Central A/C [censored] out
by TOMJ
06/18/18 08:43 AM
08 Scion tC under valve cover pics
by Highboy
06/18/18 08:39 AM
Storing extension ladded in garage?
by maverickfhs
06/18/18 08:27 AM
Do you let your tool batteries go dead in storage
by Snagglefoot
06/18/18 07:20 AM
BITOG using excessive CPU power?
by Kibitoshin
06/18/18 05:10 AM
Any news on what happened to this plane?
by Exhaustgases
06/18/18 02:36 AM
E4OD fluid ?
by Exhaustgases
06/18/18 02:23 AM
Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
Orion62, Revd, blinky1041, mostdecent, T1TN
65261 Registered Users
72 registered (Artem, BAJA_05, andyd, barkingspider, 2009Edge, badtlc, 8 invisible), 1430 Guests and 39 Spiders online.
65261 Members
67 Forums
285509 Topics
Page 1 of 3 1 2 3 >
#4461980 - 07/17/17 03:46 PM Toyota 22RE top end rebuild starts tomorrow.
BigD1 Offline
Loc: NC
Tearing down my 92 Toyota 22RE engine tomorrow. New head, timing chain kit, water pump, and oil pump will be installed.
My plan to seal it all back up. This engine does use gaskets except for the oil pan, and the oil pan uses Toyota FIPG or equivalent. I plan on using Gasgacinch/Edelbrock for the timing cover, water pump, intake(not water ports), upper plenum, and throttle body. Edelbrock recommends RTV only around the intake water ports.
What would you use to seal the engine?
http://gasgacinch.com/
http://www.jegs.com/InstallationInstructions/300/350/350-9300.pdf
1992 Toyota Pickup--Havoline HM 10W-30--Motorcraft FL-910S
#4462015 - 07/17/17 04:19 PM Re: Toyota 22RE top end rebuild starts tomorrow. [Re: BigD1]
mk378 Offline
Loc: USA
If you're doing this in the truck, and it's a stock height 4x4 truck, the front axle will be really in the way of taking the oil pan off. So don't, just drop it down some so you have clearance to put the timing cover on.
Modern gaskets of good quality usually don't need sealer.
Edited by mk378 (07/17/17 04:19 PM)
#4462024 - 07/17/17 04:25 PM Re: Toyota 22RE top end rebuild starts tomorrow. [Re: BigD1]
nthach Offline
Loc: California
Permatex Hi-Tack. Never failed me when I do need to install a cut gasket that doesn't explicitly say install dry but does need a little something to hold it in place.
Be careful with RTV/FIPG around the input/output ports of the oil pump, use silicone-based sealers sparingly - enough to seal with only a tiny bit of squeeze out.
Edited by nthach (07/17/17 04:27 PM)
#4462025 - 07/17/17 04:25 PM Re: Toyota 22RE top end rebuild starts tomorrow. [Re: BigD1]
Linctex Offline
Loc: Waco, TX
#4462037 - 07/17/17 04:40 PM Re: Toyota 22RE top end rebuild starts tomorrow. [Re: mk378]
BigD1 Offline
Loc: NC
It's 2wd drive truck, so it's not too much work to get the oil pan off.
#4462043 - 07/17/17 04:44 PM Re: Toyota 22RE top end rebuild starts tomorrow. [Re: nthach]
BigD1 Offline
Loc: NC
I was going to roll with the Hi-Tack, but saw a builder that specializes in the 22R, and they use Gasgacinch. I was going to use the Hi-Tack, but changed my mind.
Oil pump has a big giant o-ring that seals it. No sealer needed on it. It sits on the front of the engine at the crank.
#4462046 - 07/17/17 04:47 PM Re: Toyota 22RE top end rebuild starts tomorrow. [Re: BigD1]
BigD1 Offline
Loc: NC
One more question.
Pretty sure the piston tops will have lots of carbon. What would you guys use to clean the piston tops? I have carb cleaner, acetone, and brake cleaner on hand.
