Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
540 RAT
by elpcmaster. 03/21/19 09:18 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
2001 CRV no restart when hot
by Kurtatron. 03/21/19 07:27 AM
Amazing human feats - free-diving...
by Shannow. 03/21/19 04:59 AM
How long to warm-up an engine?
by OilUzer. 03/21/19 04:58 AM
Disappearance and appearance
by bbhero. 03/21/19 04:38 AM
Big Changes for WIX 51334 - Pics
by tony1679. 03/21/19 04:26 AM
Supertech Synthetic Data Sheets
by The Critic. 03/21/19 04:25 AM
Forester XT filter recommandation
by jbutch. 03/21/19 04:23 AM
Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
AlanGonzales, Jrealstreeter, DarkFrontier, Zuraxus, Burks21
67574 Registered Users
104 registered members (addyguy, 2012AccentSE, arowbat, Anduril, ArrestMeRedZ, 901Memphis, 11 invisible), 1,903 guests, and 60 spiders.
Topics286,185
Posts4,903,766
Members67,574
Most Online2,967
Mar 10th, 2019
Kohler command corrosion #4462748
07/18/17 11:21 AM
07/18/17 11:21 AM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
This just isn't my week. I went to buy a hobart elite welder generator off someone on Craigslist. It was supposed to 6 months old, then I looks at the engine code and it's from like 2014. The cover on the machine is all scratched. What has me worried was all the aluminum oxide corrosion on all the cooling fins, which I guess can be washed off, but I've never seen that much corrosion before, even on an older engine that gets rained on all the time.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Kohler command corrosion [Re: motor_oil_madman] #4462751
07/18/17 11:23 AM
07/18/17 11:23 AM
Houston, Texas
Houston, Texas
Is that a kohler thing? Even the governor spring had corrosion.
Re: Kohler command corrosion [Re: motor_oil_madman] #4462766
07/18/17 11:34 AM
07/18/17 11:34 AM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
Did you already buy it? If the seller lied about the age, they will probably lie about the maintenance.
Corroded aluminum is a outdoor storage thing, not a Kohler thing. My Kohler 27HP is blown off with a leaf blower after every use, and stored inside. It's 10 years old. It is just starting to show a little corrosion.
Re: Kohler command corrosion [Re: motor_oil_madman] #4462767
07/18/17 11:38 AM
07/18/17 11:38 AM
Columbus Nebraska
old1 Offline
old1  Offline
Columbus Nebraska
The engine could have been built in 2014, and not sold to the consumer that sold it to you till 6 month ago. The corrosion thing is probably due to the area/conditions which it was stored in either the distributor, or dealer. If you clean it up, it may not come back.
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 15/40 Delo
1929 ford model A No filters, and 15/40 oil
Re: Kohler command corrosion [Re: motor_oil_madman] #4462772
07/18/17 11:40 AM
07/18/17 11:40 AM
Florida
Ausfahrt Offline
Ausfahrt  Offline
Florida
Did you buy it?
'14 Subaru Crosstrek MT 70k
'15 Tacoma 4x4 MT 30k
'03 Camry AT 148k
'07 BMW R1200GSA 71k
'98 Electra Glide 52k
Re: Kohler command corrosion [Re: Ausfahrt] #4462794
07/18/17 12:15 PM
07/18/17 12:15 PM
Houston, Texas
Houston, Texas
Originally Posted By: Ausfahrt
Did you buy it?
No
Re: Kohler command corrosion [Re: motor_oil_madman] #4462803
07/18/17 12:23 PM
07/18/17 12:23 PM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
+1 on the machine being stored before sold. Sometimes the engine date codes are a year older than the machine itself, depending on how long before assembly the manufacturer purchases the engine from Kohler.
I remember walking through a few equipment dealers where the mowers/engines were 1+ year old since they don't sell as much volume as the big box stores.
The corrosion is from being stored outside in the weather.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (38k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Kohler command corrosion [Re: jeepman3071] #4462805
07/18/17 12:28 PM
07/18/17 12:28 PM
Houston, Texas
Houston, Texas
Yeah. I figured although it's odd since the whole generator/welder has an enclosed sound shield.
Re: Kohler command corrosion [Re: motor_oil_madman] #4462816
07/18/17 12:35 PM
07/18/17 12:35 PM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
That would make it even worse. When things are enclosed like that, it makes it harder for any trapped water/moisture to evaporate.
Some of the most corroded mower engines I have ever seen were always parked in the shade under a tarp. The sun would never dry them out.
Re: Kohler command corrosion [Re: motor_oil_madman] #4462818
07/18/17 12:42 PM
07/18/17 12:42 PM
Houston, Texas
Houston, Texas
I was just trying to save $600.00, but it was too scratched up with rust in areas where the paint was damaged, plus the battery was dead. Surprising since he said he runs it periodically to charge the battery. He has a battery charger on it when I came cause it was dead. I'll just buy a new one for a piece of mind.
Re: Kohler command corrosion [Re: motor_oil_madman] #4462826
07/18/17 12:45 PM
07/18/17 12:45 PM
MD
AirgunSavant Offline
MD
Walking away was SMART!
Re: Kohler command corrosion [Re: motor_oil_madman] #4462831
07/18/17 12:49 PM
07/18/17 12:49 PM
Houston, Texas
Houston, Texas
Well after being ripped off yesterday by that body man I figured i should just pass. Lol
Re: Kohler command corrosion [Re: AirgunSavant] #4462833
07/18/17 12:49 PM
07/18/17 12:49 PM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
+1
Sounds like it sits around a lot and wasn't maintained that well. A bad combination.
Re: Kohler command corrosion [Re: motor_oil_madman] #4462880
07/18/17 01:36 PM
07/18/17 01:36 PM
Houston, Texas
Houston, Texas
It only had 43 hours on it so I was expecting it to look better than it did.
Re: Kohler command corrosion [Re: jeepman3071] #4463355
07/18/17 09:32 PM
07/18/17 09:32 PM
Houston, Texas
Houston, Texas
+1
Yeah it seems I forgot how many people just don't take care of anything. I hate buying brand new stuff because you get hit so hard at resale time, but I guess the peace of mind at least for me makes it worth it.
