Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
127 registered members (benjy, Altima2, Benzadmiral, Bailes1992, aquariuscsm, Alfred_B, 8 invisible), 2,239 guests, and 62 spiders.
Topics286,397
Posts4,907,578
Members67,614
Most Online2,967
Mar 10th, 2019
Oil shear? #4460001
07/15/17 10:23 AM
07/15/17 10:23 AM
MA.
Camprunner Offline OP
MA.
Is there any evidence that lower cost synthetic oils (ST, Form Shell, Parts Master, Etc,) shear down faster then the so called top tier oils (M1, PP, Amsoil, etc) of the same oil weight?
Re: Oil shear? [Re: Camprunner] #4460008
07/15/17 10:32 AM
07/15/17 10:32 AM
Sav ga
NStuart Offline
NStuart  Offline
Sav ga
I'm in
Detroit14l 1m75k mi bp schaffer9k 30k oil
96 ram 5.9 gas 80k built tranny 5k m1
85 cj7 4.2 performance build. Schaeffer 9000
08 cbr600rr graffiti. T6
08 husky sm610 t6
Re: Oil shear? [Re: NStuart] #4460013
07/15/17 10:42 AM
07/15/17 10:42 AM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Originally Posted By: NStuart
I'm in
Me too. I have no evidence but this will be interesting if someone does.
Thick vs Thin test: 15k / 43k miles complete
Re: Oil shear? [Re: Camprunner] #4460025
07/15/17 10:58 AM
07/15/17 10:58 AM
DFW
JustN89 Offline
JustN89  Offline
DFW
popcorn
Re: Oil shear? [Re: Camprunner] #4460368
07/15/17 06:15 PM
07/15/17 06:15 PM
MN
oil_film_movies Offline
MN
Its been covered as far as higher-spec oils vs. SN GF5 dexos1 oils.
Of course the missing info is which brands and types of oils use which type of VII chemicals.
http://hrcak.srce.hr/file/37720
Looks like any oil using OCP as the VII best passes the toughest shear tests (Shear Stability CEC L-14-93, ASTM D6278 / 7109).
Mercedes MB 229.5 rated oils, Euro-specs. ...
dexos1 doesn't appear to run the shear test as long as the Euro-spec oils do.
Conclusions from http://hrcak.srce.hr/file/37720 :
1. New international specifications ACEA and API require that the shear stability of
engine oils is tested by 90 cycles of oil passing through the nozzle instead of
current 30 cycles; these requirements are accepted by a number of vehicle
manufacturers.
2. Shear stability determination according to new ASTM D 7109 method has been
defined with 90 cycles of testing.
3. Different concentrations of viscosity index improvers are needed for production
of multigrade engine oil of the same viscosity; the highest additive concentration
is needed for the viscosity index improvers based on OCP.
4. Viscosity index improvers based on OCP have the best shear stability after 90
cycles of testing.
5. Engine oil with the viscosity index improver based on styrene-isoprene (C) has a
significant viscosity loss after extended testing from 30 cycles to 90 cycles and it
does not meet requirements of the new international and OEM specifications.
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1172315
Re: Oil shear? [Re: Camprunner] #4460616
07/16/17 06:09 AM
07/16/17 06:09 AM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
The more important underlying question:
Does it matter if they do?
The lube does not exist to be self-serving. It's there to protect the engine. So if there is some shearing (moderate, not obscenely out by two grades), does it affect wear? After all, that's the purpose of the lube; to reduce wear. I've seen a lot of UOAs, and I've never seen one where shearing (or ox thickening for that matter) affects much of anything when we're only talking about typical shifts in grade. Some oils have less room for vis loss; where an engine using a 10w-40 can easily tolerate a drop to 30, I'd not want a 5w-20 to drop to a 10.
But the thing to ask is if the shearing actually causes an effect?
How will you know? Run the lubes and find out.
I doubt you're going to see much disparity in the actual protection factor; that's their job after all, and that's what you should judge them on.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Oil shear? [Re: Camprunner] #4460623
07/16/17 06:25 AM
07/16/17 06:25 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
No, none, zip,. zero, not a concern.
Top tier = think of top marketing
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
