2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
103 registered members (1978elcamino, 64bawagon, 69GTX, 97f150, 65convertible, 12 invisible), 1,660 guests, and 63 spiders.
Topics286,228
Posts4,904,674
Members67,582
Most Online2,967
Mar 10th, 2019
11' Ford F150 5.0 oil consumption, timing chain #4459390
07/14/17 03:06 PM
07/14/17 03:06 PM
Tennessee
fordkid Offline OP
fordkid  Offline OP
Tennessee
I've got a 2011 F150 with 5.0L coyote. I bought it with 55k miles on it, changed the oil first thing with a motorcraft filter and royal purple 5w-20 full synthetic (factory recommended oil weight). Checked oil shortly after first change maybe 1500 miles, and it was a quart low. Added more oil. Went through 2 more oil change cycles both times had to add around a quart of oil. After that I put an oil separator on the pcv lines and the consumption decreased from a full quart to less half a quart or sometimes even less. The truck now has 79k miles, I don't drive it every day often sits for 4 to 5 days a week. Now probably 1 out of 5 times starts after sitting the timing chains will slap where the tensioners aren't holding. Would swapping to 10w-30 help any of these issue or make them worse ? Also thinking of swapping to amsoil full synthetic.
Re: 11' Ford F150 5.0 oil consumption, timing chain [Re: fordkid] #4459401
07/14/17 03:13 PM
07/14/17 03:13 PM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
I have a neighbor who had a '12 F150 with the Coyote engine. About the same mileage as yours too. His started fouling a spark plug and had lost compression in one cylinder. He traded it for an EcoBoost before it got worse. Good luck finding your culprit!
too many cars and oil combinations to list in 150 characters or less
Re: 11' Ford F150 5.0 oil consumption, timing chain [Re: fordkid] #4459404
07/14/17 03:16 PM
07/14/17 03:16 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Just use some decent oil and don't use these gimmick fancy boutique over-priced.
Then determine what the oil usage is.
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: 11' Ford F150 5.0 oil consumption, timing chain [Re: fordkid] #4459406
07/14/17 03:18 PM
07/14/17 03:18 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
Sorry, but yours is most likely a mechanical issue present before you bought the truck.
2007 Ford Fusion 239,000 miles
M1 0-20 EP
2017 Ford Fusion 67K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: 11' Ford F150 5.0 oil consumption, timing chain [Re: fordkid] #4459424
07/14/17 03:39 PM
07/14/17 03:39 PM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
I just asked my neighbor again about his former F150 with the Coyote. He said it burned a little bit of oil too. Just 2 cents
Re: 11' Ford F150 5.0 oil consumption, timing chain [Re: fordkid] #4459432
07/14/17 03:44 PM
07/14/17 03:44 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
I'd go with a quality 10W-30 synthetic right off the bat.
I believe there is a TSB on tensioner related timing chain noise on your engine.
I keep mentioning that these ultra thin oils are fantastic at certain things. But cylinder wall lubrication and timing chain life is not ideal with thin oils. There is no magic to chain life. Particulates will cause pin wear. And the oil's viscosity is directly related to film strength and thickness. So, more frequent oil changes and a higher viscosity may be warranted. Chain manufacturers will often specify a 30 viscosity oil or higher.
GM got tired of replacing chains under warranty, and changed the oil life monitor to a far more normal oil change interval.
Re: 11' Ford F150 5.0 oil consumption, timing chain [Re: fordkid] #4459433
07/14/17 03:45 PM
07/14/17 03:45 PM
New York Queens
Ram02 Offline
Ram02  Offline
New York Queens
Wow I thought the coyote motor was pretty solid . Maybe change the brand of oil your using
2013 Malibu 2LT M1 5w30
2013 Accord Sport M1 AP 0w20
Re: 11' Ford F150 5.0 oil consumption, timing chain [Re: fordkid] #4459442
07/14/17 03:54 PM
07/14/17 03:54 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Oil may or may not help Try a 10w-40 let us know the difference.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 11' Ford F150 5.0 oil consumption, timing chain [Re: tig1] #4459444
07/14/17 03:55 PM
07/14/17 03:55 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Like, bad metallurgy in the steel of the timing chain links?
