Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
125 registered members (benjy, Altima2, Benzadmiral, Bailes1992, aquariuscsm, Alfred_B, 8 invisible), 2,235 guests, and 63 spiders.
Topics286,397
Posts4,907,578
Members67,614
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Oil Temperature and moisture #4460325
07/15/17 05:05 PM
07/15/17 05:05 PM
Upstate NY
LZ1989 Offline OP
LZ1989  Offline OP
Upstate NY
with all this talk about engine temp and whether to run a hot thermostat or not. What does everyone think the min temp for engine oil to reach to get rid of condensation and water. Im not talking about going on short rides. I mean an hour drive, at what temp should the oil/coolant be to safely burn off the water.
Re: Oil Temperature and moisture [Re: LZ1989] #4460340
07/15/17 05:28 PM
07/15/17 05:28 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Interesting question. The answer of "30 minutes at normal operating temp" is a standard answer, but what is "normal"?
195F coolant temp does not always equal "normal" oil temp.
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: Oil Temperature and moisture [Re: LZ1989] #4460355
07/15/17 05:51 PM
07/15/17 05:51 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
Don't quote me, but I seem to recall a sustained 160F measured in the sump is good for cooking off moisture. Obviously the hotter the better, so maybe that isn't such a good answer, but it's the one in my head. Oil is pretty happy at around 220F, but ideally not much higher.
Plus there is the issue of where, exactly, you are measuring the oil temperature. There will be a wide variation, even in the same motor, depending on where you are picking up the temp.
That's why they say to watch your oil temperature when it goes higher than the typical number for your vehicle, rather than giving a specific temperature to watch for.
If I were concerned about it (I'm not) and wanted more info, I'd be looking at the higher reputation oil cooler manufacturers for guidance, so that's where I would be pointing my Google search terms.
Moroso
Derale
Setrab
Canton
... and some of the Hot Rod people.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Oil Temperature and moisture [Re: LZ1989] #4460358
07/15/17 05:58 PM
07/15/17 05:58 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
My oil runs 20-40F hotter than the 180F coolant on my Gen Coupe 2L turbo. But water evaporates at about any temperature, especially when the PCV system is pulling fresh air into the motor.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Oil Temperature and moisture [Re: LZ1989] #4460471
07/15/17 08:48 PM
07/15/17 08:48 PM
Upstate NY
LZ1989 Offline OP
LZ1989  Offline OP
Upstate NY
I have a 2.3l quad 4. so thermal cycling and high heat were killers of these motors. But I'm just hoping the 160 degree thermostat will keep the car warm enough without creating increased engine wear.
Re: Oil Temperature and moisture [Re: LZ1989] #4460476
07/15/17 08:58 PM
07/15/17 08:58 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
There's a MSc thesis on oil-life monitoring algorithms (2nd one down in the "interesting papers" forum) that I thought would answer this question, but from a quick look it doesn't, though I might have missed it.
Tests on short-tripping are discussed in terms of ambient temperatures, rather than actual oil temperatures. (25C ambient is said to prevent water accumulation).
The algorithm implemented assumes an optimum temperature of 80C, though water accumulation is only one of the factors mentioned.
Re: Oil Temperature and moisture [Re: Ducked] #4460573
07/16/17 01:04 AM
07/16/17 01:04 AM
MN
oil_film_movies Offline
MN
The range of 80 deg C (176 deg F) to 140 deg C (284 deg F) works the best.
From Noria http://www.machinerylubrication.com/Read/77/gm's-oil-life-system-improves-timing-of-oil-change
Re: Oil Temperature and moisture [Re: LZ1989] #4460641
07/16/17 06:42 AM
07/16/17 06:42 AM
Upstate NY
LZ1989 Offline OP
LZ1989  Offline OP
Upstate NY
I think I'm going to get a oil temp gauge and stick it in the oil pan next oil change, and keep an eye on the temps. The oil gets changed at 3,000 miles no matter what anyways, its not a daily driver. So I'm thinking even at a 160 thermostat the oil is reaching 176. Unless its mostly highway driving then I'm not sure.
Re: Oil Temperature and moisture [Re: LZ1989] #4460661
07/16/17 07:31 AM
07/16/17 07:31 AM
Upstate NY
LZ1989 Offline OP
LZ1989  Offline OP
Upstate NY
actually it looks like I may not do that. It seems to be a PITA to get one adapted to the drain plug, ill have to do some more looking around.
Re: Oil Temperature and moisture [Re: LZ1989] #4460664
07/16/17 07:36 AM
07/16/17 07:36 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
My oil filter adapter had a nice flat spot that was easy to drill and tap for a sensor.
Re: Oil Temperature and moisture [Re: LZ1989] #4460672
07/16/17 07:49 AM
07/16/17 07:49 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Get a multimeter with a type K thermocouple....do your thing, pull over, and drop the thermocouple down the dipstick hole which is into the area of drainback from the reciprocating/rotating assembly...cheap enough, and you'll be surprised.
Re: Oil Temperature and moisture [Re: Shannow] #4460849
07/16/17 11:22 AM
07/16/17 11:22 AM
Upstate NY
LZ1989 Offline OP
LZ1989  Offline OP
Upstate NY
Wow that is a good idea actually, Ill have to do that!
Re: Oil Temperature and moisture [Re: LZ1989] #4460975
07/16/17 02:12 PM
07/16/17 02:12 PM
Cheshire, England
barryh Offline
barryh  Offline
Cheshire, England
It's not so much about oil temperature as length of run. 80 C (176 F) is more than enough to get rid of condensation as long as the engine is not used only on short runs.
Barry
1979 BMW R45 (Triple QX 5W40)
2009 Mercedes C180K (Shell Helix Ultra 5W40)
Re: Oil Temperature and moisture [Re: LZ1989] #4460991
07/16/17 02:28 PM
07/16/17 02:28 PM
Morris County NJ
steve20 Offline
steve20  Offline
Morris County NJ
FWIW I think it depends on how far 'upstate' you are--equal to, or north of Albany, I doubt the 160 will be enough to get you sufficient heat inside the car
Steve
Re: Oil Temperature and moisture [Re: steve20] #4461012
07/16/17 03:02 PM
07/16/17 03:02 PM
Upstate NY
LZ1989 Offline OP
LZ1989  Offline OP
Upstate NY
Its just a summer car, the heater won't be used. well parallel with Albany.
Page 1 of 3 1 2 3
