EU version of Subaru 2.5 FB engine
by IMPALA08. 09/21/18 08:40 AM
New “rules” changing your choice of car?
by daves87rs. 09/21/18 06:04 AM
WIX51334XP Oil Filters
by CB900F2. 09/21/18 05:14 AM
Signal Oil Company radio advertising
by 21Rouge. 09/21/18 04:07 AM
Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
ScottRousell, Direct_Rejection, donatom, Sylent_Snyper, Ajizzle
66034 Registered Users
95 registered members (AnthonyF, ARCOgraphite, andyd, 2015_PSD, ArrestMeRedZ, AndyB, 6 invisible), 1,432 guests, and 41 spiders.
Topics290,748
Posts4,849,591
Members66,034
Most Online3,590
Jan 24th, 2017
303 tractor hyd oil in a manual transmission #4460578
07/16/17 01:17 AM
07/16/17 01:17 AM
ohio,usa
racsan Offline OP
racsan  Offline OP
ohio,usa
well about 2 weeks ago i bought a used 94 ford ranger, very well used and needing all sorts of stuff, when i checked the manual transmission fluid, it had 80w90 hypoid oil in it (can tell by the smell) i knew this is a major problem and it should have atf in it, i drained it out, had only about 2 qts in it, which means it was also low on oil. i went to my oil supply and found i had only 1 qt of atf, but i had over half of a 5 gallon bucket of 303 tractor hydraulic fliud. now since atf is pretty much a hydraulic flid itself and this in a manual transmission, i figured it might be safe, they both seem about the same viscosity and when you consider the heat and loads that a farm tractor is under, than 303 should be more than good enough for a old ford ranger 5 speed. ive searched online just out of curiosity and all ive seen others do with 303 as far as automotive usage is to run them in drag race automatics. so far after 500 miles ive not had any issues with my ranger transmission, at least its closer to the right fluid and its now full, any damaage that was done by being low on oil and being the wrong oil has already been done, but i am curious, any reason why 303 tractor hydraulic fluid shouldnt be used in a light-duty 5 speed manual trans? i know that hypoid oil is bad because of being too heavy and not "yellow metal frendly" which can eat up syncros. trans does have input shaft bearing noise, had it when i got it, and of course its not going to fix itself no matter what oil might be used. vechicle has high milage but not sure how high, shows 44K but its anyones guess how many times its rolled over, im sure its at least 144k but could be 244K. any thoughts on 303 oil and if i should dump it for the atf as soon as possible to avoid a future problem? granted it might not be a "yellow metal frendly" oil, i have no idea, considering tractors dont have sycros (to my knowledge) it wouldnt nessasarliy have to be good for sycros. ive not had a issue with it going up through the gears or downshifting either one. (yet)
Re: 303 tractor hyd oil in a manual transmission [Re: racsan] #4460580
07/16/17 01:27 AM
07/16/17 01:27 AM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
Does it have a T5 tranny? If so,it specs Mercon V. I'd go ahead and replace it.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 5W20
Re: 303 tractor hyd oil in a manual transmission [Re: racsan] #4460581
07/16/17 01:28 AM
07/16/17 01:28 AM
ohio,usa
racsan Offline OP
racsan  Offline OP
ohio,usa
its the M5OD, spec is mercon/dexron atf
Re: 303 tractor hyd oil in a manual transmission [Re: racsan] #4460585
07/16/17 01:43 AM
07/16/17 01:43 AM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
You're right,Madza transmssion:
https://en.wikipedia.org/wiki/Mazda_M5OD_transmission
I did some reading out of curiosity and Mercon III/Dexron seems to be the fluid that gives the best shifting. 80W90 gear oil is definitley the wrong fluid.
Re: 303 tractor hyd oil in a manual transmission [Re: racsan] #4460650
07/16/17 07:04 AM
07/16/17 07:04 AM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
I'd put a real manual transmission fluid in it, not some GL5 smelly sulfur stuff that is far too slippery for the synchronizers to work,
not automatic transmission fluid as specified by Ford and definitely not tractor fluid.
What the big three sometimes did was to use the same fluid in both automatics and manuals in some vehicles to eliminate an additional expensive UAW employee in the pit.
There were/are strange rules you cant phantom unless you've had a high dollar union job like I do.
Retired Chrysler manual transmission guru ex[plains it here:
Me: 13' VW GTI 3 door 6 speed manual
Re: 303 tractor hyd oil in a manual transmission [Re: skyactiv] #4460729
07/16/17 09:03 AM
07/16/17 09:03 AM
NE,Ohio
Rand Online content
Rand  Online Content
NE,Ohio
That transmission isnt too picky.
I like redline MTL in those. Another good choice is the ford full syn gl-4 gear oil.
XT-M5-QS IIRC.
Re: 303 tractor hyd oil in a manual transmission [Re: racsan] #4460770
07/16/17 10:01 AM
07/16/17 10:01 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
303 is a John Deere spec that hasn't been around since the 60's.
I don't think it has any decent anti-wear or extreme pressure additives.
REAL tractor fluid (for the kind of tractors with powershift and wet brakes) makes an excellent auto trans racing fluid. it also cost several times more per gallon than the junky "303" oil.
I see no reason to worry about your trans
Re: 303 tractor hyd oil in a manual transmission [Re: racsan] #4460771
07/16/17 10:01 AM
07/16/17 10:01 AM
Charlotte, NC
Oldmoparguy1 Offline
Charlotte, NC
I'd use Penzoil MTF, Manual Transmission Fluid. Works for me.
A Randomly Selected Thought For The Day:
If Noah had used Zip, he could have used a smaller boat.
Re: 303 tractor hyd oil in a manual transmission [Re: racsan] #4462066
07/17/17 05:12 PM
07/17/17 05:12 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
If you can find Pentosin FFL-4 or Redline DCTF Dual Clutch Transmission Fluid (8.1 cSt)
they have the correct viscosity and friction modification for MT's speced for fluids of the ATF viscosity.
Reading is fundamental; understanding is not a given ability.
Re: 303 tractor hyd oil in a manual transmission [Re: racsan] #4464142
07/19/17 03:55 PM
07/19/17 03:55 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
A higher quality utf that meets a newer spec would be a better gamble.
2015 Ford F150 2.7
2018 Ford F350 6.2
