Guest's devices cannot connect to my WiFi
by boulderdentist
06/23/18 12:54 AM
Battery stuck in flashlight.
by Chris142
06/22/18 11:53 PM
Must read for everyone watching their diet
by JLTD
06/22/18 11:28 PM
2014 Mazda5 Valvoline Synpower 0W-20 7500 miles
by PWMDMD
06/22/18 10:54 PM
VOA Ravenol ECS 0W-20
by PWMDMD
06/22/18 10:47 PM
2020 mid-engine Corvette spy vid?!
by AZjeff
06/22/18 10:45 PM
'05 base impala. NO turn signals.FAST blinking.
by Lee4212
06/22/18 10:34 PM
Motul 15w-50, 5 Liter 4 Pack $19.42
by hatt
06/22/18 10:10 PM
High Lead Redline 5W40 thoughts? Ty
by Pajero
06/22/18 09:40 PM
Source of the Mighty Columbia River
by Snagglefoot
06/22/18 09:32 PM
Another thick/thin article to discuss
by JLTD
06/22/18 09:23 PM
Ethylene Glycol Long Life Coolant for KUBOTA
by pburchett
06/22/18 09:11 PM
Mobil 1 5W-30, 6,200 mi, 2017 2.3 EB Explorer
by Whimsey
06/22/18 08:48 PM
Chevron 10w-40, 97 Nissan Maxima, 3000 miles
by OilGeek91
06/22/18 08:36 PM
Old green antifreeze in garage storage is gelling
by JLawrence08648
06/22/18 08:32 PM
VWs at Pick n Pull
by Eric Smith
06/22/18 08:17 PM
Single Data Point: CK-4 destroys the flat tappet
by Gokhan
06/22/18 08:12 PM
Breaking in new short block
by Bub
06/22/18 07:00 PM
Should I buy a mill or a drill press?
by Vern_in_IL
06/22/18 06:32 PM
Weber Q300 Grill Parts Help
by gathermewool
06/22/18 05:24 PM
azzid0906, OilGeek91, DRancher, Newuser, Varbill
65299 Registered Users
37 registered (10WSmuckers, dilberto88, boulderdentist, ArrestMeRedZ, 4WD, clinebarger, 3 invisible), 906 Guests and 28 Spiders online.
65299 Members
67 Forums
285815 Topics
#4461464 - 07/17/17 07:47 AM UOA 2013 CIVC SI AMSOIL 0W/30 AZO 8,615MI
Swifty Offline
Loc: Nor Cal
A rather boring UOA but the first on this car. Only thing that bothers me a bit is the oil didn't stay in grade, but the protection is still there.
"Almost" every UOA of 30 weight that I have seen ends up as a 20 weight in this version of the K24.
10W/30 ATM is in the car now it will be interesting to see if it still is a 30 weight at the end of the OCI
Code:
2013 civic SI K24Z7, Hondata Flashpro custom tune, AFE Pro Dry air filter.
Your air filtration system is doing a good job, as seen by the 16 ppm of silicon in this sample.
Universal averages show typical wear for this type of engine after about 6,900 miles of oil use. You kept this
oil in place a little longer and most metals are in line with averages. Lead is a bit higher and that could show
bearing wear, but this engine probably has aluminum bearings, so maybe it's from an octane booster or
"unleaded" track fuel, if any were used. Let's just see how it trends.
The viscosity read in the 0W/20 range and the TBN was strong at 4.1. Try 10,000 miles
No make up oil.
Oil	Amsoil 0W30 AZO
Miles in use	8,615
Miles           67,903
Sample taken	07/02/17
Aluminum	4
Chromium	0
Iron	        6
Copper	        1
Lead	        7
Tin	        0
Molybdenum	135
Nickel	        0
Manganese       0
Silver	        0
Titanium        0
Potassium       1
Boron	        78
Silicon	        16
Sodium	        10
Calcium	       3002
Magnesium       12
Phosphorus      576
Zinc            624
Barium          0
SUS Viscosity @210	54.8
Cst Viscosity @100	8.70
Flashpoint              425
Fuel%                   <0.5
Antifreeze%              0
Water%	                 0
Insolubles%              0.1
TBN                      4.1
2013 Civic SI Sedan Amsoil 5/30 ASL Fram Ultra 77k miles
2003 Toyota Highlander PP 10/30 M1 Filter (wife's) 160k miles
#4461517 - 07/17/17 08:39 AM Re: UOA 2013 CIVC SI AMSOIL 0W/30 AZO 8,615MI [Re: Swifty]
oil_film_movies Offline
Loc: MN
0w20 is the Honda-recommended oil, not an xw30 as you're using, which means you have plenty of room for viscosity to drop before the engine has durability issues.
#4461530 - 07/17/17 08:54 AM Re: UOA 2013 CIVC SI AMSOIL 0W/30 AZO 8,615MI [Re: oil_film_movies]
Swifty Offline
Loc: Nor Cal
That is why I said the protection is still there and you are correct I am far from having any durability issues. I'm not to bothered by it, just would be nice to see a 30 weight stay in grade over the interval. I'm certainly not going to lose any sleep over it.
The K24 when introduced was specd for 30 weight and outside the US it uses different viscosities.
#4461596 - 07/17/17 10:15 AM Re: UOA 2013 CIVC SI AMSOIL 0W/30 AZO 8,615MI [Re: Swifty]
addyguy Offline
Loc: Canada
The Si specs a 30-weight oil.
Impressive results for 8600 miles, all single-digit.
2010 Kia Soul 2U - 2.0L I-4, auto; 126k miles.
M1 EP 10W-30; OEM Kia filter.
#4461624 - 07/17/17 10:48 AM Re: UOA 2013 CIVC SI AMSOIL 0W/30 AZO 8,615MI [Re: addyguy]
Swifty Offline
Loc: Nor Cal
I believe the 8th gen did but the 9th generation actually specs 0w/20.
#4461888 - 07/17/17 02:14 PM Re: UOA 2013 CIVC SI AMSOIL 0W/30 AZO 8,615MI [Re: Swifty]
bigt61 Offline
Loc: Virginia
If it regularly sees redline, I'd stay with the 30. If you drive it easy, the 0W-20 won't be stressed. In California, even somewhat colder Northern Cali, I doubt a 5 or 10W-30 will hurt anything. Obviously, your #'s look great.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
#4461923 - 07/17/17 02:42 PM Re: UOA 2013 CIVC SI AMSOIL 0W/30 AZO 8,615MI [Re: bigt61]
Swifty Offline
Loc: Nor Cal
I agree, I can't complain about the numbers at all, but I am more inclined to stay with the 30 weight for my OCI's as it will end up at the higher end of the viscosity range of a 20 weight anyway.
I can't say it sees redline regularly, but my daily commute at 4am in the morning sees between 80-90 on the freeway for 35 minutes even at those speeds I still think it is relatively easy on the oil.
