2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
101 registered members (64bawagon, 69GTX, 97f150, 97prizm, 65convertible, 9 invisible), 1,657 guests, and 62 spiders.
Topics286,228
Posts4,904,674
Members67,582
Most Online2,967
Mar 10th, 2019
Automobiles vs Mowers #4459480
07/14/17 04:35 PM
07/14/17 04:35 PM
MD
AirgunSavant Offline OP
MD
I have some MC. Oil filters that I quit using because they are Purolators.
That said in mowers that are from say 30 to 37 HP gas engines I'd like to run a 910s to 100 hours. Just to see if it tears.
Questions is. Does a lawn mower engine create more or less strain on a oil filter than say a normally aspirated Engine like you would find in say a Ford Fusion etc??
Both car and mower operating in the same climate.
I plan to use a FS. 15w50 oil.
Re: Automobiles vs Mowers [Re: AirgunSavant] #4459492
07/14/17 04:57 PM
07/14/17 04:57 PM
USA
oldhp Offline
oldhp  Offline
USA
Far less stress my opinion. Would be a good test to see if it tears.
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
Re: Automobiles vs Mowers [Re: AirgunSavant] #4459501
07/14/17 05:17 PM
07/14/17 05:17 PM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
MC may be built by Puro, but they're built to Ford's specs, and are good filters, especially the FL400s and FL910s. I've cut open many of these, and never found a problem. Run yours on your car.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 271,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 62,000mi
Re: Automobiles vs Mowers [Re: AirgunSavant] #4459507
07/14/17 05:26 PM
07/14/17 05:26 PM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
The top oil pressure in Briggs and Kohler small engines are ~40 PSI.
Not sure about the Kawasaki units. Most Japanese auto and cycle mfgs
seem to like 70 psi pressures.
Then to, the low hours you are talking about might be even less stressful
on the filters.
The 'tears' might be a result of extended pressure (time) and
wide fluctuations of pressure and flow on the average auto/truck engine.
My 2
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Automobiles vs Mowers [Re: SirTanon] #4459509
07/14/17 05:27 PM
07/14/17 05:27 PM
MD
MD
Yes they are the stars of that line. I have plenty of Ultras for the car.
If the 910 holds up it will be a nice cheap mower filter. I always liked the look of them.
Now the 820 filters have been junk.
Re: Automobiles vs Mowers [Re: dwendt44] #4459515
07/14/17 05:31 PM
07/14/17 05:31 PM
MD
MD
on the filters.
My 2
Thanks for the information!!!
I wonder if mower engine temps could be harder on the filter since I mow large properties and not small lots. Those filters get scalding rather quickly on the mower.
Re: Automobiles vs Mowers [Re: SirTanon] #4459535
07/14/17 06:00 PM
07/14/17 06:00 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
While I agree the FL-400 and 910S have a good record and have not had issues like the FL-820S, I know I have seen at least one of them (400/910S, don't remember which one) with a tear in the same spot as other Purloators.
The fact is Purolator filters have gone to poop, and they have failed to respond or fix the issues for years. The only Puro made filter worth a darn are the Bosch Distance Plus (which I am not sure who sells anymore besides Amazon). Other than that one, Puro made filters are off my list.
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: Automobiles vs Mowers [Re: AirgunSavant] #4459680
07/14/17 09:15 PM
07/14/17 09:15 PM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
Mower engines run a lot hotter than cars. 250-280 is typical on a mower vs 200-210 in a car, so not sure if high heat is hard on an oil filter. This is a great question though.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Automobiles vs Mowers [Re: AirgunSavant] #4459709
07/14/17 09:37 PM
07/14/17 09:37 PM
il usa
merconvvv Offline
merconvvv  Offline
il usa
whats the issue with fl 820s. I just stocked up on those !
1988 Mazda RX7 na PP 10w30 Noack 4.7
1994 Chrysler Concorde 3.3
1999 Ford Expedition 4.6 QSUD 10W30 NOACK 5.0
Re: Automobiles vs Mowers [Re: merconvvv] #4459718
07/14/17 09:51 PM
07/14/17 09:51 PM
Houston, Texas
WellOiled Offline
WellOiled  Offline
Houston, Texas
They tear in the same manner the Purolators do at the wide pleats near the seam.
2004 Ford Ranger 4.0L V6
Valvoline Advanced Full Synthetic HM 5W30 + WIX 51372
Re: Automobiles vs Mowers [Re: AirgunSavant] #4459721
07/14/17 09:58 PM
07/14/17 09:58 PM
Houston, Texas
WellOiled Offline
WellOiled  Offline
Houston, Texas
Double post.
Re: Automobiles vs Mowers [Re: AirgunSavant] #4459730
07/14/17 10:15 PM
07/14/17 10:15 PM
Houston, Texas
Houston, Texas
I haven't seen a synthetic fiber filter tear yet.
Re: Automobiles vs Mowers [Re: motor_oil_madman] #4459918
07/15/17 08:32 AM
07/15/17 08:32 AM
MD
MD
Thanks. I thought so.
Like you said they get hot and if you touch the filter it will burn you good. I can imagine a 100F degree day mowing for hours with no air at all- heavy humidity and no breeze like we had the last few days.
Especially if you are a maintenance pig and don't even keep things clean with a leaf blower.
We'll find out soon I guess smile
Re: Automobiles vs Mowers [Re: motor_oil_madman] #4459995
07/15/17 10:14 AM
07/15/17 10:14 AM
blupupher Offline
blupupher  Offline
I think the 910S with a synthetic ADV is a good thing though (if the ADV is needed). Nitrile does not like heat and would probably harden pretty quickly.
Re: Automobiles vs Mowers [Re: AirgunSavant] #4460637
07/16/17 06:36 AM
07/16/17 06:36 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
Many OPE engines (like my 21HP Briggs) have a pump that pumps the oil through the filter, but the engine is splash lubricated. I have used MC FL910S filters for years in both my Briggs engine and my car engines. To date none have had a problem.
2007 Ford Fusion 239,000 miles
M1 0-20 EP
2017 Ford Fusion 67K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