#4462057 - 07/17/17 04:59 PM Re: Toyota 22RE top end rebuild starts tomorrow. [Re: BigD1]
FlyNavyP3 Offline
Loc: Jacksonville, FL
I've done this job probably 40+ times. Maybe more.
I've had the best luck with Permatex Aviation Form a Gasket. I've also used it quite a bit while building engines when I worked at a rebuilder and then at a race shop. The turbine mechanics at work use it on aircraft turbine case halves. It's really good stuff.
You don't actually have to drop the oil pan to do the job. But you can if you want to. No need to use FIPG from Toyota. Permatex Ultra Grey works very well.
Don't forget the long Allen head bolt near the thermostat on the intake.
Don't forget the front cylinder head bolt forward of the timing chain and under the distributor gear. Its hidden by oil usually. It has a 12mm head.
Let me know if you have questions!
Luke
#4462063 - 07/17/17 05:09 PM Re: Toyota 22RE top end rebuild starts tomorrow. [Re: BigD1]
FlyNavyP3 Offline
I should clarify. You can use the form a Gasket on all paper gasket surfaces.
However my personal technique is to use it on both sides of the timing cover gaskets just brush it on and assemble.
For the intake gaskets I only use it around the water portions.
Both sides of the water pump gasket.
Use it on the two water pipe gaskets on each side of the timing cover both sides.
Everything else goes on dry.
Luke
#4462156 - 07/17/17 06:31 PM Re: Toyota 22RE top end rebuild starts tomorrow. [Re: BigD1]
BigD1 Offline
Loc: NC
@FlyNavyP3
I know I can install the water pump on the timing cover when I have the timing cover on the bench. There is one big long bolt on the pump that I will have to install after the cover is mounted because I think it goes into the block. Can I install the oil pump on the timing cover too when it's on the bench? Would be easier for me to get that big oil pump o-ring seated right on the bench.
#4462255 - 07/17/17 08:22 PM Re: Toyota 22RE top end rebuild starts tomorrow. [Re: BigD1]
Chris142 Offline
Loc: Deplorable in apple valley, ca
There is a 12mm headed bolt under the distributer gear. Dont miss it and break the timing cover like the shops here do.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#4462260 - 07/17/17 08:30 PM Re: Toyota 22RE top end rebuild starts tomorrow. [Re: BigD1]
FlyNavyP3 Offline
Originally Posted By: BigD1
@FlyNavyP3
Yes, you absolutely can. Keep track of which oil pump bolts go where as well as they're different lengths and putting the wrong long one in the wrong place will bind the tensioner. The short bolts that only bolt into the timing cover can be used to install the oil pump with the timing cover on the bench.
Luke
#4462385 - 07/17/17 11:16 PM Re: Toyota 22RE top end rebuild starts tomorrow. [Re: Chris142]
BigD1 Offline
Loc: NC
Hanes manual pointed that bolt out, so I know about it, but yeah I could see how that bolt gets missed because it is submerged in oil.
#4462387 - 07/17/17 11:23 PM Re: Toyota 22RE top end rebuild starts tomorrow. [Re: FlyNavyP3]
BigD1 Offline
Loc: NC
@FlyNavyP3
OK that sounds good. That timing cover laying flat with the o-ring in the groove should stay put when I install the pump to cover. I will use a little dab of grease on the o-ring to help hold it in the groove of the timing cover.
Should I pack the pump with some multipurpose grease? Some say yes, and some say no. The no people say that assembly lube is enough, which is what I was going to do. On the other hand, using some grease would help hold the pump gears in the oil pump housing.
#4462398 - 07/17/17 11:37 PM Re: Toyota 22RE top end rebuild starts tomorrow. [Re: BigD1]
FlyNavyP3 Offline
@FlyNavyP3
I do not recommend grease in the oil pump. The gears dont fall out easily even if coated in oil. I personally use assembly lube to ensure a quick prime on startup. I haven't had any issues with that practice yet including new engine builds. Be sure to use plenty of lube on the camshaft when you install it as well. Timing chain I lube with oil after everything is back on but before the valve cover goes on, it just gets a quart dumped directly on it before the VC goes on.
Luke
Page 1 of 3 1 2 3 >
