F1 - 2018 Russian Grand Prix
by gofast182. 09/26/18 06:11 AM
Pets Puking in Middle of the Night :~/
by LoneRanger. 09/26/18 05:16 AM
Is there a new (2018) list of GM Dexron VI licensees?
by garageman402. 09/26/18 01:20 AM
Thoughts on new AMAZON branded oil...?
by PantherFan88. 09/25/18 10:47 PM
Clutch kit?
by andrewp1998. 09/25/18 10:34 PM
Galaxy S8+ weird app when clearing storage
by KrisZ. 09/25/18 10:18 PM
Brake bleeder - cfm ?
by hallstevenson. 09/25/18 09:43 PM
18' Corolla vs 18' Elantra
by wolf_06. 09/25/18 09:41 PM
Using Tc-w3 bad for my car?
by Floydian. 09/25/18 09:25 PM
I'm going to start using type F in my gm autos
by turtlevette. 09/25/18 09:17 PM
Cleaning deceased MIL condo and found $15K cash
by Mr Nice. 09/25/18 09:12 PM
Gluten
by StevieC. 09/25/18 07:55 PM
Amazon Prime delivering inside your house
by StevieC. 09/25/18 07:49 PM
2018 MB C300 M1 0W-40 3,475 Miles
by 2015_PSD. 09/25/18 06:44 PM
02-05 Silverado frame rot
by Oildudeny. 09/25/18 06:38 PM
Aftermarket Back Up Camera
by lancerplayer. 09/25/18 06:20 PM
Service champ filter CUT OPEN
by 53' Stude. 09/25/18 05:05 PM
Pressure washer pump life just 23 hours?
by HawkeyeScott. 09/25/18 05:01 PM
Everzooom, donnyw, Dfeeds, JJ_RA, Captjayd
66077 Registered Users
74 registered members (advocate, 2015_PSD, ABomb369, Armkb, aquariuscsm, 2K2AcuraTL, 7 invisible), 865 guests, and 49 spiders.
Topics291,028
Posts4,854,762
Members66,077
Most Online3,590
Jan 24th, 2017
Choosing oil for a bracket racer drag car #4460217
07/15/17 02:06 PM
07/15/17 02:06 PM
California, USA
casamagana Offline OP
California, USA
I work on three different strip/street V8/RWD bracket cars. What are the qualities or specifications I should be looking for in choosing an engine oil? All three are single carburetor, hydraulic flat tappet camshaft engines. Ideally the engines get torn down and inspected every other season. An average season is around 150 1/8th mile passes during the heat of summer.
So the engines are a 406 small block Chevrolet, a 427 small block Ford, and a 440 big block Dodge. Changing oil often is not a concern; keeping expensive crankshafts, pistons, and valve trains in good shape is the goal. Maximum engine rpm is 6500 for all three combinations.
Currently using, depending on each engine owner's favorites, 10/30 VR1 and 20/50 Brad Penn. None of these engines have ever had major failures but I feel I'm always guessing on what to put in the crankcases.
Thanks ahead of time for your thoughts.
'15 Hemi 6spd Challenger, '89 Chev R3500 dually-454 tbi,
'67 Firebird-406 sbc-th350, 3.73 8.5"axle, [email protected]/8th
'66 Bug, '87 Banshee, '85 ATC 350X
Re: Choosing oil for a bracket racer drag car [Re: casamagana] #4460230
07/15/17 02:25 PM
07/15/17 02:25 PM
BC, Canada
userfriendly Offline
BC, Canada
I'll vote Delo 400 SAE 30 for the SBC & SAE 40 for the Ford 'n BBM.
Re: Choosing oil for a bracket racer drag car [Re: casamagana] #4460246
07/15/17 02:57 PM
07/15/17 02:57 PM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
Spend the money on a used oil analysis and see where your current oil brew is letting you down, then compensate!
too many cars and oil combinations to list in 150 characters or less
Re: Choosing oil for a bracket racer drag car [Re: casamagana] #4460247
07/15/17 02:58 PM
07/15/17 02:58 PM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
The hard launches and WOT of drag racing can be tough on engine parts, so use Redline.
