AAP 25% Off
by Egg_Head
06/22/18 06:03 AM
GM Ecotec 2.4 - Cracked Exhaust Manifold
by The Critic
06/22/18 05:05 AM
Half Price - Shell Helix HX7, Castrol Edge and GTX
by SR5
06/22/18 03:59 AM
Why hang your bicycle from the ceiling?
by mjoekingz28
06/22/18 03:47 AM
Oil For High Sustained RPM on BMW S52
by ZEK
06/21/18 10:41 PM
Chevy brought the blazer back
by WiskyBadger
06/21/18 10:07 PM
LC20 and uses in modern motor oil
by synman
06/21/18 10:01 PM
Full Synthetic CJ-4 or > 5W-30 or 10W-30
by LeTempt
06/21/18 09:57 PM
2018 RAM 1500 EcoDiesel
by OVERKILL
06/21/18 08:37 PM
Fram SureGrip coating
by mobilaltima
06/21/18 08:24 PM
Manual transmissioned electric car
by mjoekingz28
06/21/18 06:45 PM
1991 Toyota Previa New JDM engine Redline
by Kurtatron
06/21/18 06:26 PM
8 yr old channeling John Bonham
by Toy4x4
06/21/18 06:02 PM
Traveller nlgi 2
by Spitter
06/21/18 05:33 PM
Upgrading the Kohler 7000 series air cleaner
by Patrick0525
06/21/18 05:08 PM
Any nano reefers here?
by RichardS
06/21/18 05:04 PM
ARC remanufactured Power Steering Pump
by Pajero
06/21/18 04:58 PM
John Deere "Easy Change" System gimmick
by SnowmanCO
06/21/18 04:55 PM
Oz Planstic Bag Bans - not so green.
by Shannow
06/21/18 04:31 PM
help me choose...
by chaindrive
06/21/18 04:07 PM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
71 registered (aquariuscsm, 4WD, BoiseRob, brages, 01rangerxl, BeerCan, 6 invisible), 1147 Guests and 30 Spiders online.
65294 Members
67 Forums
285753 Topics
#4459756 - 07/14/17 11:09 PM will going up a curb bend a tandem axle trailer?
motor_oil_madman Online   content
Loc: Houston, Texas
I'm finding on my trailer that the driver side rear tire seems to wear more than the other tires, like big time. Makes me wonder if it's due to the time I went over the curb slightly backing into a customers driveway with about 4.5 yards of mulch on the trailer, so the whole rig probably weighed 5,000 pounds. That particular tire went way up into the rim when I backed into the driveway. I know on tandem axle trailers, you have that piece in the center of the two tires that the leaf springs connect to, so I wasn't worried and thinking oh it was just doing what it was designed to do, but I've always thought since then that that particular tire looked to have a little bit of negative camber compared to the front tire on that side, but it's hard to tell since they do that anyways whenever the trailer turns.
Opinions? Do you think most of the weight on that side went on that axle? It has two 3500 pound axles and I can't remember if it lifted up the front axle on that side when I went over the curb I think it came close, but not quite.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#4459757 - 07/14/17 11:10 PM Re: will going up a curb bend a tandem axle trailer? [Re: motor_oil_madman]
Loc: Houston, Texas
Just to clarify I'm referring to the axle, not the trailer.
#4459762 - 07/14/17 11:28 PM Re: will going up a curb bend a tandem axle trailer? [Re: motor_oil_madman]
Killer223 Offline
Loc: AZ
bust out the level, take hub off and measure and see what's level and what's not. could very well of bent the spindle, not very likely, but it could and does happen, i'd bet it's more of a turning wear than bent parts.
Get a large square, and on level ground see if it's out of square to the ground.
08 6.7 cummins G56
04 5.9 cummins
11 ranger 4.0
16 KTM 250 XC
#4459766 - 07/14/17 11:48 PM Re: will going up a curb bend a tandem axle trailer? [Re: motor_oil_madman]
CKN Offline
Loc: Utah
It's much more likely the axle is bent than anything else. If you have a tire with a consistent wear pattern-it is more likely the axle. Take to a shop that specializes in aligning axles. This could very well be a commercial truck place that does (big rig) commercial trailers.
NOT AN RV TYPE PLACE.
Curb hopping is a major source of throwing the alignment of an axle out. We all have done this-at one time or another.
Edited by CKN (07/14/17 11:49 PM)
#4459769 - 07/14/17 11:58 PM Re: will going up a curb bend a tandem axle trailer? [Re: motor_oil_madman]
Loc: Houston, Texas
I meant to say that tire went up into the wheel well, not rim lol
#4459770 - 07/15/17 12:02 AM Re: will going up a curb bend a tandem axle trailer? [Re: CKN]
Loc: Houston, Texas
Doesn't take much huh? I've always thought 7000 pounds is a good bit of weight for the skinny 205mm wide tires they call for on these landscape trailers. Same scenario with travel trailers.
Edited by motor_oil_madman (07/15/17 12:02 AM)
#4459864 - 07/15/17 07:12 AM Re: will going up a curb bend a tandem axle trailer? [Re: motor_oil_madman]
hemitom Offline
Loc: canada
wonder if it could have broken some belts in the tire ?? or through the axle of its axis a little. ??or slight bend in rim.??
2006 kia spectra.
2010 pontiac vibe.
2012 mustang coupe.
#4459865 - 07/15/17 07:14 AM Re: will going up a curb bend a tandem axle trailer? [Re: motor_oil_madman]
bullwinkle Offline
Loc: Cincinnati, OH, USA
The axles will deflect, the 3500 pound ones on our company enclosed trailer are slightly bent, wearing out the inside of the tread faster than the outside. Company is cheap, cheap, cheap-I would have sprung for the 5K ones myself, they would quickly pay for themselves in longer tire life.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
#4459879 - 07/15/17 07:34 AM Re: will going up a curb bend a tandem axle trailer? [Re: motor_oil_madman]
m37charlie Offline
Loc: Alaska
Awfully flimsy materials if it took going over a curve at idle speed to bend things. Why don't you get a 1.25 ton military trailer.
Charlie
05 Unimog U500/Unicat camper/Delvac 1 SHC ACEA E4/E5
09 BMW X5 35d/Delvac1 LE 5W30
88 Toyota OJ50LV OM314 motor D1 SHC
52 Dodge M37/Hercules diesel
#4459900 - 07/15/17 08:12 AM Re: will going up a curb bend a tandem axle trailer? [Re: motor_oil_madman]
64bawagon Offline
Loc: Michigan
Very easy to tweak an axle especially when turning. As has been suggested, don't go to a RV dealer for service on this, find a good spring/axle/frame shop that will work on trailers.
05 Duramax Chevy(SOLD), 64 Chevy wagon, 10 Jeep Wrangler, 17 Equinox (rental), 18 Silverado 1/2 ton
#4459954 - 07/15/17 09:16 AM Re: will going up a curb bend a tandem axle trailer? [Re: motor_oil_madman]
Loc: Houston, Texas
The tire is bald now, but it looked like it was wearing more about 1.5" from the shoulder on each side
#4459980 - 07/15/17 09:51 AM Re: will going up a curb bend a tandem axle trailer? [Re: motor_oil_madman]
Rand Offline
Loc: NE,Ohio
on each side is turning wear or underinflated.
on one side is alignment..usually inside edge of tire(s)
2017 Jeep Cherokee Trailhawk V6
#4460458 - 07/15/17 08:38 PM Re: will going up a curb bend a tandem axle trailer? [Re: m37charlie]
CKN Offline
Loc: Utah
Charlie
Yeah-that would work....not all of us want to drive/tow around something as heavy as you do......
