Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
21 registered members (bbhero, 2015Corolla, dishdude, Aero540T, Char Baby, Exhaustgases, 1 invisible), 773 guests, and 40 spiders.
Topics295,007
Posts4,925,890
Members66,664
Most Online2,553
Oct 27th, 2018
Oil/filter for 250k Prius, hills & city driving #4459422
07/14/17 02:37 PM
07/14/17 02:37 PM
Tennessee
BigPoppa Offline OP
BigPoppa  Offline OP
Tennessee
I have a 2006 Prius that just hit 250k miles. Just paid for the traction battery to be serviced (not totally replaced), so want to make sure the engine lasts as long as possible.
Have been using Dino 5w-30 at Valvoline Instant Oil Change every 4k for the 40k I put on it, don't know anything about previous service. I drive mostly city & suburban miles, lots of hills, very hot & humid. I'm not much of a leadfoot and I do a fair amount of idling with the AC on (which in a Prius mostly runs off the traction battery but the car will restart in order to charge it back up). Have noticed that the engine makes more noise under acceleration than is normal for a Prius (still quieter than non hybrids).
Am interested in doing my own oil & filter changes using quality products (so I assume this means an 0w-20 synthetic). Would also like to extend the interval between changes, if prudent. So, what oil & filter combo would you recommend?
Thanks
Re: Oil/filter for 250k Prius, hills & city driving [Re: BigPoppa] #4459428
07/14/17 02:41 PM
07/14/17 02:41 PM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
The OEM filters work great. You can get them off amazon for 4.20 a piece if you buy in 10. that is what I did on my last prius and I have 6 left. If you were near me id let you have them.
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Re: Oil/filter for 250k Prius, hills & city driving [Re: BigPoppa] #4459437
07/14/17 02:49 PM
07/14/17 02:49 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Seems the oil and filter you used for first 250,000 miles worked well
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Oil/filter for 250k Prius, hills & city driving [Re: BigPoppa] #4459453
07/14/17 03:01 PM
07/14/17 03:01 PM
NC
Vladiator Offline
Vladiator  Offline
NC
Hot and humid. Hill driving. 250k miles. Sounds like your Prius is a perfect candidate for Valvoline Maxlife full synthetic 5w30. You'll thank me later.
Re: Oil/filter for 250k Prius, hills & city driving [Re: Vladiator] #4459455
07/14/17 03:03 PM
07/14/17 03:03 PM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
Yeah this sounds like what I would do, with an OEM filter. Except I'd use the factory specified viscosity and see if any oil is lost. If no loss, stick with the factory spec.
too many cars and oil combinations to list in 150 characters or less
Re: Oil/filter for 250k Prius, hills & city driving [Re: BigPoppa] #4459462
07/14/17 03:10 PM
07/14/17 03:10 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Any modern GF-5 5W-30 synthetic will be far better than what it's been running on. I'd find the cheapest jug at Walmart and run that. Prius engines aren't picky and don't need any special kind of protection that a more powerful engine would.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: EDGE 0W-30
Re: Oil/filter for 250k Prius, hills & city driving [Re: 1JZ_E46] #4459464
07/14/17 03:13 PM
07/14/17 03:13 PM
NC
Vladiator Offline
Vladiator  Offline
NC
If this is the 1.5L, then they are known to be quite oil burners, and need a bit of a specialized oil to fight that. Read: High Mileage.
Re: Oil/filter for 250k Prius, hills & city driving [Re: 1JZ_E46] #4459467
07/14/17 03:15 PM
07/14/17 03:15 PM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
Prius 1NZ-FXE engines have very frequent start-stop cycles.
Conventional wisdom holds that most engine wear occurs at startup.
So wouldn't a very good, properly specified, easily flowing oil be the right choice?
Re: Oil/filter for 250k Prius, hills & city driving [Re: L_Sludger] #4459473
07/14/17 03:24 PM
07/14/17 03:24 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
I was trying to get across that any modern GF-5 synthetic will be a big step up from dino, especially in terms of cold-flow. Something like Castrol Magnatec would be a good fit in terms of performance and value.
Re: Oil/filter for 250k Prius, hills & city driving [Re: BigPoppa] #4459476
07/14/17 03:28 PM
07/14/17 03:28 PM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
Yes, I agree that modern synthetics are marvelous, well refined products these days.
Re: Oil/filter for 250k Prius, hills & city driving [Re: L_Sludger] #4459520
07/14/17 04:40 PM
07/14/17 04:40 PM
CA
raytseng Offline
raytseng  Offline
CA
would just like to say correction on the wisdom is more specifically cold startup.
The warm startups are not something thst makes a significant wear factor
for the op, id say the oci on dino is too low. if you go by that it is fuel consumed not miles, then a high mpg vehicle should be easier on the oil so 4k is overkill.
especially considering your mileage thst indicates a over average used car which is also easier on the oil. and then as a hybrid the engine is often running in a more efficient mode and not just the primary power source. so thats another point for easy on the oil.
but whatever makes you feel better.
Re: Oil/filter for 250k Prius, hills & city driving [Re: BigPoppa] #4459529
07/14/17 04:53 PM
07/14/17 04:53 PM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
Thanks
During your 40k on 5w-30, was there any oil use?
I would use Motorcraft synthetic blend 5w-30 and a Toyota 90915-yzzF1 genuine oil filter. I find it to be a very fine oil and "quiet" if there is such a thing. I used to use it in mine. The F1 filter is the slightly longer but otherwise identical filter to the F2. Makes is easier to change having the extra 3/4 inch in length. The transaxle oil should be changed using genuine Toyota WS fluid. Every 60k is what I would do, and what I do. It's a little trickier than the engine oil but not that bad.
Re: Oil/filter for 250k Prius, hills & city driving [Re: BigPoppa] #4459550
07/14/17 05:25 PM
07/14/17 05:25 PM
CA
The Critic Offline
The Critic  Offline
CA
By your mileage, these engines usually drink a ton of oil. How much oil consumption do you see? I have yet to see a Gen2 Prius that does not drink at least a 1-2 quarts between oil services.
Also, it is unfortunate that you elected to service your traction battery instead of replacing it. You will surely be replacing it within the next 1-3 years. The money would have been better spent towards a new replacement. How much did you pay for the "service?" Was it done thru a franchise similar to "the hybrid shop?"
2011 Toyota Prius - 178k - Various 0W-20 (Brew)
2007 Honda Accord 2.4 - 133K - Mobil 1 EP HM 5W-30
Re: Oil/filter for 250k Prius, hills & city driving [Re: The Critic] #4459568
07/14/17 05:47 PM
07/14/17 05:47 PM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
I install grid chargers on all of my hybrid vehicles that I have owned ( 7 so far) and think it is one of the best things you can do for your hybrid, so depending what his service entailed andn if he was already experiencing problems yet or not before the service. Hybrid like to be driven daily
Re: Oil/filter for 250k Prius, hills & city driving [Re: raytseng] #4459570
07/14/17 05:53 PM
07/14/17 05:53 PM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
True that...
and warm, with a positive displacement oil pump, 0W, 5W, and SAE30 make zero difference in "flow" to repressurise galleries.