Cable ties should hold it
Re: Choosing oil for a bracket racer drag car [Re: casamagana] #4460261
07/15/17 03:10 PM
07/15/17 03:10 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
It depends on a number of factors. Long list:
Rod and Main clearances for the bottom end, Cross-drilled or grooved Crank,
Are you gauging oil pressure at both ends of the crank or lifter gallies,
The valve spring geometry (Rev Pack, or just spring on valve?),
Valve spring pressures over the nose,
Who's lifters, made during what decade, what style (Direct Lube, or plain OEM style),
Distributor gear and oil pump (volume and pressure, as in HV or HP, or special race pump),
Are all the in-block oil pressure reliefs blocked off,
What kind of windage tray,
Any extra oiling holes or channels created when assembled,
Piston to wall clearances, and to a minor degree, what rings end gaps,
Debris screens epoxied into lifter valley to catch debris,
What filter (remote or direct mount),
Any signs of trouble so far? Any UOA's ... What do the cut-open filters look like,
Magnetic drain plug show "hair",
The oil has to fit the spaces and not foam from getting whipped up at anything above about 4,000 ...
Do you let these engines idle much? Are they warm at 180* coolant temp when you come to the line? What temps is the sump when you go out the big end?
Tranny's being cooled by the radiators?
How rich are you it idle and staging?
Any black smoke out the headers when the driver backs off,
Any trouble keeping the carbs full, w/o overflowing ...
That'll give us a good starting point smile
Re: Choosing oil for a bracket racer drag car [Re: casamagana] #4460381
07/15/17 06:59 PM
07/15/17 06:59 PM
Rochester, New York
johnnydc Offline
johnnydc  Offline
Rochester, New York
I'm no expert, But here is my 2 cents. I have 2 friends that race every week. Sometimes twice a week. They both have BB Chevys. Don't remember off hand the cubic inches I do know they both are above 800HP and lift the fronts every time. One of them use M1 10w30 the other uses VR1 10w40. Neither one of them have had catastrophic engine failures. They get rebuilt every 2 years.
2012 Ford Fusion SEL V6
2009 Mercury Milan Premier V6
Valvoline Advanced Synthetic 5/20 and Motorcraft Filters
Re: Choosing oil for a bracket racer drag car [Re: casamagana] #4460413
07/15/17 07:39 PM
07/15/17 07:39 PM
Texas
Dallas69 Offline
Dallas69  Offline
Texas
Why do you not teardown every season if not sooner?
Years ago when Dad raced we ran a straight 40 wt.
We had to replace a crank every 40 runs.This was when 1/4 mile was the norm.
I would just check with other racers and get an idea on oil.
2009 Galant-ultra oil and filter
1987 Ford F-150 302
Smittys 5-30
Motorcraft filter
Re: Choosing oil for a bracket racer drag car [Re: casamagana] #4460478
07/15/17 09:02 PM
07/15/17 09:02 PM
Chicago
Fraser434 Offline
Fraser434  Offline
Chicago
Look at AMSoil dominator 20W-50 , Gibbs Driven 15W-50.
Something more common found in stores Mobil1 15W-50 has 1300ppm zinc
Be careful with diesel oil, don't use bottles that say API CK4/SN rated. Should just say only CK4.
Re: Choosing oil for a bracket racer drag car [Re: BrocLuno] #4460589
07/16/17 02:01 AM
07/16/17 02:01 AM
California, USA
California, USA
Since the most recent overhaul was on the 406 sbc, let's work on this one.
Mains 1-4 and .002-.003,#5 at .0035 with .006 endplay.
Oil pressure at the lifter galley only, 55 [email protected] rpm @ 190 degree coolant temp.
No rev kit, yes spring on valve.
No information on over the nose pressure. No spring checker in the garage.
Comp Cams lifters from about 15 years ago. OEM style and always re-installed in their original locations on the cam.
Iron distributor gear and standard oil pump, no HV or HP.
Stock oil pressure relief at the filter mount is functional
Tray is welded into a deep sump pan with a short OEM tray bolted to the rear main bearing caps.
No extra oiling holes
Wall clearances were .003 to .005 on older TRW forged flat top pistons. I don't recall the ring end gaps and that note book is not nearby at the moment. I'm surprised at what I am remembering.
No debris screens
Wix, direct mount
No troubles, no UOAs. The cut filters never show any major debris. This engine has never hurt bearings or camshafts.
No magnetic plug
They only idle moving the staging lanes. Always at least 180 coolant temp after the burnout. No oil sump temp sensor.
Yes and an additional external cooler.
LM-2 shows 14 to at idle and staging, 12.5 through the traps.
No one has ever made that observation.
Nope, 1/2" fuel lines and a return style fuel system and electric pump
