Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
26 registered members (bfleeman, Black_Thunder, AnthemBassMan, Brad_C, 555, AndyB, 3 invisible), 492 guests, and 68 spiders.
Topics286,262
Posts4,905,490
Members67,589
Most Online2,967
Mar 10th, 2019
2012 Silverado lunges forward while braking to a stop #4461226
07/16/17 08:53 PM
07/16/17 08:53 PM
In
SquirrelMan Offline OP
In
When I brake, it seems to really lunge forward. I can only describe it as aggressive downshifting? I have been advised by a fellow Silverado owner to turn off the Active Fuel Management with Flashpaq? I would love to hear what some of you guys have to say on this. It's a 1/2 ton crew cab 5.3L 4 speed automatic. 2012. Thanks
Re: 2012 Silverado lunges forward while braking to a stop [Re: SquirrelMan] #4461230
07/16/17 08:58 PM
07/16/17 08:58 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
Nearly impossible to diagnose across web with the limited info we have
2012 Chevy Cruze LT 1.4T - 59k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 144k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: 2012 Silverado lunges forward while braking to a stop [Re: SquirrelMan] #4461244
07/16/17 09:22 PM
07/16/17 09:22 PM
In
In
Other forum discussions I have found describe it as "lurching" forward. Happens as transmission downshifts.
Re: 2012 Silverado lunges forward while braking to a stop [Re: SquirrelMan] #4461246
07/16/17 09:23 PM
07/16/17 09:23 PM
VA
mrgrim Offline
mrgrim  Offline
VA
Just my random experience: last year my passenger car experienced a lounge forward per se when I was almost to a full stop. It only happened once, but I checked it out the next day and discovered that my brake fluid had gotten really dirty, and probably contaminated due to the extremely humid summer and stop-and-go tunnel traffic I have to go through. I'm thinking the hydraulic pressure didn't force the brake pads to catch and hold, so I did a brake flush and haven't had that issue again. Given the fact that we're going through another humid summer, I'll probably take a precaution and flush the lines again during my next tire rotation.
Re: 2012 Silverado lunges forward while braking to a stop [Re: SquirrelMan] #4461276
07/16/17 09:57 PM
07/16/17 09:57 PM
PV Az @ 5000'
AZjeff Offline
AZjeff  Offline
PV Az @ 5000'
By aggressive downshifting if you mean earlier at higher speed that would cause higher revs and would be the opposite of lurching forward. If it were older I'd guess maybe the Idle Air Valve? Not sure what the AFM would have to do with it.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: 2012 Silverado lunges forward while braking to a stop [Re: 901Memphis] #4461332
07/16/17 11:14 PM
07/16/17 11:14 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Nonsense! We're all psychic! smile
Re: 2012 Silverado lunges forward while braking to a stop [Re: SquirrelMan] #4461337
07/16/17 11:24 PM
07/16/17 11:24 PM
MN
Tman220 Offline
Tman220  Offline
MN
You're not doing something silly like driving around with tow/haul mode activated are you? (button at the end of the column shifter)
Some people like to drive around all the time with it on because of the firmer and later shifts, but doing so will cause more aggressive engine braking and downshifting while slowing down.
2012 Regal GS Turbo PP 5w30
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30
Re: 2012 Silverado lunges forward while braking to a stop [Re: SquirrelMan] #4461607
07/17/17 10:28 AM
07/17/17 10:28 AM
In
In
I am not in tow haul. Definitely high revs. From 2 to 1 is the worst. I have a feeling it's normal. But I read where a guy turned off DOD/AFM and never experienced it again. Stopping gradually it doesn't do it. Only in harder more sudden braking. I maybe wrong in describing lunging or lurching, but it definitely feels like it's under more power than what I am used to. I appreciate the replies, I will check back again. Maybe it's the computer, and it's normal, like an engine braking program? I'm no expert. I service fluids and change filters and gaskets but after that, I am not a knowledgeable mechanic.
