Used generator price.
by Eddie. 09/24/18 11:55 AM
More energy concerns about Bitcoin
by OVERKILL. 09/24/18 10:01 AM
Soot loading from DI engines - Size of particles
by StevieC. 09/24/18 09:58 AM
New TV bad picture some channels
by raaizin. 09/24/18 09:35 AM
Crown Victoria HVAC repair
by emmett442. 09/24/18 08:44 AM
2007 Toyota Camry LE Alternator
by maverickfhs. 09/24/18 08:28 AM
AutoSense drying not drying
by Ifixyawata. 09/24/18 08:23 AM
Time for a new Generator... Wisdom desired!
by webfors. 09/24/18 06:36 AM
flat roof weight bearing support
by henni. 09/24/18 06:29 AM
ADD A MARBLE - Make Life Easier
by MasterSolenoid. 09/24/18 06:17 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont
by RogerBacon. 09/24/18 05:40 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont.
by RogerBacon. 09/24/18 05:37 AM
Direct Injection Valve Cleaning Maintenance
by RayCJ. 09/24/18 05:20 AM
Chattanooga tn ,cycling
by CourierDriver. 09/24/18 04:42 AM
Sunrise, Sunset
by csandste. 09/24/18 02:39 AM
Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
albert001, LG_Electronics, TCam, OzFrog, Kursk
66062 Registered Users
88 registered members (bdcardinal, 4WD, -SyN-, AndyB, bismic1, 9 invisible), 1,984 guests, and 31 spiders.
Topics290,939
Posts4,852,895
Members66,062
Most Online3,590
Jan 24th, 2017
2017 Toyota UA80E 8 speed A/T #4460862
07/16/17 11:36 AM
07/16/17 11:36 AM
ga
faltic Offline OP
faltic  Offline OP
ga
Looking over my New 2017 Highlander LE Plus with the 2GR-FKS V6 and UA80E 8 speed A/T with an eye to future servicing. Found a video showing fluid change on a 2016 model but not 2017 and this transmission looks different, No oil pan. Any Toyota experts know if the drain/fill and level adjustment for this trans is the same as previous year? I couldn't find anything showing this transmission. I have searched pretty hard but so far nothing.
Re: 2017 Toyota UA80E 8 speed A/T [Re: faltic] #4460881
07/16/17 12:02 PM
07/16/17 12:02 PM
USA
Reddy45 Offline
Reddy45  Offline
USA
You're right there's not a whole lot out there. Looks like these have been produced since late 2016 so they haven't even been out a full year yet.
Re: 2017 Toyota UA80E 8 speed A/T [Re: faltic] #4460911
07/16/17 12:32 PM
07/16/17 12:32 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
It has been installed in the Lexus a year before that.
Yes, there is not much information.
  • 2017 Toyota Sienna
Re: 2017 Toyota UA80E 8 speed A/T [Re: faltic] #4460998
07/16/17 02:37 PM
07/16/17 02:37 PM
ga
faltic Offline OP
faltic  Offline OP
ga
Thanks for the reply's, maybe someone will put something on youtube before I need to do a drain and fill.
17 Highlander 3.5 2wd AT 10K+
95 Tacoma 2.4 2wd AT 187k+
07 EX250 21k+
09 EN500 11k+
11 PCX 125 4K+
Re: 2017 Toyota UA80E 8 speed A/T [Re: faltic] #4461948
07/17/17 03:15 PM
07/17/17 03:15 PM
Modesto,CA
mehullica Offline
mehullica  Offline
Modesto,CA
I have printed copies of the Repair Manual of the fluid change/adjustment procedure. I don't have access to a scanner. If you PM me you email, I can take photos with my iPhone & email them to you.
Re: 2017 Toyota UA80E 8 speed A/T [Re: faltic] #4585440
11/26/17 12:03 PM
11/26/17 12:03 PM
Seattle
Cruzmeister Offline
Cruzmeister  Offline
Seattle
Any update? Did you do your drain and fill? Please share details.
Re: 2017 Toyota UA80E 8 speed A/T [Re: Cruzmeister] #4586182
11/26/17 11:14 PM
11/26/17 11:14 PM
Seattle
Cruzmeister Offline
Cruzmeister  Offline
Seattle
Well, I took one for the team and went for it. The procedure is almost identical to the 2014-2016 video on youtube. There is no drain pan so the drain bolt is in the bottom.of the transmission case. The leveling tube is black instead of red. Fill bolt is exactly in the same spot and has 'WS' stamped on it. I used my scangauge to measure the temperature as I adjusted the level. The amount of fluid used was within an ounce of the fluid quantity I drained. Hope this helps someone who might be confused by the new setup like I was.
