Magnetic Smartphone Holders
by willbur. 12/17/18 11:06 AM
1991 Caprice 5.0l hard starting in the AM
by WyrTwister. 12/17/18 10:55 AM
Question about new Peak OEM coolants
by PD001. 12/17/18 10:21 AM
Rev X
by Big_3_Only. 12/17/18 10:04 AM
Cleanliness
by WyrTwister. 12/17/18 08:12 AM
Gear whine
by odotb. 12/17/18 07:38 AM
Honda Pilot Oil specs US vs Overseas
by parshisa. 12/17/18 06:23 AM
Advisory on Roku TV's
by LoneRanger. 12/17/18 05:44 AM
Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
117 registered members (badtlc, atikovi, ARB1977, ArrestMeRedZ, aquariuscsm, 4WD, 11 invisible), 2,092 guests, and 51 spiders.
Topics295,182
Posts4,929,363
Members66,700
Most Online2,553
Oct 27th, 2018
Sent an email to Chevron..... #4459549
07/14/17 05:20 PM
07/14/17 05:20 PM
North Carolina
4ever4d Offline OP
4ever4d  Offline OP
North Carolina
I sent an email to Chevron (Lubetek) last night to see if i could get the HT/HS numbers for there HM oils as these are my current fills and favorites. When checking my email this evening i had received a reply. I am very happy with the results. As follows:
I am an avid user of your Havoline products and would like to know the HT/HS numbers for your Havoline product line. In particular the Havoline High Mileage 5w-20
- 2.8 cP
and 5w-30
- 3.3 cP
. These are the current fills in my wifes Honda and my Chevy truck. I have been unable to find this information and would like to know if you could supply this info.
Thank You,
TC
Michael A. Freeman
Lubrication Engineer
CLS, MLT II, OMA-I
[email protected]
Along with a kv100 of 8.8 and 11.8 respectively for 5w-20 and 5w-30 this i think makes for a stout oil. Oh and TBN of 8.5 isn't too shabby either. thumbsup
04 Chevy Colorado 3.5 I5 5w-30 OEF
07 Honda Element 2.4 I4 5w-20 OEM
10 Nissan Rogue AWD 2.5 I4 5w-30 OEF
Amsoil Products & Fram or Wix Filters
Re: Sent an email to Chevron..... [Re: 4ever4d] #4459612
07/14/17 06:54 PM
07/14/17 06:54 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
OP, thanks for asking.
Chevron, good work giving a straight answer to a straight question.
That 5W30 with KV100 of 11.8 cSt and HTHS of 3.3 cP particularly catches my eye, most ILSAC 5W30's are about 3.0 - 3.1 cP, while most Euro A3 5W30's are 3.5 - 3.6 cP. So this HM oil nicely sits in the middle, a very good place to be. Give it a TBN of 8.5 and that makes it a good strong product.
Here is a link to the product PDF which states they are synthetic blends.
https://cglapps.chevron.com/msdspds/PDSDetailPage.aspx?docDataId=486786&docFormat=PDF
SA = 0.9 %
Zinc = 880 ppm
Decent numbers for a modern GF-5 and SN oil.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Sent an email to Chevron..... [Re: SR5] #4459617
07/14/17 07:02 PM
07/14/17 07:02 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
Yeah I agree SR5. A 3.3 HTHS is a good middle ground compared to a thinner offerings and thick ones. I wonder what percentage of synthetic is actually in this new version? I would be willing to bet about 30-40%.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: Sent an email to Chevron..... [Re: bbhero] #4459637
07/14/17 07:34 PM
07/14/17 07:34 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
They also could be using their IsoSyn technology, which I believe is an heavily processed Group II+ base. It's used a lot in the Chevron Delo synblend HDEO's. Just guessing.
Re: Sent an email to Chevron..... [Re: SR5] #4459640
07/14/17 07:39 PM
07/14/17 07:39 PM
North Carolina
4ever4d Offline OP
4ever4d  Offline OP
North Carolina
SA = 0.9 %
Zinc = 880 ppm
SR5, these are the results i was hoping for. As you state, right down the middle not too thin and not too thick. I am pleased with this oil and plan for it too be my go to for awhile. I don't really need the "seal conditioners" as i have no leaks. This oil is lending to no usage in either vehicle, both dip sticks at full mark. bbhero, I would have no idea as to the synth content but 30-40% would be a good amount.
Re: Sent an email to Chevron..... [Re: 4ever4d] #4459656
07/14/17 07:52 PM
07/14/17 07:52 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
OP, what distance are you doing on this oil in your cars ?
It should be able to easily go 7,500 miles.
Re: Sent an email to Chevron..... [Re: SR5] #4459666
07/14/17 08:03 PM
07/14/17 08:03 PM
North Carolina
4ever4d Offline OP
4ever4d  Offline OP
North Carolina
At this point I am changing the Colorado out at 5-6k and the Honda is running by the OLM, going between 6.6 and 7k miles. I would be willing to try 7.5, but no without an UOA somewhere around the 6k mark.
Re: Sent an email to Chevron..... [Re: SR5] #4459671
07/14/17 08:06 PM
07/14/17 08:06 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
It may well be they are using their Isosyn group 2 oil in it. Given that they are mentioning on the front of the label it is a synthetic blend now I would bet it would be about 30 percent.
Re: Sent an email to Chevron..... [Re: 4ever4d] #4459688
07/14/17 08:19 PM
07/14/17 08:19 PM
Michigan
daves87rs Offline
daves87rs  Offline
Michigan
Not bad at all!
Coming together is a beginning; keeping together is progress; working together is success.
Henry Ford
Re: Sent an email to Chevron..... [Re: 4ever4d] #4459704
07/14/17 08:32 PM
07/14/17 08:32 PM
North Carolina
4ever4d Offline OP
4ever4d  Offline OP
North Carolina
I was really impressed of the 2.8cP HT/HS for the 5w-20 as that is teetering on a 30w at a 2.9cP min.
Re: Sent an email to Chevron..... [Re: 4ever4d] #4459777
07/14/17 11:40 PM
07/14/17 11:40 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Yeah the Havoline HM 5W20 has a KV100 = 8.8 cSt and a HTHS = 2.8 cP
While M1 HM 5W20 has a KV100 = 8.6 cSt and a HTHS = 2.7 cP for comparison.
So Havoline HM is definitely a thick 5W20 oil, I would probably give the nod to M1 for low Noack volatility, as this seems to be a M1 strong point.
But if you need a 5W20 for warranty but you want an oil at the thick end, the Havoline HM would do the job nicely.
Re: Sent an email to Chevron..... [Re: 4ever4d] #4459780
07/14/17 11:42 PM
07/14/17 11:42 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Sounds good to me.