Re: 2012 Silverado lunges forward while braking to a stop [Re: SquirrelMan] #4461678
07/17/17 11:34 AM
07/17/17 11:34 AM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
Does this occur mostly when braking on bumpy or uneven road surfaces?
2011 Toyota Prius now at 97K
Re: 2012 Silverado lunges forward while braking to a stop [Re: SquirrelMan] #4461682
07/17/17 11:39 AM
07/17/17 11:39 AM
stower17 Offline
stower17  Offline
I have been in several 2010-2012 Silverados with the 6 speed auto. They ALL clunked from 2-1 downshift and have a "surge" feeling when almost stopped. Even worse with the 4x4 models. I have a buddy with a 2014 that claims the same thing. His words not mine, "the forums say the all clunk and downshift rough". Nature of the best?
Re: 2012 Silverado lunges forward while braking to a stop [Re: SquirrelMan] #4461748
07/17/17 12:32 PM
07/17/17 12:32 PM
MN
Tman220 Offline
Tman220  Offline
MN
So what does it do when you are in tow/haul? Get worse, stay the same, etc?
I also believe that transmission has adaptive shifting, perhaps try disconnecting the battery for a bit and letting it relearn? Worth a try, don't you think?
Just noticed you said it was a 4 speed? I didn't think that was still available in 2012 behind a 5.3? If that's really the case then there isn't adaptive shifting but a PCM reset still might do it some good.
Re: 2012 Silverado lunges forward while braking to a stop [Re: SquirrelMan] #4461783
07/17/17 01:03 PM
07/17/17 01:03 PM
Utah
CKN Offline
CKN  Offline
Utah
This is a "feature" of those trucks. It is caused (in part) by the AFM. What I would suggest doing to test this out is to move your selector to the manual position-and then move the gear button to the "5' position. This is great for around town. If the transmission is prevented from going in to 6th-the AFM will not come on.
A tuner is not needed to turn off the AFM. There is a company that makes a black bot that plugs in to the OBD port. You just unplug it when you take it in to the dealer. It DOES NOT OVERWRITE the ECM.
https://rangetechnology.com/
I have the same year as yours in a GMC Sierra with the 5.3. This is my second truck-the first one was a 2011. So I'm pretty familiar with the issues with these trucks.
The issue with a tuner-is that it over writes the ECM (and-yes it can be discovered by the dealer) and will void any powertrain warranty you have.
Re: 2012 Silverado lunges forward while braking to a stop [Re: Tman220] #4462340
07/17/17 10:17 PM
07/17/17 10:17 PM
stower17 Offline
stower17  Offline
[/quote]
Just noticed you said it was a 4 speed? I didn't think that was still available in 2012 behind a 5.3? If that's really the case then there isn't adaptive shifting but a PCM reset still might do it some good. [/quote]
I just noticed he said 4 speed as well... If it's indeed a 4 speed then he has a 4.8 V8 or a 4.3 V6 which neither of those have AFM in those years.
I have driven, rode in, and owned countless 4L60e's for 2 decades and never experienced this 2-1 downshift and surge. So if it's a 4 speed then my experience tells me that something is wrong with that unit.
Re: 2012 Silverado lunges forward while braking to a stop [Re: SquirrelMan] #4462547
07/18/17 07:40 AM
07/18/17 07:40 AM
In
In
Thanks for your time guys, I have never engaged tow haul. Only had truck since December. I could swear when I bought filter and gasket for tranny I had to specify 4 speed or 6, deep or shallow pan. I also don't remember manual mode showing 6 speeds, I will check. Also, I don't feel the transmission moving through 6 different gears as I build up to 60mph on highway. As a matter of fact, it happens when I pull into McDonald's and it's very rough bump pulling in. I will double check my transmission specs.
Re: 2012 Silverado lunges forward while braking to a stop [Re: SquirrelMan] #4462548
07/18/17 07:43 AM
07/18/17 07:43 AM
In
In
My cousin actually recommended the Range unit. If I want to turn off AFM. He couldn't stand AFM but he is very particular
