Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
31 registered members (clinebarger, csandste, Bullwinkle007, carlprop, 3 invisible), 1,042 guests, and 38 spiders.
Topics295,007
Posts4,925,873
Members66,664
Most Online2,553
Oct 27th, 2018
Storing String Trimmers Without Leaking.. #4460323
07/15/17 04:00 PM
07/15/17 04:00 PM
MIchigan
Warstud Offline OP
Warstud  Offline OP
MIchigan
I store my String Trimmer(Weed Wacker) vertically with the engine at the top and it leaks gas. Is there a correct way to store it so it doesn't leak?
Re: Storing String Trimmers Without Leaking.. [Re: Warstud] #4460336
07/15/17 04:14 PM
07/15/17 04:14 PM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
Find the leak it shouldn't do that.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Storing String Trimmers Without Leaking.. [Re: Warstud] #4460341
07/15/17 04:29 PM
07/15/17 04:29 PM
Manvel, Texas
apwillard1986 Offline
Manvel, Texas
Check the cap or the fuel line grommet. I store mine vertically and they do not leak.
2011 Ext. Cab Silverado 4.3L V6 (His)
2013 Crew Cab Silverado 5.3L V8 (Hers)
Re: Storing String Trimmers Without Leaking.. [Re: Warstud] #4460342
07/15/17 04:35 PM
07/15/17 04:35 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
I store mine (and all similar tools, like ice augers) horizontally with the carb up. A slight incline is good too, but most are designed with a bit of incline anyway if you lay them down, perhaps via a handle. Also this type of tool is usually designed so that the vent in the fuel cap will be air-dry if you store it that way.
Carb will always leak gas so it has to be the highest fuel-accessible point; they have necessary passages open to the atmosphere.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Storing String Trimmers Without Leaking.. [Re: Warstud] #4460348
07/15/17 04:43 PM
07/15/17 04:43 PM
MIchigan
Warstud Offline OP
Warstud  Offline OP
MIchigan
I don't "get it" it's designed to operate vertically but when storing it vertically....it leaks.
Re: Storing String Trimmers Without Leaking.. [Re: Warstud] #4460374
07/15/17 05:37 PM
07/15/17 05:37 PM
West Michigan
Balrog006 Offline
Balrog006  Offline
West Michigan
When your using it the fuel doesn't get a chance to leak out, it's being burned...
There is a leak somewhere, need to find and fix it.
19 Ridgeline RTL-E >1K factory fill, A01
08 CRV 275K+ VSyn w/ML, A01
04 JD L130 740H, Mobil S 5w30
13 JD 2032r 325H, JD Plus 50 ii 15w40
M1Delvac 5w40 in OPE
Re: Storing String Trimmers Without Leaking.. [Re: Balrog006] #4460384
07/15/17 06:00 PM
07/15/17 06:00 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
A friend (who tinkers with small engines well) and I have concluded the E85 gas eats clear tubing parts and causes leaks.
We've found bits of clear rubber (crumbs) in fuel jets which stops the machines in their tracks.
Re: Storing String Trimmers Without Leaking.. [Re: Kira] #4460391
07/15/17 06:06 PM
07/15/17 06:06 PM
UT
BHopkins Offline
BHopkins  Offline
UT
Mine hangs vertically also, with the engine end up. I've never had a leak when it's stored like that.
No offense intended, but who in their right mind would be putting E85 in a small engine, particularly a 2 cycle engine?
I'll admit that I learned the hard way, but even 10% ethanol is hard on 2 cycle engines.
2013 Subaru Outback 2.5i - Idemitsu 0W-20 & Mobil 1 filter
2007 Mercedes SL550 - M1M 5W-40 & MB OEM filter
Re: Storing String Trimmers Without Leaking.. [Re: Warstud] #4460457
07/15/17 07:36 PM
07/15/17 07:36 PM
Upper Midwest by the Lakes USA
SumpChump Offline
SumpChump  Offline
And store your string in water folks.
Re: Storing String Trimmers Without Leaking.. [Re: BHopkins] #4460477
07/15/17 08:01 PM
07/15/17 08:01 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
Dang, yikes. E85. I try to avoid E10 if I can!!
Re: Storing String Trimmers Without Leaking.. [Re: EdwardC] #4460622
07/16/17 05:25 AM
07/16/17 05:25 AM
Kira Offline
Kira  Offline
To respond to as many of you as I can:
1) I'm not in my right mind. But then again, how would I know?
2) I just learned about finding straight gasoline for small engines. Is BP or Sunoco premiums 100% gas?
3) My weed whacker is a 4 cycle Honda.
4) Storing the spool of string in water? As in under water completely? Why, to keep it from drying out?
Thanks Kira
Re: Storing String Trimmers Without Leaking.. [Re: Warstud] #4460691
07/16/17 07:06 AM
07/16/17 07:06 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Its probably a bushing on the fuel tank. Fix it.
Some ope gets oily/slimy regardless. My echo blower always has an oily residue on the bottom though I can't get any fuel to leak even turning upside down, shaking, etc.
Re: Storing String Trimmers Without Leaking.. [Re: Warstud] #4460730
07/16/17 08:04 AM
07/16/17 08:04 AM
Houston, Texas
Houston, Texas
Of it's an echo they had some trouble with the has tank grommets going bad for a few years. Some had a recall on it.
