CASIO G-SHOCK
by Char Baby. 04/18/19 05:23 AM
Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
62 registered members (4WD, antik, 87sammy, Anthony, 2015_PSD, A1O, 7 invisible), 779 guests, and 26 spiders.
Topics287,674
Posts4,932,037
Members67,838
Most Online2,967
Mar 10th, 2019
Coolant overflow tube connector broke off #4459625
07/14/17 08:15 PM
07/14/17 08:15 PM
Vermont
methusaleh Offline OP
Vermont
I apologize if one of the photos appears upside-down, it does not on the device that I used to take the photo, but it does on the preview of my upload here.
Vehicle is a 1985 Chevy K5 Blazer. It is not a daily driver. I bumped up against the coolant overflow tube connector (for lack of a better term) with just enough force to break it off the neck of the radiator. It came from the little hole you can see directly below the radiator cap. I tried to JB Weld it back into place, but the location is so awkward that I couldn't get a clamp of any size in there to hold it while the JB Weld cures. I then went to the hardware store and got a male-to-male fitting that fit into both the overflow tube and the hole, however once again I can't come up with a way to hold it in the hole while adhesive or JB Weld cures/hardens.
The depth of the hole under the radiator cap is no more than 3mm or so, which is barely anything for adhesive/JB Weld to grab onto anyhow.
Any ideas? My redneck neighbor-- albeit he's a handyman-- says just ignore it and watch the temperature gauge, but I'd like more input than that!
Re: Coolant overflow tube connector broke off [Re: methusaleh] #4459634
07/14/17 08:31 PM
07/14/17 08:31 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Take the radiator to a radiator shop.....They can acid flux & silver solder that back on it a few seconds, The hole needs to be vertical when soldering the nipple back on....At least when I do it.
2001 Chevy Camaro L92/4L80E
Re: Coolant overflow tube connector broke off [Re: methusaleh] #4459649
07/14/17 08:45 PM
07/14/17 08:45 PM
USA
NHGUY Offline
NHGUY  Offline
USA
1985? I think I'd replace the radiator.Its probably 1/2 plugged anyway.
Re: Coolant overflow tube connector broke off [Re: methusaleh] #4459669
07/14/17 09:05 PM
07/14/17 09:05 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Ya we fix that problem all day long whete I work.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Coolant overflow tube connector broke off [Re: Chris142] #4459796
07/15/17 03:14 AM
07/15/17 03:14 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Originally Posted By: Chris142
Ya we fix that problem all day long where I work.
And how do you fix the problem ?
Re: Coolant overflow tube connector broke off [Re: methusaleh] #4459871
07/15/17 07:19 AM
07/15/17 07:19 AM
PA
copcarguy Offline
copcarguy  Offline
PA
A brand new radiator at www.rockauto.com is $75 - $115.
I'm sure you'd be close to or over this amount by the time you're done fiddling with it.
Re: Coolant overflow tube connector broke off [Re: methusaleh] #4460365
07/15/17 06:11 PM
07/15/17 06:11 PM
Vermont
Vermont
Thanks for all the replies. I am still considering options and ultimately need to discuss it with my wife. Doesn't look like something that will break the bank, though smile
Re: Coolant overflow tube connector broke off [Re: Merkava_4] #4460712
07/16/17 08:32 AM
07/16/17 08:32 AM
Chris142 Offline
Chris142  Offline
we solder it back on.
Broadway Radiator & Air Conditioning Service
https://www.yelp.com/biz/broadway-radiat...ef=yelp-android
Re: Coolant overflow tube connector broke off [Re: methusaleh] #4460942
07/16/17 01:13 PM
07/16/17 01:13 PM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
If you do not have soldering skills, replace radiator. If you have to pay someone to solder that old radiator, you might as well put it towards a new radiator. Don't leave it like that, excess coolant will spill out and air will be drawn back in when everything cools down. I would keep your neighbor away from it after seeing his solution to the problem (schmuck).
The "thinking" man's friend.
Re: Coolant overflow tube connector broke off [Re: Chris142] #4461168
07/16/17 07:08 PM
07/16/17 07:08 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Is that anything like brazing? Do you use a filler rod and a flame torch?
Re: Coolant overflow tube connector broke off [Re: methusaleh] #4461366
07/17/17 12:56 AM
07/17/17 12:56 AM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
I broke one years ago when I was all but broke.
I used fishing line and blue PVC glue (epoxy would have been better but used what was in the shed)."lashed" the spout into position with multiple wraps of fishing line, and blue glue.
It lasted ages, until I soldered it properly finally.
Re: Coolant overflow tube connector broke off [Re: Merkava_4] #4480270
08/05/17 09:29 PM
08/05/17 09:29 PM
Chris142 Offline
Chris142  Offline
40/60 solder,flux and a torch