Poor heat treating?
Re: 11' Ford F150 5.0 oil consumption, timing chain [Re: fordkid] #4459445
07/14/17 03:56 PM
07/14/17 03:56 PM
Austin, Texas
Brons2 Offline
Brons2  Offline
Austin, Texas
Wasn't 2011 the first year of the Coyote? Maybe that has something to do with it?
2012 Hyundai Sonata GLS 6MT 2.4GDI, ProDS 10w30, XG9688 filter, 2018 Mitsubishi Outlander SEL 2.4 CVT, Factory fill still.
Re: 11' Ford F150 5.0 oil consumption, timing chain [Re: fordkid] #4459481
07/14/17 04:36 PM
07/14/17 04:36 PM
USA
NHGUY Offline
NHGUY  Offline
USA
First the Tritons were lunching spark plugs and had bad valve timing actuators,and now the 5.0 isn't any good? I think sticking with the base V6 unless you need the extra power is always the best choice.
Re: 11' Ford F150 5.0 oil consumption, timing chain [Re: fordkid] #4459496
07/14/17 05:04 PM
07/14/17 05:04 PM
Dayton,Ohio
ShotGun429 Offline
ShotGun429  Offline
Dayton,Ohio
The 5.0 ohc has a stellar record. use a "normal" off the self oil. motorcraft,valvoline,pennsoil,etc and get back to us.
Re: 11' Ford F150 5.0 oil consumption, timing chain [Re: Brons2] #4459513
07/14/17 05:30 PM
07/14/17 05:30 PM
Houston, TX
czbrian Offline
czbrian  Offline
Houston, TX
My dad has a 2011 as well and hasnt had a issue. The engine runs runs smooth and quiet although Ive only put 5w30/0w30 in it other than a couple times. He bought it with 90k and it has 160k miles now.
Re: 11' Ford F150 5.0 oil consumption, timing chain [Re: fordkid] #4459530
07/14/17 05:55 PM
07/14/17 05:55 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
I too have heard many good things about the coyote.
I'm still waiting for the 5.0 ecoboost. Prolly 500 hp and something ridiculous for tq in an F350
My source: SWAG and some math. 365/3.5 = 104.29HP/L
For 5L * 104.29 = 520ish. And knock off a bit just because.
You could probably tune it and throw on an aftermarket exhaust and break 700hp easy.
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: 11' Ford F150 5.0 oil consumption, timing chain [Re: fordkid] #4459573
07/14/17 06:54 PM
07/14/17 06:54 PM
MA.
Camprunner Offline
Camprunner  Offline
MA.
Ok my take ..... I have a 2013 Mustang GT 5.0 with 24,000 miles that will drink a quart every 5,000 miles of any brand and weight of off the shelf synthetic if I wind it up driving it around town. If I drive it totally on the highway the car will not use a drop of oil. This is not uncommon if you read on the mustang forums. In 2013 the 5.0 Pistons and all the rings were changed to a different design it seems there were issues with the 2011-2012 models by no means all of them.
I would ditch the Royal Purple the guy who lives next door to me is a Subaru WRX nut! He and his friends mess with there hot rod Modded WRX cars every weekend in the summer. A few weeks ago we had a big oil talk and several of them had issues with oil consumption running RP oil. All of them switched to other brands Shell, Castrol, Valvoline, Mobil and one guy running Motul. Some running 30 weights the rest running 40 weights.
Most Mustang 5.0 guys seem to graduate to a 5 or 10w30 if they do extensive reading on the forums and seem to care. The exception is the track pack 5.0 cars running the recommended 5w50. I now use only Valvoline Synpower 5w30 since it seems to idle better on it then all the other synthetic oils I have tried.
If it were my truck I would run Valvoline Synpower 5w30 and give it a few oil changes and see if the consumption improves.
