dash cam
by DAC2018
06/24/18 05:08 AM
WoO driver Jason Johnson injured
by bdcardinal
06/24/18 01:08 AM
Plastic burning smell when WOT
by Jaha24k
06/24/18 12:57 AM
Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
06/24/18 12:00 AM
Ruger LCP .380
by PW01
06/23/18 11:24 PM
Launching boat with stick shift
by troutfisher
06/23/18 11:22 PM
Free oil
by Spitter
06/23/18 10:53 PM
Porsche Panamera buying advice
by CharlieBauer
06/23/18 10:04 PM
RC cars
by red7404
06/23/18 09:36 PM
Any Good 4K Movies ?
by Warstud
06/23/18 09:06 PM
Gray on Oil Dipstick?
by chinee
06/23/18 08:41 PM
Clear plastic scratch remover?
by Quattro Pete
06/23/18 08:15 PM
Parking wars show.
by Chris142
06/23/18 08:15 PM
set for years
by 93cruiser
06/23/18 08:07 PM
Looking to replace 2005 Sienna with SUV
by i6pwr
06/23/18 07:26 PM
Trying to fix chainsaw
by turtlevette
06/23/18 06:48 PM
tire rotation
by marine65
06/23/18 06:48 PM
Reese hitch $30 Walmart YMMV
by pda1122
06/23/18 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
06/23/18 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
06/23/18 06:00 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
26 registered (Atesz792, bbhero, Brad_C, Cujet, 4 invisible), 789 Guests and 36 Spiders online.
65303 Members
67 Forums
285890 Topics
#4463089 - 07/18/17 04:59 PM Mercon LV
Whimsey Offline
Loc: The Garden State
After my wife's dealer refused to to a drop and fill on her 2017 Explorer, only do transmission flush or a transmission case spit I purchased 12 quarts from Rock Auto for $5/quart delivered. The dealer did me a favor and saved me money because with her 2.3 EcoBoost engine it's real easy to change the ATF via drain and fill. I'll do it cold so I can measure what came out and I'll put what goes back in.
Whimsey
#4463101 - 07/18/17 05:15 PM Re: Mercon LV [Re: Whimsey]
buck91 Offline
Loc: West Michigan
Sounds good. Assuming its pretty much the same as our '14 Explorer with the 3.5L Eco. A simple and well placed drain plug. Hardest part is moving the air cleaner out of the way of the fill neck!
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
#4463118 - 07/18/17 05:34 PM Re: Mercon LV [Re: buck91]
Kira Offline
Loc: Champlain/Hudson Valley
A 2017 is a relatively new vehicle. Is there a reason you wanted to do a D&F other than "cleaner is better"?
#4463141 - 07/18/17 06:01 PM Re: Mercon LV [Re: Whimsey]
Taildragger Offline
Loc: SW Florida
Does Mercon LV interchange with Mercon V ?
04 F-150 5.4
73 Big Block, 4sp Corvette
15 Mazda 3
Couple of airplanes
#4463142 - 07/18/17 06:02 PM Re: Mercon LV [Re: Kira]
Whimsey Offline
No, other than earlier ATF changes is cheap maintenance to get you to high mileage. We keep our vehicles for more than 10+ years. I don't want to spend the money for a new transmission late in it's life, if changing it keeps it alive. I'm driving her old 2005 4.6 Explorer with 194,000 miles. It shifts great with the original transmission with ATF changes every 20,000-30,000 miles, initial one done early. You do what ever you feel comfortable with. For me it's cheap insurance since I keep my vehicles a long time, to each their own.
Whimsey
#4463145 - 07/18/17 06:07 PM Re: Mercon LV [Re: Taildragger]
Whimsey Offline
No it doesn't, totally different ATF fluid. The Mercon LV is for their newer transmissions. You can't use it for Mercon V or Mercon rated transmissions.
Whimsey
#4463147 - 07/18/17 06:08 PM Re: Mercon LV [Re: Whimsey]
CT8 Offline
Loc: Idaho
Gets the metal out. New parts break in produce the highest metal per mile.
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4463166 - 07/18/17 06:30 PM Re: Mercon LV [Re: Whimsey]
tig1 Offline
Loc: Illinois
Last week I did a D&F on my 2017 Fusion. Used MC LV. Also had to remove the air box, which took about 10 Min. 3 1/2 qts came out cold.
Edited by tig1 (07/18/17 06:31 PM)
2007 Ford Fusion 227,000 miles
M1 0-20 EP
2017 Ford Fusion 49K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
#4463182 - 07/18/17 06:54 PM Re: Mercon LV [Re: buck91]
Whimsey Offline
I'm lucky with this 2.3 EB because the ATF fill is out in the open without moving any engine compartment pieces. Seriously this engine is a piece of cake to change the oil and filter plus changing the transmission fluid. It has no under body shield. It's lot easier than the 2005 4.6 Explorer I inherited from her which also doesn't have a under body shield but is a real pain in the butt to service grin.
Whimsey
#4463189 - 07/18/17 06:58 PM Re: Mercon LV [Re: Whimsey]
buck91 Offline
Loc: West Michigan
Whimsey
Shouldn't need to be that aggressive with atf intervals and Mercon LV. I did mine for the first time at 80k on my F150 and was very comfortable with that. Had a UOA done at about half that mileage indicating plenty of time left on the fluid.
2011 F150 4x4 5.0L
#4463320 - 07/18/17 09:07 PM Re: Mercon LV [Re: Whimsey]
SilverFusion2010 Offline
Loc: Crawfordville FL
I had Valvoline MAXLife LV in mine and did a drain and fill with licensed Mercon LV to make me sleep better at night. It probably would have been fine but with licensed motorcraft fluid I know it will be good for 80k or so
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
