Aisin Warner TF-71SC
by Bailes1992. 12/19/18 06:37 AM
on the Fence about giving up Facebook
by Donald. 12/19/18 06:20 AM
Motorcraft Mercon LV, 15k, 15' Ford Fusion 6F35
by ssamaroo01. 12/19/18 06:14 AM
RockAuto AC compressors
by chrismo. 12/19/18 05:38 AM
Fullers Vintage Ale anyone?
by Lolvoguy. 12/18/18 11:23 PM
Got an alignment
by michaelluscher. 12/18/18 11:18 PM
Castrol Edge 0W-40; 9,762 mi; 2016 Ford Fiesta ST
by asiancivicmaniac. 12/18/18 10:50 PM
Windows Defender Error Code
by ZeeOSix. 12/18/18 10:20 PM
UOA Motul 300V, 5w40, 2013 BMW S1000RR
by Sportbiker. 12/18/18 09:53 PM
Under valve cover pics
by barkingspider. 12/18/18 09:47 PM
Kubota Super UDT2? Anything better?
by Jmoney7269. 12/18/18 09:23 PM
Car Door Fabric Glue
by cb450sc. 12/18/18 08:57 PM
Canadian Uber
by StevieC. 12/18/18 08:13 PM
71141 / Lifeguard 5
by chefwong. 12/18/18 07:52 PM
Tested Positive for Flu
by john_pifer. 12/18/18 07:37 PM
Cooper RTX?
by 01rangerxl. 12/18/18 07:25 PM
blkvzgo, AdamJames, Firefighter3244, Sportbiker, trollhattan
66721 Registered Users
81 registered members (aba4430, 2009Edge, ARB1977, 4WD, ABomb369, aquariuscsm, 8 invisible), 1,383 guests, and 38 spiders.
Topics295,254
Posts4,930,966
Members66,721
Most Online2,553
Oct 27th, 2018
Page 1 of 8 1 2 8
If 0w-20 in the winter why not 5w30 in the summer #4459651
07/14/17 07:47 PM
07/14/17 07:47 PM
PA
T-Stick Offline OP
T-Stick  Offline OP
PA
So we all know that the industry is moving to 0w20 ... but if that is the right weight for a winter viscosity why would not a lightweight (energy conserving) 5w30 be just as suitable or better in the heat of summer.
Re: If 0w-20 in the winter why not 5w30 in the summer [Re: T-Stick] #4459659
07/14/17 07:57 PM
07/14/17 07:57 PM
North Carolina
4ever4d Offline
4ever4d  Offline
North Carolina
You could do that, no problem. 0w-20 in September and 5w-30 in March. There is just really no need unless you are in the "Great White North". Both oils should do well under normal temp variations.
04 Chevy Colorado 3.5 I5 5w-30 OEF
07 Honda Element 2.4 I4 5w-20 OEM
10 Nissan Rogue AWD 2.5 I4 5w-30 OEF
Amsoil Products & Fram or Wix Filters
Re: If 0w-20 in the winter why not 5w30 in the summer [Re: T-Stick] #4459661
07/14/17 07:58 PM
07/14/17 07:58 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
If your engine calls for 0-20 5-20 use it year round.
2007 Ford Fusion 235,000 miles
M1 0-20 EP
2017 Ford Fusion 61K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: If 0w-20 in the winter why not 5w30 in the summer [Re: T-Stick] #4459670
07/14/17 08:05 PM
07/14/17 08:05 PM
Southeast Texas
gfh77665 Offline
gfh77665  Offline
Southeast Texas
I still think 0-20 or 5-20 for the northern tier and Canada, 5-30 for mid America, and 10-30 for the Gulf Coast, AZ and NM are the optimal weights. One size does not fit all. Houston, TX and Fargo, ND have vastly different climates.
Re: If 0w-20 in the winter why not 5w30 in the summer [Re: T-Stick] #4459678
07/14/17 08:14 PM
07/14/17 08:14 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
Because your engine is water cooled.
Now if you were going to the track or anything that calls for extended high HP output stepping to the
25% thicker 5w30 might be ideal.
Towing in the mountains..
Then again if your vehicle has Coolers for everything the thin oil works fine.. you only need to step up in viscosity if your oil temp is higher.
-20f in minnesota is alot different that 110f in phoenix.. when you are pushing your vehicle somewhat.
Re: If 0w-20 in the winter why not 5w30 in the summer [Re: Rand] #4459691
07/14/17 08:20 PM
07/14/17 08:20 PM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
Correct. More to the point, your engine is water cooled, and air temperatures on the hottest of days is still not much more than half of the engine's operating temperature, an almost 100F delta. Unless there is a malfunction or design problem, that's a lot of latitude. I've seen electronics cooling systems where the deltas are 10F between operating and outside cooling. Now that's a challenge.
