STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
106 registered members (ARCOgraphite, Ag76, Altima2, AZjeff, acme, 2012AccentSE, 9 invisible), 1,968 guests, and 64 spiders.
Topics286,230
Posts4,904,725
Members67,582
Most Online2,967
Mar 10th, 2019
Permanent Fix for Worn Sway Bar #4462703
07/18/17 10:30 AM
07/18/17 10:30 AM
Kennett Square, PA
artbuc Offline OP
artbuc  Offline OP
Kennett Square, PA
Just replaced the rear sway bar bushings 8 months/3k miles ago which totally eliminated noises which happened only on a rare combination of bump and speed. In fact, there was only one spot where I could consistently create the classic sound. Now the sound is back but happening more often in an entirely different set of road conditions. The sway bar is worn and scored so I gave it a healthy wrap of teflon tape and reinstalled the practically new bushings. All noises gone. Since this 99 Avalon is 18 years old with 137k miles, I am not interested in buying a new sway bar. OTOH, I am not interested in doing a teflon wrap every 6 months. Does anyone have a feel for how long the teflon tape will work? Is there a better, longer lasting way to build-up the worn sway bar? Thanks.
Re: Permanent Fix for Worn Sway Bar [Re: artbuc] #4462716
07/18/17 10:44 AM
07/18/17 10:44 AM
Central NY
Miller88 Online content
Miller88  Online Content
Central NY
The end where the link goes is worn out? I'm having the same issue on my Focus. I'm ... just going to live with it clunking.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Permanent Fix for Worn Sway Bar [Re: artbuc] #4462720
07/18/17 10:46 AM
07/18/17 10:46 AM
Midwest, Illinois
beanoil Online content
beanoil  Online Content
Midwest, Illinois
A sleeve? I'm not sure if you are referring to the bar or end link....
Moog has replacements for some makes. Might be worth a look.
beanoil: Tough under heat, real dirty afterwards.
Re: Permanent Fix for Worn Sway Bar [Re: Miller88] #4462724
07/18/17 10:51 AM
07/18/17 10:51 AM
Kennett Square, PA
artbuc Offline OP
artbuc  Offline OP
Kennett Square, PA
No, the section of the bar that provides bearing for the sway bar bushing. Nothing to do with the sway bar end links. To keep things quiet, the rubber bushing has to clamp the bar. Even the smallest play will cause a major clunk. My sway bar has worn thin where the bushing clamps around it. For now the build-up with teflon tape is working perfectly.
Re: Permanent Fix for Worn Sway Bar [Re: artbuc] #4462746
07/18/17 11:20 AM
07/18/17 11:20 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
I imagine if its worn significantly it will break there soon. Its like nicking a spring.
I guess you could drill and tap a grease nipple through the bracket and the bushing. I think if your going to want it to run silently for a long time you should just get a new bar and bushings and fix it once.
07 Focus ZXW, 5spd manual, 230km M1 5W30
18 Outback 2.5 CVT 22km 0W20
Re: Permanent Fix for Worn Sway Bar [Re: artbuc] #4462749
07/18/17 11:22 AM
07/18/17 11:22 AM
MI
doitmyself Offline
doitmyself  Offline
MI
Could you go with bushings that are one size smaller (interior hole diameter) so that they will clamp down on the sway bar?? Or, go one size smaller AND with greaseable mounts??
Re: Permanent Fix for Worn Sway Bar [Re: artbuc] #4462755
07/18/17 11:26 AM
07/18/17 11:26 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Can sand and paint the spot on the sway bar where the original paint has worn off. Just go very light on the sanding, just enough to clean it up, rough it up.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Permanent Fix for Worn Sway Bar [Re: artbuc] #4462778
07/18/17 11:54 AM
07/18/17 11:54 AM
Northeast
Finz Offline
Finz  Offline
Northeast
Can't speak for permanent as only time will tell but what if you exposed the bar where needed snd:
1. Cut/wrap a piece of soaker hose ( from Home Depot to weep water around base of plants) around the bar or
2. Cut/wrap a piece of the cellulose pipe wrap (another Home Depot purchase).
Lots of trimming involved but I would imagine each would double up on the dampening you're after. And, if trimmed well, would be a nice snug fit. Also, both would be water resistant
God Bless America
Re: Permanent Fix for Worn Sway Bar [Re: artbuc] #4462799
07/18/17 12:21 PM
07/18/17 12:21 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Wabbout paring the split on the bushing and bashing in the clamp a little bit? No experience but...
Thick oil is better grin2
Re: Permanent Fix for Worn Sway Bar [Re: artbuc] #4462807
07/18/17 12:29 PM
07/18/17 12:29 PM
West Michigan
buck91 Offline
buck91  Offline
West Michigan
The metal bar itself or wearing? Typically, the rubber "grips" the bar and just deforms during articulation... Poly bushings have rotation along their I.D.
That said, what about checking the OE spec'd bushing size and picking up an aftermarket unit with a slightly smaller diameter? Most PU makers like energy suspension offer sized-based part numbers. Just be aware the PU bushings like to squeak. Best I've found is Super Lube multi purpose grease... but eventhat needs greased often.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Permanent Fix for Worn Sway Bar [Re: artbuc] #4462828
07/18/17 12:47 PM
07/18/17 12:47 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
That is a low mileage for a Toyota although it is old based on model year.
Believe me, they don't build it like that anymore.
I know sometimes people think it is old but not in this case.
I would just shell out the money for a new sway bar if you want to keep the car for at least 100K miles which may be another 10-15 years at the current rate of use.
I don't think the new sway bar will be more than $100 plus some labor if you cannot do it yourself.
JMHO.
  • 2017 Toyota Sienna
Re: Permanent Fix for Worn Sway Bar [Re: artbuc] #4462848
07/18/17 01:11 PM
07/18/17 01:11 PM
In the Garage...
ls1mike Offline
ls1mike  Offline
In the Garage...
How much is a sway bar?
Never mind. About 80 bucks. I would think that car is worth 80 bucks plus saves you time messing with it, which you can't get back.
None of that stuff is going to last long and you will go out of your mind trying to stop the noise.
Mike
00 Trans Am WS6 5.7 LS1
02 Silverado 2500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Permanent Fix for Worn Sway Bar [Re: JMJNet] #4462862
07/18/17 01:22 PM
07/18/17 01:22 PM
Kennett Square, PA
artbuc Offline OP
artbuc  Offline OP
Kennett Square, PA
I'm going to take her to my grave. I just did a complete detail inside and out. Looks almost brand new. The paint is smooth as glass. I have the Platinum Edition with the BMW style allow wheels.
Re: Permanent Fix for Worn Sway Bar [Re: artbuc] #4462872
07/18/17 01:30 PM
07/18/17 01:30 PM
In the Garage...
ls1mike Offline
ls1mike  Offline
In the Garage...
So if it is that nice and you are taking it to the after life...Do yourself and your love a favor, buy her a new sway bar. Easy Peasy Lemon Squeezey and no more noise or time wasted. I did the hose trick on an old truck. It works but I eventually broke down and picked up a sway bar.
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Permanent Fix for Worn Sway Bar [Re: artbuc] #4462888
07/18/17 01:42 PM
07/18/17 01:42 PM
Canuck living in California
KrisZ Online content
KrisZ  Online Content
I was going to suggest some red neck epoxy fix, but if this vehcile is so special and well cared for, a new sway bar is a no brainier.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
