang thing in the buggy. I overlooked the silver tire iron in the silver buggy when I was loading the truck. It was only about $8 but HF is over an hour away.
Small tires are a pain. I worked on big trucks for a couple of years 22" tires are super easy, 17.5" trailer tires will make me walk away after a lot of cussing and sweating.
Re: Please school me on changing a tire on a lawn mowr [Re: andyd] #4463354
07/18/17 09:30 PM
07/18/17 09:30 PM
N.C.
gman2304 Offline
gman2304  Offline
N.C.
Motorcycle tire irons, dish detergent, beer, band aids.
Re: Please school me on changing a tire on a lawn mowr [Re: andyd] #4463358
07/18/17 09:33 PM
07/18/17 09:33 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I've never done a garden tractor tire, but I've done plenty of motorcycle tires by hand. A proper set of tire irons are a huge help, and like others mentioned, make sure to use plenty of lube! I have never used proper tire lube, have always used diluted dish soap and have not had any issues so far. Good luck!
Re: Please school me on changing a tire on a lawn mowr [Re: gman2304] #4463376
07/18/17 09:50 PM
07/18/17 09:50 PM
Kansas
Kruse Offline
Kruse  Offline
Kansas
Yep, yep, yep, yep, but not always in that exact order.
Re: Please school me on changing a tire on a lawn mowr [Re: gman2304] #4463425
07/18/17 10:47 PM
07/18/17 10:47 PM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
This is a job I can definitely do myself, and always bring to the local tire shop. They charge $5 extra for small wheels. Why? I didn't even get a chance to ask them why, they told me they're a PITA.
I pay the money, and happy to do so.
Various musings: http://hangfire.net
Re: Please school me on changing a tire on a lawn mowr [Re: andyd] #4463491
07/19/17 02:42 AM
07/19/17 02:42 AM
Southeastern USA
FowVay Offline
FowVay  Offline
Southeastern USA
I think the trick is to keep the two tire beads as close together as possible as you spoon the bead over the wheel.
Use a lubricant such as Ruglyde and apply it liberally. Work the first bead over the wheel lip. This part goes fairly easy.
Powder up the innertube (if you're using an innertube) using baby powder to help it move about freely and insert it into the wheel at this point. I always put a bit of air into the tube so that it's straight and not bunching up. I do this to reduce the possibility of pinching it. Get the valve stem in place and keep everything loose.
And finally, lube the opposite bead of the tire and start working it over the wheel rim. This is where I use a big zip tie and sinch the beads together once I've gotten a section of both beads onto the wheel. Take small bites with your tire iron and try to keep things flat on the floor. Those tiny 6" wheels are as wide as they are round so it's like humping a basketball but you just have to go slow.
I strongly suggest using tire irons as opposed to using screw drivers since the ends are blunt/rounded and greatly reduce the risk of damage as opposed to a sharp, flat screwdriver.
That's about it - small bites and keep the beads together. Once the tire is over the lip you can cut the zip-tie out and discard it. Inflate the tire to seat the bead and you're done.
Re: Please school me on changing a tire on a lawn mowr [Re: HangFire] #4463568
07/19/17 06:23 AM
07/19/17 06:23 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
I'm with you. I watched a friend of mine 'try' to do it once with a screwdriver. An exercise in frustration to put it mildly. After that, when I needed one done, took it to a local shop and let them do it. Cost of tire included the change and seemed reasonable to me. If and when ever need it again, I'll do the same.
