Ghetto testing a wheel speed sensor
by Nayov
06/24/18 06:23 AM
dash cam
by DAC2018
06/24/18 05:08 AM
WoO driver Jason Johnson injured
by bdcardinal
06/24/18 01:08 AM
Plastic burning smell when WOT
by Jaha24k
06/24/18 12:57 AM
Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
06/24/18 12:00 AM
Ruger LCP .380
by PW01
06/23/18 11:24 PM
Launching boat with stick shift
by troutfisher
06/23/18 11:22 PM
Free oil
by Spitter
06/23/18 10:53 PM
Porsche Panamera buying advice
by CharlieBauer
06/23/18 10:04 PM
RC cars
by red7404
06/23/18 09:36 PM
Any Good 4K Movies ?
by Warstud
06/23/18 09:06 PM
Gray on Oil Dipstick?
by chinee
06/23/18 08:41 PM
Clear plastic scratch remover?
by Quattro Pete
06/23/18 08:15 PM
Parking wars show.
by Chris142
06/23/18 08:15 PM
set for years
by 93cruiser
06/23/18 08:07 PM
Looking to replace 2005 Sienna with SUV
by i6pwr
06/23/18 07:26 PM
Trying to fix chainsaw
by turtlevette
06/23/18 06:48 PM
tire rotation
by marine65
06/23/18 06:48 PM
Reese hitch $30 Walmart YMMV
by pda1122
06/23/18 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
06/23/18 06:14 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
76 registered (andyd, Astro14, 2009Edge, 1foxracing, 4WD, 6 invisible), 1149 Guests and 71 Spiders online.
65303 Members
67 Forums
285891 Topics
#4462049 - 07/17/17 04:50 PM Torquing Rear Control Arms
artbuc Offline
Loc: West Chester, PA
Re: 1999Toyota Avalon
I am replacing the rear control arm assemblies (the ones that adjust toe). I saw or read somewhere that the car weight must be resting on the wheels before you torque to make sure bushings are in correct position. I can not find the reference and wonder if anyone can tell me. It is much easier to torque with car jacked up on stands and tires hanging free but I want to do it the right way. Thanks.
Oh, the arms are 48730 and 48740 on the diagram:
https://parts.toyota.com/a/63045254__6709454/REAR-SPRING--SHOCK-ABSORBER/361410-4804.html
Edited by artbuc (07/17/17 04:51 PM)
#4462071 - 07/17/17 05:20 PM Re: Torquing Rear Control Arms [Re: artbuc]
SLO_Town Offline
Loc: California's Wine Country
For all rubber suspension "bushings" you must tighten the attachment bolts with the suspension at it's normal ride height. Do not tighten the attachment bolts with the suspension at full droop, as it is when on jack stands. To do so will twist the rubber bushing relative to the metal sleeve(s) when the vehicle is back at normal ride height. This will lead to premature failure of the bushing.
In the diagram you reference, it appears that bolts 48703E should be tightened with the suspension at its normal right height.
The exception to this rule is when the bushing is an actual "bearing", one where the center sleeve can rotate freely when it's installed on the suspension control arm.
Scott
03 BMW 330Ci (Euro Castrol 0W-30)
10 Honda Element (Castrol Edge EP 5W-30)
11 BMW 328i (Euro Castrol 0W-30)
15 Ford Focus (Castrol Edge EP 5W-20)
#4462106 - 07/17/17 05:42 PM Re: Torquing Rear Control Arms [Re: SLO_Town]
artbuc Offline
Scott
Thanks. I found the reference which confirms your advice. I will have to check but I think the design of these arms is the bearing type you call out as an exception.
#4462188 - 07/17/17 06:59 PM Re: Torquing Rear Control Arms [Re: artbuc]
Merkava_4 Offline
Loc: Clovis, CA
It's got rubber bushings for the control arms; I can see them in the drawing. You need to back the car up on Rhino ramps (or something similar) before you do the final tightening. If you're thin enough to get under their while the car is on the floor, that's even better. A four post lift is the easiest way if you got one of those in your garage.
#4462215 - 07/17/17 07:27 PM Re: Torquing Rear Control Arms [Re: artbuc]
Colt45ws Offline
Loc: Central Washington
I like to get the weight of the car down on the ground, and bounce the suspension a few times to make sure its settled before reefing on the bolts.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
#4462447 - 07/18/17 03:05 AM Re: Torquing Rear Control Arms [Re: Merkava_4]
artbuc Offline
The ones I am replacing definitely have bearing bushings instead of fixed bushings. I don't know if the companion control arms 48710 and 48720 also have bearing bushings. Both arms are torqued with the same bolt so I have to determine that.
Edited by artbuc (07/18/17 03:09 AM)
#4462599 - 07/18/17 08:42 AM Re: Torquing Rear Control Arms [Re: artbuc]
artbuc Offline
Ok, both control arms rotate freely as you would expect considering how much movement they see. Thanks to all for your input.