Various musings: http://hangfire.net
Re: If 0w-20 in the winter why not 5w30 in the summer [Re: T-Stick] #4459779
07/14/17 11:41 PM
07/14/17 11:41 PM
MTL, CANADA
Rolla07 Online content
Rolla07  Online Content
MTL, CANADA
Why cant people accept that 0w20 is perfectly effective year around regardless of where you live, for daily driving?
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: If 0w-20 in the winter why not 5w30 in the summer [Re: T-Stick] #4459785
07/15/17 12:06 AM
07/15/17 12:06 AM
Balearic Islands , Spain
FordCapriDriver Offline
0W-20 will be fine, so will 5W-30, in PA ( Pennsylvania? ) a 5W-30 Synthetic will do just fine too.
If your particular engine has some fancy VVT system though i would stay with 0W-20 as thesse systems tend to work based on oil pressure and don't work right with the wrong viscosity.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort Mk4 Xr3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Finnish expat in Spain.
Re: If 0w-20 in the winter why not 5w30 in the summer [Re: T-Stick] #4459791
07/15/17 01:31 AM
07/15/17 01:31 AM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
What vehicle / engine / use / driving style?
I'm running the same 0W-20 PPPP in my 5.7L Hemi with MDS in San Antonio summer I ran in winter when I lived in the Great Lakes area with no problems. I typically run 5W-20 in the warmer 6 months because I bought a LOT of QSUD 5W-20 when it was $0.99 / qt. after stacked rebates at Menards, then had trouble during a Polar Vortex winter that didn't reappear when using 0W-20 the following winter.
My engine oil is water cooled and automatic transmission fluid is air cooled, no thermostats on either oil cooler or transmission fluid cooler (extremely evident during winter when I was living in the Great Lakes area).
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: If 0w-20 in the winter why not 5w30 in the summer [Re: Rolla07] #4459809
07/15/17 03:36 AM
07/15/17 03:36 AM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
Because there are much better options for wear protection and other lubrication dimensions, and a lot of people care about that?
That might be a reason.
Re: If 0w-20 in the winter why not 5w30 in the summer [Re: T-Stick] #4459829
07/15/17 05:06 AM
07/15/17 05:06 AM
Western usa
Ammofirst Offline
Ammofirst  Offline
Western usa
My brother does that in all his fords. 3.5 v6
Re: If 0w-20 in the winter why not 5w30 in the summer [Re: T-Stick] #4459832
07/15/17 05:18 AM
07/15/17 05:18 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
You can, but OEM's won't.
It's about $$$......and CAFE penalty.
Re: If 0w-20 in the winter why not 5w30 in the summer [Re: T-Stick] #4459847
07/15/17 05:54 AM
07/15/17 05:54 AM
North Texas
ARB1977 Online content
ARB1977  Online Content
North Texas
5W20 year round in my wife's CRV. Close to 170K trouble free miles. If it ain't broke don't fix it.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: If 0w-20 in the winter why not 5w30 in the summer [Re: T-Stick] #4459859
07/15/17 06:05 AM
07/15/17 06:05 AM
PA
T-Stick Offline OP
T-Stick  Offline OP
PA
The question is not posed for any particular vehicle, or for personal advice or for warranty considerations. The question is purely empirical. Most vehicle manuals recognize temperature ranges as part of the oil selection criteria even if they specify one recommended viscosity such 0w20. My point simply is that the viscosity of a 20 weight in winter temps of 0-10 degrees after the oil is warm cannot be that much different from the viscosity of a light 5w30 in 95-100 degree weather in the summer. The cooling system will usually not be able to completely uniform engine temps despite outside weather.
So my point is that if a heavy 20 weight is optimum for protection and performance, then probably a lightweight 5w30 is optimum in the heat of summer because 5w30 will often thin to a heavy 20 weight in hot temps while a 20 weight may thin more than what is optimum.
Re: If 0w-20 in the winter why not 5w30 in the summer [Re: T-Stick] #4459947
07/15/17 08:08 AM
07/15/17 08:08 AM
San Antonio, TX
jorton Offline
jorton  Offline
San Antonio, TX
It is a challenging topic. I was just reading the 17 ford focus uoa post. FF is 5-50 that thinned to a 30 I think.
There must be something different about the engine in that focus. Clearly Ford does not want 20 grade oil in that model.
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Page 1 of 8 1 2 8
